Amps to EmonCMS Question
Since the IotaWatt utilizes CTs which gather the total amps flowing in each phase. I was wondering when we setup a transfer to something like EmonCMS if the value of the amps is the raw data from the CTs and not derived from the power, W, value divided by the voltage.
The IoTaWatt measures Watts, Amps and Volts. It stores Watts, VA and Volts. It develops all other metrics from these values. Specifically Amps are computed by dividing VA by Volts.
Thanks for the answer.
