I have my system up and running.
I first connected CT’s to my incoming mains and my Heat Pump but I’m seeing something that I cannot explain and hoping someone can help.
It would appear that the power consumed by my heat Pump exceeds the total power input coming in on my Mains. How can this be?
The Blue and Green lines are my mains stacked and the Red line is my Heat Pump. Heat Pump consumption appears to exceed the total power coming into the house ???
Here’s a pic of the CT for the HeatPump
I looked in the manual for a way to match physical CT’s to CT’s in the configuration drop down list but couldn’t find any. I suspect this is the problem but I can’t really tell which CT to select for the different CT’s I received in my shipment???
That photo shows a 100A CT, if I am reading the label correctly. So, you should select the correct 100A CT,instead of a 200A CT, in the configuration drop down menu.
