Received and install 1st station Feb 1. All works fine except all sensors on 1st phase showed reversed and are installed correctly (same) on all breakers. I just checked reverse in setup. One main show reversed so I flipped it. Everything works OK just curious why as all was installed correctly.
I want to get a second base station for additional sensors, I know you are trying to catch your backlog up so waiting for you to list these. OR is it possible to order a US kit and you substitute 50 amp sensors for the 200amp, 100amp, and Voltage supply? I could put the change in the notes on the order.
