Best practices for influxdb?
Sorry, I tend to want to squeeze everything I can from a new toy. So if I can log Pf or Hz going from 59.97 to 60.05, I’ll want to do it. Even if there is no value in doing so. Have to rethink my philosophy of “capture everything”.
So for clarification, the tag set is only for defining your IotaWatt device (if you have multiple IotaWatts) which stores an InfluxDB tag for every value? I’m guessing tag sets are related to the inputs because the first one (Iotawatt=Home) gets tagged with every record. What else are tag sets (in the Iotawatt config) used for? How do the variables work? Has this already been explained somewhere (link)?
We did get some best practices out of this thread : )
  • Keep measurement & tag names short
  • Use 10 second or longer interval
  • Only bulk send 2-3 intervals at a time
The upload history doesn’t seem to be working for me. When I delete the measurement in InfluxDB (DELETE FROM Total_Mains). The Iotawatt just picks up with the next record/sample. I also tried stopping the service (from the status page), then delete the measurement, then restart the InfluxDB service.
This is what I see in my log…
12/01/18 19:13:07 Updater: service started. Auto-update class is MINOR
12/01/18 19:13:07 dataLog: service started.
12/01/18 19:13:07 dataLog: Last log entry 12/1/18 19:12:55
12/01/18 19:13:08 historyLog: service started.
12/01/18 19:13:08 historyLog: Last log entry 12/1/18 19:12:00
12/01/18 19:13:08 EmonService: started. url=192.168.208.3:80, node=IotaWatt, interval=10, encrypted
12/01/18 19:13:08 influxDB: started, url=192.168.208.1:8086, db=iotawatt, interval=10
12/01/18 19:13:09 EmonService: Start posting at 12/1/18 19:13:00
12/01/18 19:13:24 Updater: Invalid response from server. HTTPcode: -11
12/01/18 19:13:28 influxDB: Start posting at 12/1/18 19:10:30
12/01/18 19:14:35 EmonService: Stopped. Last post 12/1/18 19:14:30
*** I Stopped using EmonCMS ***
12/02/18 11:31:04 WiFi disconnected.
12/02/18 11:32:07 WiFi connected. SSID=gg, IP=192.168.208.5, channel=1, RSSI -72db
*** I deleted the Influx records here, but noticed only new records were being sent ***
12/02/18 15:00:12 influxDB: Stopped. Last post 12/2/18 14:59:20
*** Then I stopped the service, deleted InFluxDB records, then restarted - same result ***
12/02/18 15:00:33 influxDB: started, url=192.168.208.1:8086, db=iotawatt, interval=10
12/02/18 15:00:35 influxDB: Start posting at 12/2/18 14:59:30
I believe historical records were working when I was messing with EmonCMS, but for InfluxDB the IotaWatt seems to start on the next record (not starting with the Upload History date). I’ve tested this on both calculated data and direct inputs.
Untitled
Anything else I can check? I guess it’s not a big deal, I just have to wait for Influx to get new data instead of using the old data in the IotaWatt.
Thanks,
— edit —
Forgot to mention I deleted my logs once I finalized my panel/CT setup (on 11/28), so everything starts logging here…
Untitled
