Hi all
I have used my iotawatt in a while; but got it back working yesterday - however today, the status page is blank:
The log looks like the following: I have deleted the datauploaders; but i still cant get it to work
6/03/22 22:32:06 grid: Started
6/03/22 22:32:06 grid: New log starting 06/02/22 22:32:05
6/04/22 11:04:58 dataLog: datalog WDT - restarting
6/03/22 23:04:58z Real Time Clock is running. Unix time 1654297498
6/03/22 23:04:58z Reset reason: Software/System restart
6/03/22 23:04:58z Trace: 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:2, 1:2, 1:3, 1:3, 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
6/03/22 23:04:58z ESP8266 ID: 188399, RTC PCF8523 (68)
6/03/22 23:04:58z IoTaWatt 4.x, Firmware version 02_07_05
6/03/22 23:04:58z SPIFFS mounted.
6/04/22 11:04:58 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 11:04:58 device name: IotaWatt
6/04/22 11:04:58 HTTP server started
6/04/22 11:04:58 emoncms: Starting, interval:5, url:http://emoncms.org
6/04/22 01:49:59z Real Time Clock is running. Unix time 1654307399
6/04/22 01:49:59z Reset reason: Exception
6/04/22 01:49:59z Trace: 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[2], 10:17, 10:17, 10:18, 31:110, 31:110, 10:23, 10:17
6/04/22 01:49:59z ESP8266 ID: 188399, RTC PCF8523 (68)
6/04/22 01:49:59z IoTaWatt 4.x, Firmware version 02_07_05
6/04/22 01:49:59z SPIFFS mounted.
6/04/22 13:49:59 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 13:49:59 device name: IotaWatt
6/04/22 13:49:59 HTTP server started
6/04/22 13:49:59 emoncms: Starting, interval:5, url:http://emoncms.org
6/04/22 13:49:59 timeSync: service started.
6/04/22 13:50:00 statService: started.
6/04/22 13:50:02 dataLog: service started.
6/04/22 13:50:04 dataLog: Last log entry 06/04/22 10:59:55
6/04/22 01:50:05z Real Time Clock is running. Unix time 1654307405
6/04/22 01:50:05z Reset reason: Exception
6/04/22 01:50:05z Trace: 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[2], 10:17, 10:17, 10:18, 31:110, 31:110, 10:23, 10:17
6/04/22 01:50:05z ESP8266 ID: 188399, RTC PCF8523 (68)
6/04/22 01:50:05z IoTaWatt 4.x, Firmware version 02_07_05
6/04/22 01:50:05z SPIFFS mounted.
6/04/22 13:50:05 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 13:50:05 device name: IotaWatt
6/04/22 13:50:05 HTTP server started
6/04/22 13:50:05 emoncms: Starting, interval:5, url:http://emoncms.org
6/04/22 13:50:05 timeSync: service started.
6/04/22 13:50:06 statService: started.
6/04/22 13:50:14 Restart command received.
6/04/22 01:50:15z Real Time Clock is running. Unix time 1654307415
6/04/22 01:50:15z Reset reason: Software/System restart
6/04/22 01:50:15z Trace: 1:3, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
6/04/22 01:50:15z ESP8266 ID: 188399, RTC PCF8523 (68)
6/04/22 01:50:15z IoTaWatt 4.x, Firmware version 02_07_05
6/04/22 01:50:15z SPIFFS mounted.
6/04/22 13:50:15 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 13:50:15 device name: IotaWatt
6/04/22 13:50:15 HTTP server started
6/04/22 01:50:45z Real Time Clock is running. Unix time 1654307445
6/04/22 01:50:45z Reset reason: Exception
6/04/22 01:50:45z Trace: 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[2], 10:17, 10:17, 10:18, 31:110, 31:110, 10:23, 10:17
6/04/22 01:50:45z ESP8266 ID: 188399, RTC PCF8523 (68)
6/04/22 01:50:45z IoTaWatt 4.x, Firmware version 02_07_05
6/04/22 01:50:45z SPIFFS mounted.
6/04/22 13:50:45 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 13:50:45 device name: IotaWatt
6/04/22 13:50:45 HTTP server started
6/04/22 01:51:47z Real Time Clock is running. Unix time 1654307507
6/04/22 01:51:47z Reset reason: Exception
6/04/22 01:51:47z Trace: 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[2], 10:17, 10:17, 10:18, 31:110, 31:110, 10:23, 10:17
6/04/22 01:51:47z ESP8266 ID: 188399, RTC PCF8523 (68)
6/04/22 01:51:47z IoTaWatt 4.x, Firmware version 02_07_05
6/04/22 01:51:47z SPIFFS mounted.
6/04/22 13:51:47 Local time zone: +12:00, using DST/BST when in effect.
6/04/22 13:51:47 device name: IotaWatt
6/04/22 13:51:47 HTTP server started
Any pointers would be awesome.
