I had my SD card fail and have uploaded the GitHub files. The unit is working ok but when I try loading my old config file config+1.txt (3.7 KB) I am having errors on lines 168,178,188, 228.
All these lines except 188 had a “ | “ at the end so I tried removing but that did not help.
178 and 188 are the same formula and 168 and 228 are the same formula so I tried deleting one of each which also didn’t help.
I then tried deleting the remaining and I’m still not successful in updating just getting the log errors
1/10/26 13:24:58z Config file parse failed.
1/10/26 13:24:58z Config update failed.
Can I just load this straight to the config file on the SD card? Or is this going to cause issues.
