Bob, Sorry but me again - more issues - now getting on the main page (of my older IOTAWATT)
Configuration not Found
The sequence was that the unit was non-responsive to any menu commands so i had to pull the plug - when it restarted i can attach to it etc.
But can not change any menu options etc
Log files (all that is on there) below
When I tried to change an input etc it will not let me
Can i just create a blank config in file manager and start over (i was going to do just that anyway)
12/19/20 12:40:08 influxDB: started, url=HTTP://172.16.100.37:8086, db=iotawattsb, interval=10
12/19/20 12:40:08 WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=7, RSSI -87db
12/19/20 12:40:08 MDNS responder started for hostname IotaWatt
12/19/20 12:40:08 LLMNR responder started for hostname IotaWatt
12/19/20 12:40:08 Updater: service started. Auto-update class is MINOR
12/19/20 12:40:10 EmonService: Start posting at 12/19/20 12:01:10
12/19/20 12:40:11 Updater: Auto-update is current for class MINOR.
12/19/20 12:40:12 influxDB: Start posting at 12/19/20 11:54:40
12/19/20 01:40:30z Real Time Clock is running. Unix time 1608342030
12/19/20 01:40:30z Reset reason: Exception
12/19/20 01:40:30z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:6, 3:6, 3:6, 3:6, 3:6, 3:6, 1:6, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:13
12/19/20 01:40:30z ESP8266 ChipID: 6346788
12/19/20 01:40:30z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 01:40:30z SPIFFS mounted.
12/19/20 12:40:30 Local time zone: +10:00
12/19/20 12:40:30 Using Daylight Saving Time (BST) when in effect.
12/19/20 12:40:30 device name: IotaWatt
12/19/20 12:40:30 HTTP server started
12/19/20 12:40:30 timeSync: service started.
12/19/20 12:40:30 statService: started.
12/19/20 12:40:30 dataLog: service started.
12/19/20 12:40:31 dataLog: Last log entry 12/19/20 12:40:25
12/19/20 12:40:34 WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=7, RSSI -89db
12/19/20 12:40:34 MDNS responder started for hostname IotaWatt
12/19/20 12:40:34 LLMNR responder started for hostname IotaWatt
12/19/20 12:40:34 Updater: service started. Auto-update class is MINOR
12/19/20 12:40:35 EmonService: started. url=HTTP://172.16.100.20/emoncms, node=IotaWatt, interval=10
12/19/20 12:40:35 influxDB: started, url=HTTP://172.16.100.37:8086, db=iotawattsb, interval=10
12/19/20 12:40:35 Updater: Auto-update is current for class MINOR.
12/19/20 12:40:35 influxDB: Start posting at 12/19/20 12:01:40
12/19/20 12:40:36 EmonService: Start posting at 12/19/20 12:07:40
12/19/20 12:41:30 historyLog: service started.
12/19/20 12:41:30 historyLog: Last log entry 12/19/20 12:40:00
12/19/20 01:43:45z Real Time Clock is running. Unix time 1608342225
12/19/20 01:43:45z Power failure detected.
12/19/20 01:43:45z Reset reason: External System
12/19/20 01:43:45z ESP8266 ChipID: 6346788
12/19/20 01:43:45z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 01:43:45z SPIFFS mounted.
12/19/20 12:43:45 Local time zone: +10:00
12/19/20 12:43:45 Using Daylight Saving Time (BST) when in effect.
12/19/20 12:43:45 device name: IotaWatt
12/19/20 12:43:48 HTTP server started
12/19/20 12:43:48 WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=7, RSSI -83db
12/19/20 12:43:48 MDNS responder started for hostname IotaWatt
12/19/20 12:43:48 LLMNR responder started for hostname IotaWatt
12/19/20 12:43:48 timeSync: service started.
12/19/20 12:43:48 statService: started.
12/19/20 12:43:48 Updater: service started. Auto-update class is MINOR
12/19/20 12:43:49 dataLog: service started.
12/19/20 12:43:49 dataLog: Last log entry 12/19/20 12:43:40
12/19/20 12:43:50 Updater: Auto-update is current for class MINOR.
12/19/20 12:43:53 EmonService: started. url=HTTP://172.16.100.20/emoncms, node=IotaWatt, interval=10
12/19/20 12:43:53 influxDB: started, url=HTTP://172.16.100.37:8086, db=iotawattsb, interval=10
12/19/20 12:43:53 influxDB: Start posting at 12/19/20 12:43:40
12/19/20 12:43:54 EmonService: Start posting at 12/19/20 12:43:50
12/19/20 12:44:49 historyLog: service started.
12/19/20 12:44:49 historyLog: Last log entry 12/19/20 12:43:00
12/19/20 15:29:50 Heap memory has degraded below safe minimum, restarting.
12/19/20 04:29:51z Real Time Clock is running. Unix time 1608352191
12/19/20 04:29:51z Reset reason: Software/System restart
12/19/20 04:29:51z Trace: 9:9, 1:2, 1:3, 1:4, 1:5[3], 3:0, 3:11, 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:1[3], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[21], 21:0, 21:1, 21:10, 21:10
12/19/20 04:29:51z ESP8266 ChipID: 6346788
12/19/20 04:29:51z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 04:29:51z SPIFFS mounted.
12/19/20 15:29:51 Local time zone: +10:00
12/19/20 15:29:51 Using Daylight Saving Time (BST) when in effect.
12/19/20 15:29:51 device name: IotaWatt
12/19/20 15:29:51 HTTP server started
12/19/20 15:29:51 timeSync: service started.
12/19/20 15:29:51 statService: started.
12/19/20 15:29:51 dataLog: service started.
12/19/20 15:29:52 dataLog: Last log entry 12/19/20 15:29:50
12/19/20 15:29:56 EmonService: started. url=HTTP://172.16.100.20/emoncms, node=IotaWatt, interval=10
12/19/20 15:29:56 influxDB: started, url=HTTP://172.16.100.37:8086, db=iotawattsb, interval=10
12/19/20 15:29:57 WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=1, RSSI -70db
12/19/20 15:29:57 MDNS responder started for hostname IotaWatt
12/19/20 15:29:57 LLMNR responder started for hostname IotaWatt
12/19/20 15:29:57 Updater: service started. Auto-update class is MINOR
12/19/20 15:29:57 influxDB: Start posting at 12/19/20 15:29:00
12/19/20 15:29:58 EmonService: Start posting at 12/19/20 15:28:50
12/19/20 15:29:59 Updater: Auto-update is current for class MINOR.
12/19/20 15:30:51 historyLog: service started.
12/19/20 15:30:51 historyLog: Last log entry 12/19/20 15:29:00
12/19/20 04:35:16z Real Time Clock is running. Unix time 1608352516
12/19/20 04:35:16z Power failure detected.
12/19/20 04:35:16z Reset reason: External System
12/19/20 04:35:16z ESP8266 ChipID: 6346788
12/19/20 04:35:16z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 04:35:16z SPIFFS mounted.
12/19/20 15:35:16 Local time zone: +10:00
12/19/20 15:35:16 Using Daylight Saving Time (BST) when in effect.
12/19/20 15:35:16 device name: IotaWatt
12/19/20 15:35:19 Connecting with WiFiManager.
12/19/20 15:35:24 HTTP server started
12/19/20 15:35:24 WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=1, RSSI -67db
12/19/20 15:35:24 MDNS responder started for hostname IotaWatt
12/19/20 15:35:24 LLMNR responder started for hostname IotaWatt
12/19/20 15:35:24 timeSync: service started.
12/19/20 15:35:24 statService: started.
12/19/20 15:35:24 Updater: service started. Auto-update class is MINOR
12/19/20 15:35:24 dataLog: service started.
12/19/20 15:35:24 dataLog: Last log entry 12/19/20 15:35:10
12/19/20 15:35:25 Updater: Auto-update is current for class MINOR.
12/19/20 15:35:29 EmonService: started. url=HTTP://172.16.100.20/emoncms, node=IotaWatt, interval=10
12/19/20 15:35:29 influxDB: started, url=HTTP://172.16.100.37:8086, db=iotawattsb, interval=10
12/19/20 15:35:29 influxDB: Start posting at 12/19/20 15:35:00
12/19/20 15:35:30 EmonService: Start posting at 12/19/20 15:35:20
12/19/20 15:36:24 historyLog: service started.
12/19/20 15:36:24 historyLog: Last log entry 12/19/20 15:35:00
12/19/20 04:39:47z Real Time Clock is running. Unix time 1608352787
12/19/20 04:39:47z Power failure detected.
12/19/20 04:39:47z Reset reason: External System
12/19/20 04:39:47z ESP8266 ChipID: 6346788
12/19/20 04:39:47z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 04:39:47z SPIFFS mounted.
12/19/20 04:39:47z Config file open failed.
12/19/20 04:39:47z Local time zone: +0:00
12/19/20 04:39:47z device name: IotaWatt
12/19/20 04:39:50z HTTP server started
12/19/20 04:39:50z WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=1, RSSI -63db
12/19/20 04:39:50z MDNS responder started for hostname IotaWatt
12/19/20 04:39:50z LLMNR responder started for hostname IotaWatt
12/19/20 04:39:50z timeSync: service started.
12/19/20 04:39:50z statService: started.
12/19/20 04:39:50z Updater: service started. Auto-update class is NONE
12/19/20 04:39:56z Real Time Clock is running. Unix time 1608352796
12/19/20 04:39:56z Reset reason: Exception
12/19/20 04:39:56z Trace: 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16
12/19/20 04:39:56z ESP8266 ChipID: 6346788
12/19/20 04:39:56z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 04:39:56z SPIFFS mounted.
12/19/20 04:39:56z Config file open failed.
12/19/20 04:39:56z Local time zone: +0:00
12/19/20 04:39:56z device name: IotaWatt
12/19/20 04:39:56z HTTP server started
12/19/20 04:39:56z timeSync: service started.
12/19/20 04:39:56z statService: started.
12/19/20 04:40:00z WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=1, RSSI -67db
12/19/20 04:40:00z MDNS responder started for hostname IotaWatt
12/19/20 04:40:00z LLMNR responder started for hostname IotaWatt
12/19/20 04:40:00z Updater: service started. Auto-update class is NONE
12/19/20 04:43:30z Real Time Clock is running. Unix time 1608353010
12/19/20 04:43:30z Power failure detected.
12/19/20 04:43:30z Reset reason: External System
12/19/20 04:43:30z ESP8266 ChipID: 6346788
12/19/20 04:43:30z IoTaWatt 5.0, Firmware version 02_05_11
12/19/20 04:43:30z SPIFFS mounted.
12/19/20 04:43:30z Config file open failed.
12/19/20 04:43:30z Local time zone: +0:00
12/19/20 04:43:30z device name: IotaWatt
12/19/20 04:43:33z HTTP server started
12/19/20 04:43:33z WiFi connected. SSID=CURTIN-G, IP=172.16.100.200, channel=1, RSSI -71db
12/19/20 04:43:33z MDNS responder started for hostname IotaWatt
12/19/20 04:43:33z LLMNR responder started for hostname IotaWatt
12/19/20 04:43:33z timeSync: service started.
12/19/20 04:43:33z statService: started.
12/19/20 04:43:33z Updater: service started. Auto-update class is NONE
Craig
