I noticed yesterday that my unit continually reboots about every 30 seconds. I recently purchased and installed this unit about a month ago and didn’t have any issues until sometime recently. The update is set to “minor” and I am running version 02_07_05. I am not use any server uploaders. I am pulling data from Iotawatt into Home Assistant.
1/25/22 13:06:55z Real Time Clock is running. Unix time 1643116015
1/25/22 13:06:55z Reset reason: Software Watchdog
1/25/22 13:06:55z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[5], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 25:18, 25:19
1/25/22 13:06:55z ESP8266 ID: 430435, RTC M41T81 (68)
1/25/22 13:06:55z IoTaWatt 5.0, Firmware version 02_07_05
1/25/22 13:06:55z SPIFFS mounted.
1/25/22 08:06:55 Local time zone: -5:00, using DST/BST when in effect.
1/25/22 08:06:55 device name: IotaWatt
1/25/22 08:06:55 HTTP server started
1/25/22 08:06:55 timeSync: service started.
1/25/22 08:06:55 statService: started.
1/25/22 08:06:55 dataLog: service started.
1/25/22 08:06:55 dataLog: Last log entry 01/25/22 08:06:50
1/25/22 08:06:59 WiFi connected. SSID=wifi_ap, IP=192.168.1.36, channel=11, RSSI -66db
1/25/22 08:06:59 MDNS responder started for hostname IotaWatt
1/25/22 08:06:59 LLMNR responder started for hostname IotaWatt
1/25/22 08:06:59 Updater: service started. Auto-update class is MINOR
1/25/22 08:07:00 historyLog: service started.
1/25/22 08:07:00 historyLog: Last log entry 01/25/22 08:06:00
1/25/22 08:07:00 Updater: Auto-update is current for class MINOR.
1/25/22 13:07:31z Real Time Clock is running. Unix time 1643116051
1/25/22 13:07:31z Reset reason: Software Watchdog
1/25/22 13:07:31z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[5], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 25:18, 25:19
1/25/22 13:07:31z ESP8266 ID: 430435, RTC M41T81 (68)
1/25/22 13:07:31z IoTaWatt 5.0, Firmware version 02_07_05
1/25/22 13:07:31z SPIFFS mounted.
1/25/22 08:07:31 Local time zone: -5:00, using DST/BST when in effect.
1/25/22 08:07:31 device name: IotaWatt
1/25/22 08:07:31 HTTP server started
1/25/22 08:07:31 timeSync: service started.
1/25/22 08:07:31 statService: started.
1/25/22 08:07:31 dataLog: service started.
1/25/22 08:07:32 dataLog: Last log entry 01/25/22 08:07:25
1/25/22 08:07:35 WiFi connected. SSID=wifi_ap, IP=192.168.1.36, channel=11, RSSI -67db
1/25/22 08:07:35 MDNS responder started for hostname IotaWatt
1/25/22 08:07:35 LLMNR responder started for hostname IotaWatt
1/25/22 08:07:35 Updater: service started. Auto-update class is MINOR
1/25/22 08:07:36 historyLog: service started.
1/25/22 08:07:36 historyLog: Last log entry 01/25/22 08:07:00
1/25/22 08:07:36 Updater: Auto-update is current for class MINOR.
