Hi,
In the CT basics section of the documentation it says:
So without connecting anything directly to any high-voltage wiring, it’s possible to get a scaled down measure of the primary current that can be used to passively measure power (Watts) of a circuit.
I’m not 100% sure what is meant by that and it’s left me with a few questions:
What is meant by “scaled down measure”?
Are all readings displayed on the IOTAWatt scaled down?
Do the readings need to be multiplied by a certain amount in order to show the true value?
Is this only true for when the current goes above a certain level? ie. scaled down for anything >100A
