Hi! I’d like to use the inputs #13 and #14 on my IotaWatt v6.
I can’t get sensible results. What am I doing wrong?
As a test, I’ve rigged up:
- Known ~500W load, PF ~0.90
- 100A CT on input 2
- 50A CT on input 14
- VT on input 0
Input 14 has the following wiring
- tip of 3.5mm CT is connected to inner of barrel jack
- sleeve of 3.5mm CT is connected to outer of the barrel jack
Configuration is
- Single phase, selected ECS1050 and ECS16100 (see config.txt below)
Results (see image)
- CT100A reads ok (input #2)
- CT50A (input #14) is wrong
- They are on the same active so should read the same
I’ve tried a few things:
- tried input 13
- reverse wiring (goes negative as expected)
- confirmed CT on input #14 reads ok if plugged into inputs 1-14
- checked burdens are correct (no changes required)
- checked log (nothing untoward)
- tried derived 3 phase and different phase angles as PF is low (no luck).
- different VT
The config.txt is copied below:
"format": 2,
"timezone": 0,
"update": "MINOR",
"device": {
"name": "IotaWatt",
"version": 3,
"channels": "15",
"burden": [
0,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20
"inputs": [
"channel": 0,
"name": "Input_0",
"type": "VT",
"model": "generic",
"phase": "3.6",
"cal": "16",
"vphase": 0,
"vmult": 1
null,
"channel": 2,
"name": "CT100A",
"type": "CT",
"model": "ECS16100",
"phase": 0.6,
"turns": 2000,
"signed": true,
"cal": 100,
"vphase": 0,
"vmult": 1
null,
null,
null,
null,
null,
null,
null,
null,
null,
null,
null,
"channel": 14,
"name": "CT50A",
"type": "CT",
"model": "ECS1050",
"phase": 1.6,
"turns": 1000,
"signed": true,
"cal": "50.00",
"vmult": 1
"outputs": [],
"derive3ph": true
