Hi Bob, from my IotaWatt the current log was apparently damaged. It deleted the current log file and created a diagnostic file. Thank you for the IotaWatt’s ability to free itself from such a situation. However, I would like to know what could have led to this problem. Can you see a hint why the log could be damaged?
iotalog:
3/19/19 05:03:13z Real Time Clock is running. Unix time 1552971793
3/19/19 05:03:13z Reset reason: Software/System restart
3/19/19 05:03:13z Trace: 1:3, 1:4, 1:5[20], 20:0, 20:1, 20:2, 20:3, 20:4, 20:42, 1:6, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:4, 1:5[20], 20:0, 20:1, 20:2, 20:3, 20:4, 20:42, 1:6, 1:3, 1:4, 1:5[21]
3/19/19 05:03:13z ESP8266 ChipID: 7283597
3/19/19 05:03:13z IoTaWatt 4.x, Firmware version 02_04_00
3/19/19 05:03:13z SPIFFS mounted.
3/19/19 05:03:14z Local time zone: +0:00
3/19/19 05:03:15z device name: IotaWatt
3/19/19 05:03:15z MDNS responder started for hostname IotaWatt
3/19/19 05:03:15z LLMNR responder started for hostname IotaWatt
3/19/19 05:03:15z HTTP server started
3/19/19 05:03:15z timeSync: service started.
3/19/19 05:03:15z statService: started.
3/19/19 05:03:15z dataLog: service started.
3/19/19 05:03:16z dataLog: Last log entry 03/19/19 05:03:10
3/19/19 05:03:17z historyLog: service started.
3/19/19 05:03:18z historyLog: Last log entry 03/19/19 05:03:00
3/19/19 05:03:20z EmonService: started. url=my.rexometer.de:80, node=IotaWatt, interval=10, encrypted
3/19/19 05:03:20z influxDB: started, url=192.168.11.76:8086, db=iotawatt, interval=10
3/19/19 05:40:19z WiFi connected. SSID=rexoweb, IP=192.168.11.117, channel=6, RSSI -78db
3/19/19 05:40:19z Updater: service started. Auto-update class is ALPHA
3/19/19 05:40:19z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:40:22z Updater: Auto-update is current for class ALPHA.
3/19/19 05:40:23z EmonService: Start posting at 03/18/19 21:02:20
3/19/19 05:40:30z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:40:41z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:40:52z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:02z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:14z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:24z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:35z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:46z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:41:56z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:42:07z timesync: Kiss-o'-Death, code RATE, ip: 37.120.164.45
3/19/19 05:42:08z influxDB: last entry query failed: -4, retrying.
4/13/19 09:12:59z EmonService: HTTP response 502, retrying.
4/13/19 09:13:17z EmonService: Retry successful after 35 attempts.
4/21/19 21:25:17z influxDB: Start posting at 01/11/19 04:22:00
4/30/19 05:42:52z timeSync: Six week routine restart.
4/30/19 05:42:53z Real Time Clock is running. Unix time 1556602973
4/30/19 05:42:53z Reset reason: Software/System restart
4/30/19 05:42:53z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:5[20], 20:0, 20:1
4/30/19 05:42:53z ESP8266 ChipID: 7283597
4/30/19 05:42:53z IoTaWatt 4.x, Firmware version 02_04_00
4/30/19 05:42:53z SPIFFS mounted.
4/30/19 05:42:54z Local time zone: +0:00
4/30/19 05:42:55z device name: IotaWatt
4/30/19 05:42:55z MDNS responder started for hostname IotaWatt
4/30/19 05:42:55z LLMNR responder started for hostname IotaWatt
4/30/19 05:42:55z HTTP server started
4/30/19 05:42:55z WiFi connected. SSID=rexoweb, IP=192.168.11.117, channel=6, RSSI -72db
4/30/19 05:42:55z timeSync: service started.
4/30/19 05:42:55z statService: started.
4/30/19 05:42:55z Updater: service started. Auto-update class is ALPHA
4/30/19 05:42:55z dataLog: service started.
4/30/19 05:42:56z dataLog: Last log entry 04/30/19 05:42:50
4/30/19 05:42:57z historyLog: service started.
4/30/19 05:42:58z historyLog: Last log entry 04/30/19 05:42:00
4/30/19 05:42:59z Updater: Auto-update is current for class ALPHA.
4/30/19 05:43:00z EmonService: started. url=my.rexometer.de:80, node=IotaWatt, interval=10, encrypted
4/30/19 05:43:00z influxDB: started, url=192.168.11.76:8086, db=iotawatt, interval=10
4/30/19 05:43:01z influxDB: Start posting at 04/30/19 05:43:00
4/30/19 05:43:01z EmonService: Start posting at 04/30/19 05:42:50
5/01/19 19:46:47z Updater: Invalid response from server. HTTPcode: 301
5/15/19 13:19:58z Updater: Invalid response from server. HTTPcode: -11
5/16/19 04:05:39z influxDB: Post Failed: -11
5/20/19 22:17:04z Real Time Clock is running. Unix time 1558390624
5/20/19 22:17:04z Reset reason: Software Watchdog
5/20/19 22:17:04z Trace: 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:3, 1:4, 1:5[7], 7:0, 7:7, 7:7
5/20/19 22:17:04z ESP8266 ChipID: 7283597
5/20/19 22:17:04z IoTaWatt 4.x, Firmware version 02_04_00
5/20/19 22:17:04z SPIFFS mounted.
5/20/19 22:17:05z Local time zone: +0:00
5/20/19 22:17:05z device name: IotaWatt
5/20/19 22:17:06z MDNS responder started for hostname IotaWatt
5/20/19 22:17:06z LLMNR responder started for hostname IotaWatt
5/20/19 22:17:06z HTTP server started
5/20/19 22:17:06z WiFi connected. SSID=rexoweb, IP=192.168.11.117, channel=6, RSSI -73db
5/20/19 22:17:06z timeSync: service started.
5/20/19 22:17:06z statService: started.
5/20/19 22:17:06z Updater: service started. Auto-update class is ALPHA
5/20/19 22:17:07z dataLog: service started.
5/20/19 22:17:09z IotaLog: file damaged iotawatt/iotalog.log
5/20/19 22:17:09z IotaLog: Creating diagnostic file.
5/20/19 23:36:02z IotaLog: Deleting iotawatt/iotalog.log and restarting.
5/20/19 23:36:06z Real Time Clock is running. Unix time 1558395366
5/20/19 23:36:06z Reset reason: Software/System restart
5/20/19 23:36:06z Trace: 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 1:6, 1:1[4], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
5/20/19 23:36:06z ESP8266 ChipID: 7283597
5/20/19 23:36:06z IoTaWatt 4.x, Firmware version 02_04_00
5/20/19 23:36:06z SPIFFS mounted.
5/20/19 23:36:07z Local time zone: +0:00
5/20/19 23:36:07z device name: IotaWatt
5/20/19 23:36:08z MDNS responder started for hostname IotaWatt
5/20/19 23:36:08z LLMNR responder started for hostname IotaWatt
5/20/19 23:36:08z HTTP server started
5/20/19 23:36:08z WiFi connected. SSID=rexoweb, IP=192.168.11.117, channel=6, RSSI -75db
5/20/19 23:36:08z timeSync: service started.
5/20/19 23:36:08z statService: started.
5/20/19 23:36:08z Updater: service started. Auto-update class is ALPHA
5/20/19 23:36:09z dataLog: service started.
5/20/19 23:36:09z dataLog: New current log created.
5/20/19 23:36:10z dataLog: Last history entry: 05/20/19 22:16:00
5/20/19 23:36:11z Updater: Auto-update is current for class ALPHA.
5/20/19 23:36:13z EmonService: started. url=my.rexometer.de:80, node=IotaWatt, interval=10, encrypted
5/20/19 23:36:13z influxDB: started, url=192.168.11.76:8086, db=iotawatt, interval=10
5/20/19 23:36:14z EmonService: Start posting at 01/01/70 00:00:10
5/20/19 23:36:14z influxDB: Start posting at 05/20/19 22:16:00
5/20/19 23:38:10z historyLog: service started.
5/20/19 23:38:10z historyLog: Last log entry 05/20/19 22:16:00
5/22/19 00:38:55z Updater: Invalid response from server. HTTPcode: -11
logdiag.txt
5/20/19 22:17:09
filesize 1614643200, entries 6307200
1558098100,6307200,1558390610,6365702
1529611350,610313,1529611350,610313
1524815910,58504,1524860105,67343
1524925710,67344,1524930980,68398
1526901780,68399,1547978930,4283829
1547981250,4283830,1558098095,6307199
End of file
