Hi Bob!
I’m configuring a newish unit (Model W14 v5). It connects and runs ok (i.e. I see the http interface), but I see two problems:
- Message logs about “dataLog: datalog WDT - restarting”.
- More importantly, startup messages stop after “HTTP server started”.
For problem #1, I tried and “deletelog” command.
For problem #2, I note that, as expected, some services are not started: no data uploader and no MDNS.
Other info: Release is set to MINOR. I had an identical problem with another unit I’m configuring.
How should I proceed? Your help is appreciated! Cheers, Brett
11/22/21 19:39:35z timeSync: service started.
11/22/21 19:39:35z statService: started.
11/22/21 19:39:35z Updater: service started. Auto-update class is MINOR
11/22/21 19:39:35z dataLog: service started.
11/22/21 19:39:35z dataLog: Last log entry 11/22/21 18:23:00
11/22/21 19:39:35z historyLog: service started.
11/22/21 19:39:35z historyLog: Last log entry 11/22/21 18:23:00
11/22/21 19:39:37z Updater: Auto-update is current for class MINOR.
11/22/21 20:56:10z dataLog: datalog WDT - restarting** Restart **
11/22/21 20:56:11z Real Time Clock is running. Unix time 1637614571
11/22/21 20:56:11z Reset reason: Software/System restart
11/22/21 20:56:11z Trace: 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2
11/22/21 20:56:11z ESP8266 ID: 4307075, RTC PCF8523
11/22/21 20:56:11z IoTaWatt 5.0, Firmware version 02_06_06
11/22/21 20:56:11z SPIFFS mounted.
11/22/21 20:56:11z Local time zone: +0:00
11/22/21 20:56:11z device name: IotaWatt
11/22/21 20:56:11z HTTP server started
11/22/21 22:07:45z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -62db
11/22/21 22:07:45z MDNS responder started for hostname IotaWatt
11/22/21 22:07:45z LLMNR responder started for hostname IotaWatt
11/22/21 22:07:45z timeSync: service started.
11/22/21 22:07:45z statService: started.
11/22/21 22:07:45z Updater: service started. Auto-update class is MINOR
11/22/21 22:07:45z dataLog: service started.
11/22/21 22:07:45z dataLog: Last log entry 11/22/21 20:51:10
11/22/21 22:07:45z historyLog: service started.
11/22/21 22:07:45z historyLog: Last log entry 11/22/21 20:51:00
11/22/21 23:24:22z dataLog: datalog WDT - restarting** Restart **
11/22/21 23:24:24z Real Time Clock is running. Unix time 1637623464
11/22/21 23:24:24z Reset reason: Software/System restart
11/22/21 23:24:24z Trace: 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 8:4, 8:2, 8:2, 1:2
11/22/21 23:24:24z ESP8266 ID: 4307075, RTC PCF8523
11/22/21 23:24:24z IoTaWatt 5.0, Firmware version 02_06_06
11/22/21 23:24:24z SPIFFS mounted.
11/22/21 23:24:24z Local time zone: +0:00
11/22/21 23:24:24z device name: IotaWatt
11/22/21 23:24:24z HTTP server started
11/22/21 23:24:24z timeSync: service started.
11/23/21 00:35:58z statService: started.
11/23/21 00:35:58z Updater: service started. Auto-update class is MINOR
11/23/21 00:35:58z dataLog: service started.
11/23/21 00:35:58z dataLog: Last log entry 11/22/21 22:19:05
11/23/21 00:35:58z historyLog: service started.
11/23/21 00:35:58z historyLog: Last log entry 11/22/21 20:51:00
11/23/21 00:35:58z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -58db
11/23/21 00:35:58z MDNS responder started for hostname IotaWatt
11/23/21 00:35:58z LLMNR responder started for hostname IotaWatt
11/23/21 00:41:00z dataLog: datalog WDT - restarting** Restart **
11/23/21 00:41:01z Real Time Clock is running. Unix time 1637628061
11/23/21 00:41:01z Reset reason: Software/System restart
11/23/21 00:41:01z Trace: 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2
11/23/21 00:41:01z ESP8266 ID: 4307075, RTC PCF8523
11/23/21 00:41:01z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 00:41:01z SPIFFS mounted.
11/23/21 00:41:01z Local time zone: +0:00
11/23/21 00:41:01z device name: IotaWatt
11/23/21 00:41:01z HTTP server started
11/23/21 01:52:35z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -58db
11/23/21 01:52:35z MDNS responder started for hostname IotaWatt
11/23/21 01:52:35z LLMNR responder started for hostname IotaWatt
11/23/21 01:52:35z timeSync: service started.
11/23/21 01:52:35z statService: started.
11/23/21 01:52:35z Updater: service started. Auto-update class is MINOR
11/23/21 01:52:35z dataLog: service started.
11/23/21 01:52:36z dataLog: Last log entry 11/23/21 00:36:00
11/23/21 01:52:36z historyLog: service started.
11/23/21 01:52:36z historyLog: Last log entry 11/23/21 00:36:00
11/23/21 03:09:12z dataLog: datalog WDT - restarting** Restart **
11/23/21 03:09:13z Real Time Clock is running. Unix time 1637636953
11/23/21 03:09:13z Reset reason: Software/System restart
11/23/21 03:09:13z Trace: 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:2, 8:2, 1:2
11/23/21 03:09:13z ESP8266 ID: 4307075, RTC PCF8523
11/23/21 03:09:13z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 03:09:13z SPIFFS mounted.
11/23/21 03:09:13z Local time zone: +0:00
11/23/21 03:09:13z device name: IotaWatt
11/23/21 03:09:13z HTTP server started
11/23/21 03:09:13z timeSync: service started.
11/23/21 04:20:47z statService: started.
11/23/21 04:20:47z Updater: service started. Auto-update class is MINOR
11/23/21 04:20:47z dataLog: service started.
11/23/21 04:20:47z dataLog: Last log entry 11/23/21 02:00:05
11/23/21 04:20:47z historyLog: service started.
11/23/21 04:20:47z historyLog: Last log entry 11/23/21 00:36:00
11/23/21 04:20:47z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -59db
11/23/21 04:20:47z MDNS responder started for hostname IotaWatt
11/23/21 04:20:47z LLMNR responder started for hostname IotaWatt
11/23/21 05:37:22z dataLog: datalog WDT - restarting** Restart **
11/23/21 05:37:23z Real Time Clock is running. Unix time 1637645843
11/23/21 05:37:23z Reset reason: Software/System restart
11/23/21 05:37:23z Trace: 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3
11/23/21 05:37:23z ESP8266 ID: 4307075, RTC PCF8523
11/23/21 05:37:23z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 05:37:23z SPIFFS mounted.
11/23/21 05:37:23z Local time zone: +0:00
11/23/21 05:37:23z device name: IotaWatt
11/23/21 05:37:23z HTTP server started
11/23/21 06:48:57z timeSync: service started.
11/23/21 06:48:57z statService: started.
11/23/21 06:48:57z Updater: service started. Auto-update class is MINOR
11/23/21 06:48:57z dataLog: service started.
11/23/21 06:48:57z dataLog: Last log entry 11/23/21 04:21:25
11/23/21 06:48:57z historyLog: service started.
11/23/21 06:48:58z historyLog: Last log entry 11/23/21 02:00:00
11/23/21 06:48:58z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -60db
11/23/21 06:48:58z MDNS responder started for hostname IotaWatt
11/23/21 06:48:58z LLMNR responder started for hostname IotaWatt
11/23/21 06:49:00z Updater: Auto-update is current for class MINOR.
11/23/21 06:54:00z dataLog: datalog WDT - restarting** Restart **
11/23/21 06:54:01z Real Time Clock is running. Unix time 1637650441
11/23/21 06:54:01z Reset reason: Software/System restart
11/23/21 06:54:01z Trace: 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:2, 8:2, 1:2
11/23/21 06:54:01z ESP8266 ID: 4307075, RTC PCF8523
11/23/21 06:54:01z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 06:54:01z SPIFFS mounted.
11/23/21 06:54:01z Local time zone: +0:00
11/23/21 06:54:01z device name: IotaWatt
11/23/21 06:54:01z HTTP server started
11/23/21 08:05:35z WiFi connected. SSID=NetComm 0405, IP=192.168.0.21, channel=11, RSSI -65db
11/23/21 08:05:35z MDNS responder started for hostname IotaWatt
11/23/21 08:05:35z LLMNR responder started for hostname IotaWatt
11/23/21 08:05:35z timeSync: service started.
11/23/21 08:05:35z statService: started.
11/23/21 08:05:35z Updater: service started. Auto-update class is MINOR
11/23/21 08:05:36z dataLog: service started.
11/23/21 08:05:36z dataLog: Last log entry 11/23/21 06:49:00
11/23/21 08:05:36z historyLog: service started.
11/23/21 08:05:36z historyLog: Last log entry 11/23/21 06:49:00
11/23/21 10:33:44z dataLog: datalog WDT - restarting** Restart **
11/23/21 10:33:45z Real Time Clock is running. Unix time 1637663625
11/23/21 10:33:45z Reset reason: Software/System restart
11/23/21 10:33:45z Trace: 1:2, 9:0, 9:0, 8:2, 8:2, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 8:4, 8:6, 8:8, 8:9, 1:2
11/23/21 10:33:45z ESP8266 ID: 4307075, RTC PCF8523
11/23/21 10:33:45z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 10:33:45z SPIFFS mounted.
11/23/21 10:33:45z Local time zone: +0:00
11/23/21 10:33:45z device name: IotaWatt
11/23/21 10:33:45z HTTP server started
11/23/21 10:33:45z timeSync: service started.
11/23/21 10:33:46z statService: started.** Restart **
1/13/22 21:41:39z Real Time Clock is running. Unix time 1642110099
1/13/22 21:41:39z Reset Reason: Power-fail restart.
1/13/22 21:41:39z ESP8266 ID: 4307075, RTC PCF8523
1/13/22 21:41:39z IoTaWatt 5.0, Firmware version 02_06_06
1/13/22 21:41:39z SPIFFS mounted.
1/13/22 21:41:39z Local time zone: +0:00
1/13/22 21:41:39z device name: IotaWatt
1/13/22 21:41:42z Connecting with WiFiManager.
1/13/22 21:41:45z HTTP server started** Restart **
1/13/22 21:47:57z Real Time Clock is running. Unix time 1642110477
1/13/22 21:47:57z Reset Reason: Power-fail restart.
1/13/22 21:47:57z ESP8266 ID: 4307075, RTC PCF8523
1/13/22 21:47:57z IoTaWatt 5.0, Firmware version 02_06_06
1/13/22 21:47:57z SPIFFS mounted.
1/13/22 21:47:57z Local time zone: +0:00
1/13/22 21:47:57z device name: IotaWatt
1/13/22 21:48:00z Connecting with WiFiManager.
1/13/22 21:48:03z HTTP server started
