Hello,
I’ve finally gotten around to installing my IoTaWatt after it’s sat in its box for 3 years
I’ve replaced the RTC battery assuming it would be dead & have been able to get it on the wi-fi but i am getting a dull red led pulse every 10 sec. i didn’t see anything in the Troubleshooting section about a red pattern like that so figured i’d share my logs & see if anyone had any suggestions. i’m also noticing that i’m receiving an invalid response from the update server: HTTPcode: -4. i’m pretty sure my firmware is out of date as i do follow the weekly digests & see that the project is still quite active. is there a way to manually update the firmware? i have not hooked up any of the CTs yet as i don’t have the green all’s well led light & figured i’d check here first.
thanks for any help or suggestions
here are my logs:
ESP8266 ChipID: 191534
SPIFFS mounted.
Local time zone: 0
device name: IotaWatt, version: 3
Connecting with WiFiManager.** Restart **
Version 02_03_18
Reset reason: External System
Trace: 101:155[102], 129:139[174], 6:60[152], 24:68[170], 41:215[119], 233:106[203], 3:144[1], 79:167[105], 16:140[60], 42:70[33], 94:227[38], 63:16[107], 250:185, 224:184[214], 75:215[144], 67:122[224], 70:165[52], 166:153[196], 99:149[38], 95:8[104], 246:227[213], 91:175[87], 3:137[153], 149:196[74], 191:141[71], 127:240[143], 4:89[108], 241:92[185], 236:73[83], 124:2[187], 138:79[168], 86:230[99]
SPIFFS mounted.
Local time zone: 0
Version 02_03_18
Reset reason: Power on
Trace: 101:159[103], 145:139[110], 6:60[155], 24:64[234], 41:159[247], 233:106[195], 3:144[5], 111:167[233], 16:140[60], 38:68[33], 30:227[38], 63:16[106], 250:185[1], 224:184[214], 203:211[146], 35:90[96], 70:173[54], 134:137[128], 99:145[38], 95:8[200], 246:227[213], 83:167[87], 9:137[153], 213:196[72], 223:141[87], 127:240[135], 12:89[109], 241:124[144], 236:73[83], 124:2[186], 138:79[168], 22:178[99]
SPIFFS mounted.
Local time zone: 0
Version 02_03_18
Trace: 101:157[103], 145:139[46], 6:60[184], 24:64[239], 41:223[119], 232:106[195], 3:128[1], 77:167[235], 16:140[60], 46:70[33], 30:227[38], 63:20[235], 250:185[1], 96:184[150], 75:215[144], 3:88[96], 70:165[116], 134:137[228], 99:145[34], 95:8[236], 246:227[213], 51:183[95], 11:137[153], 209:196[72], 255:141[67], 127:240[133], 12:89[77], 241:92[185], 238:73[83], 60:2[187], 138:79[168], 22:166[99]
SPIFFS mounted.
Local time zone: 0
Version 02_03_18
Trace: 101:153[103], 145:139[46], 7:60[184], 24:68[175], 41:215[119], 233:106[195], 19:144[1], 45:167[233], 16:140[60], 46:68[33], 94:235[38], 47:16[107], 250:185, 224:184[214], 203:223[146], 3:90[96], 70:165[54], 134:137[164], 99:145[34], 95:8[108], 246:227[213], 19:167[87], 11:137[153], 213:196[72], 223:141[87], 123:248[135], 12:89[104], 241:88[152], 238:73[83], 60:2[186], 138:79[168], 22:166[99]
SPIFFS mounted.
Local time zone: 0
HTTP server started
timeSync: service started.
statService: started.
WiFi connected. SSID=IoT, IP=10.10.5.206, channel=3, RSSI -45db
Updater: Invalid response from server. HTTPcode: -4** Restart **
Version 02_03_18
Trace: 101:153[103], 129:143[110], 7:60[154], 24:64[239], 41:219[119], 233:42[195], 3:128[5], 77:167[249], 16:140[60], 42:70[33], 94:235[38], 31:16[234], 250:185[8], 224:184[150], 203:215[154], 3:88[96], 70:173[116], 134:137[128], 99:145[38], 95:8[232], 246:227[213], 19:167[87], 11:137[153], 213:196[74], 87:141[71], 127:248[143], 12:89[76], 241:88[177], 238:73[83], 124:2[186], 139:79[168], 22:230[99]
SPIFFS mounted.
Local time zone: 0
HTTP server started
WiFi connected. SSID=IoT, IP=10.10.5.206, channel=2, RSSI -49db
Restart command received.** Restart **
Version 02_03_18
Reset reason: Software/System restart
Trace: 1:3, 1:4, 1:5[21], 1:6, 1:3, 1:4, 1:5[5], 1:6, 1:3, 1:4, 1:5[20], 20:0, 20:1, 20:2, 20:3, 20:31, 20:32, 20:4, 20:42, 1:6, 1:1, 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 10:2, 10:3
SPIFFS mounted.
Local time zone: 6
HTTP server started
WiFi connected. SSID=IoT, IP=10.10.5.206, channel=7, RSSI -48db
Version 02_03_18
SPIFFS mounted.
Local time zone: 6
HTTP server started
timeSync: No time update in last 24 hours.** Restart **
Version 02_03_18
Trace: 101:159[119], 149:139[46], 6:60[185], 152:100[238], 43:223[119], 233:106[203], 3:128[5], 45:167[235], 16:140[60], 38:68[33], 30:227[38], 59:16[235], 250:185[12], 224:184[150], 203:215[154], 3:90[64], 70:173[54], 134:137[196], 99:145[38], 127:8[200], 230:227[213], 26:167[87], 11:137[153], 213:196[72], 247:141[87], 127:240[135], 13:89[76], 241:124[185], 236:201[83], 60:2[187], 138:79[168], 22:226[99]
SPIFFS mounted.
Local time zone: 6
RTC not running, waiting for WiFi.** Restart **
Version 02_03_18
Trace: 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 15:1, 15:0, 15:1, 11:7, 11:8, 16:0, 11:8, 11:9
SPIFFS mounted.
Local time zone: 6
HTTP server started
WiFi connected. SSID=IoT, IP=10.10.5.206, channel=1, RSSI -48db
