This is unfortunately our life in South Africa there we have power failures.
SO the IOTAWatt connect to a range extender that’s connected to the main router. Now after power failures and not every one I need to restart the IOTAWATT to work. Not sure if it’s the network that isn’t up by the time it boots or what it is. 05h15 was when it started up from the power failure and 07h15 was when I manually restarted. So it doesn’t look like it tried to restart after an hour.
2/10/21 05:15:59z Real Time Clock is running. Unix time 1612934159
2/10/21 05:15:59z Power failure detected.
2/10/21 05:15:59z Reset reason: External System
2/10/21 05:15:59z ESP8266 ChipID: 12676588
2/10/21 05:15:59z IoTaWatt 5.0, Firmware version 02_05_12
2/10/21 05:15:59z SPIFFS mounted.
2/10/21 07:15:59 Local time zone: +2:00
2/10/21 07:15:59 device name: IotaWatt
2/10/21 07:16:02 Connecting with WiFiManager.
2/10/21 07:16:05 HTTP server started
2/10/21 07:16:06 WiFi connected. SSID=bulky@home, IP=192.168.0.136, channel=4, RSSI -86db
2/10/21 07:16:06 MDNS responder started for hostname IotaWatt
2/10/21 07:16:06 LLMNR responder started for hostname IotaWatt
2/10/21 07:16:06 timeSync: service started.
2/10/21 07:16:09 statService: started.
2/10/21 07:16:09 Updater: service started. Auto-update class is BETA
2/10/21 07:16:09 dataLog: service started.
2/10/21 07:16:09 dataLog: Last log entry 02/10/21 02:00:10
2/10/21 07:16:10 EmonService: started. url=HTTP://192.168.0.247/emoncms, node=IotaWatt, interval=10
2/10/21 07:16:10 Updater: Auto-update is current for class BETA.
2/10/21 07:16:11 EmonService: Start posting at 02/04/21 08:10:15
2/10/21 07:17:10 historyLog: service started.
2/10/21 07:17:10 historyLog: Last log entry 02/10/21 02:00:00
Some Info and Firmware version I am running
Thank Rudolph
