Hi all,
Please may you assist me.
I have been successfully posting to the emoncms.org server for a while, but I would like to change this to send to my own server. I have tried to setup the IotaWatt to send to my server, of which I have a number of other devices successfully sending data to, but without success.
Here is the message log from last restart:
5/27/20 13:32:04z Real Time Clock is running. Unix time 1590586324
5/27/20 13:32:04z Reset reason: Software/System restart
5/27/20 13:32:04z Trace: 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 10:2, 10:3
5/27/20 13:32:04z ESP8266 ChipID: 6991482
5/27/20 13:32:04z IoTaWatt 4.x, Firmware version 02_05_02
5/27/20 13:32:04z SPIFFS mounted.
5/27/20 15:32:05 Local time zone: +2:00
5/27/20 15:32:05 device name: IotaWatt
5/27/20 15:32:06 MDNS responder started for hostname IotaWatt
5/27/20 15:32:06 LLMNR responder started for hostname IotaWatt
5/27/20 15:32:06 HTTP server started
5/27/20 15:32:06 WiFi connected. SSID=Inverter room, IP=192.168.1.2, channel=1, RSSI -81db
5/27/20 15:32:06 timeSync: service started.
5/27/20 15:32:07 statService: started.
5/27/20 15:32:07 Updater: service started. Auto-update class is MAJOR
5/27/20 15:32:07 dataLog: service started.
5/27/20 15:32:10 dataLog: Last log entry 05/27/20 15:32:00
5/27/20 15:32:10 historyLog: service started.
5/27/20 15:32:11 historyLog: Last log entry 05/27/20 15:32:00
5/27/20 15:32:11 EmonService: started. url=monitoring.greenhousesolar.co.za:80/emoncms/, node=4, interval=10
5/27/20 15:32:14 Updater: Auto-update is current for class MAJOR.
5/27/20 15:32:31 EmonService: get input list failing, code: 301
End
I have tried http:// and https://.
I have tried removing the user ID.
Any help will be much appreciated.
