Can anyone recommend an outdoor enclosure that I can find in Australia?
I got one I thought would work from Jaycar but it doesn’t quite fit. (Would if the CT claps had 90° connectors). Not sure if they have anything larger.
Would also be good to have some extra space in case I decide to replace with a larger or multiple units in the future.
Can these things run in a IPxx rated enclosure? Wondering about heat in summer.
Alternatively is it possible to swap the RSP8266 module with one that has an external antenna. Sparkie is happy to install it in the main box and there is plenty of room, but I get zero Wifi with this little chip through the metal box. That would avoid all the external cable routing too.
(Guy who installed the smartmeter just drilled a hole and poked through an antenna for the Telstra LTE)
