Enphase Solar Tracking with PVOutput
New user here having a few issues. Overall setup seems pretty straight forward but I seem to be having some issues in Graph+ and PVOutput.
I have feeds from both IoTaWatt and Enphase being sent to PVOutput. Does the Enphase data override the IoTaWatt data for production? I will share photos showing where the data for production changes later in the day.
Do I need to have 2 separate systems in PVOutput or can I use some of the extra paid inputs to track both IoTaWatt and Enphase numbers on the same system?
The Energy used in PVOutput does not seem to be working. Any ideas why?
The solar seems to never drop below 3 watts even when the sun is down even with max 0 in my uploader.
Solar on bottom left breaker. One CT with Doubled checked.
Weird negative spike in the data from IotaWatt in PVOutput. This does not seem to show up on Graph+ or the Enphase data. https://enlighten.enphaseenergy.com/public/systems/fNDA1422112 The spike shown in the picture is now gone from PVO but there are 2 more at later times that I assume with also disappear once the Enphase data updates.
10:45 from IoTaWatt was showing around 12.3 kWh as Enphase was showing 11.3 as the next picture will show. I would expect the IoTaWatt CT to read lower than the Enphase as this is 200 ft from the Envoy installed at the array. My production readings come from the Enphase Production CT’s in the combiner box not the microinverters.
Not showing negative spike in the data.
This is showing how I think Enphase is sending the data later and updating the production numbers.
Any advice would be appreciated in how to get some of the data cleaned up.
Happy to be part of this niche community either way!
I ran this query to see the data.
http://iotawatt.local/query?select=[time,solar_1]&begin=2022-03-25T12:05&end=2022-03-26T15:30&group=5m&format=csv
My peak power in Enphase is 11,300 or so and IoTaWatt is showing a peak of 11,200 so this seems to be correct although I was expecting to see a bit more loss than 1% with a 200 ft run between CT’s. The wires and breaker do get warm during midday full sun. I ran 3 gauge copper about 100 ft from array to house and then 4 gauge romex from cuttoff to main about another 100 ft.
Is there are log of what is sent to PVOutout that I can query as well?
2022-03-25T12:05:00, 0
2022-03-25T12:10:00, 0
2022-03-25T12:15:00, 0
2022-03-25T12:20:00, 0
2022-03-25T12:25:00, 0
2022-03-25T12:30:00, 0
2022-03-25T12:35:00, -578.2
2022-03-25T12:40:00, -3788.4
2022-03-25T12:45:00, -5565.9
2022-03-25T12:50:00, -5573.9
2022-03-25T12:55:00, -4973.3
2022-03-25T13:00:00, -3802.1
2022-03-25T13:05:00, -5565.1
2022-03-25T13:10:00, -5749.1
2022-03-25T13:15:00, -7747.5
2022-03-25T13:20:00, -7269.1
2022-03-25T13:25:00, -7090.3
2022-03-25T13:30:00, -6986.1
2022-03-25T13:35:00, -6535.2
2022-03-25T13:40:00, -6629
2022-03-25T13:45:00, -7499.8
2022-03-25T13:50:00, -7046.4
2022-03-25T13:55:00, -3626.4
2022-03-25T14:00:00, -6944.6
2022-03-25T14:05:00, -7627.9
2022-03-25T14:10:00, -6911
2022-03-25T14:15:00, -7052.4
2022-03-25T14:20:00, -7167.3
2022-03-25T14:25:00, -4227.3
2022-03-25T14:30:00, -3894.4
2022-03-25T14:35:00, -3032.5
2022-03-25T14:40:00, -3435
2022-03-25T14:45:00, -4358.9
2022-03-25T14:50:00, -3863.8
2022-03-25T14:55:00, -3004.9
2022-03-25T15:00:00, -3693.3
2022-03-25T15:05:00, -4013.1
2022-03-25T15:10:00, -6084.1
2022-03-25T15:15:00, -7588.6
2022-03-25T15:20:00, -7851.8
2022-03-25T15:25:00, -5813.7
2022-03-25T15:30:00, -7295.4
2022-03-25T15:35:00, -7591.7
2022-03-25T15:40:00, -6213.8
2022-03-25T15:45:00, -4657.1
2022-03-25T15:50:00, -5871.1
2022-03-25T15:55:00, -6496.4
2022-03-25T16:00:00, -6793.4
2022-03-25T16:05:00, -6985.7
2022-03-25T16:10:00, -5674.7
2022-03-25T16:15:00, -5824.4
2022-03-25T16:20:00, -3869.7
2022-03-25T16:25:00, -5745.3
2022-03-25T16:30:00, -4014.7
2022-03-25T16:35:00, -3786.3
2022-03-25T16:40:00, -3768.5
2022-03-25T16:45:00, -3749.9
2022-03-25T16:50:00, -2723.4
2022-03-25T16:55:00, -3809.4
2022-03-25T17:00:00, -4880.1
2022-03-25T17:05:00, -4194.4
2022-03-25T17:10:00, -3464.7
2022-03-25T17:15:00, -3494.3
2022-03-25T17:20:00, -3037.2
2022-03-25T17:25:00, -4688
2022-03-25T17:30:00, -2894
2022-03-25T17:35:00, -1684.5
2022-03-25T17:40:00, -1756.9
2022-03-25T17:45:00, -1533.5
2022-03-25T17:50:00, -1756.4
2022-03-25T17:55:00, -1542.6
2022-03-25T18:00:00, -1505.6
2022-03-25T18:05:00, -1618.4
2022-03-25T18:10:00, -553.1
2022-03-25T18:15:00, 1441.3
2022-03-25T18:20:00, 843.9
2022-03-25T18:25:00, 725.9
2022-03-25T18:30:00, 607.5
2022-03-25T18:35:00, 476.6
2022-03-25T18:40:00, 713.4
2022-03-25T18:45:00, 724
2022-03-25T18:50:00, 652.7
2022-03-25T18:55:00, 607.6
2022-03-25T19:00:00, 478.9
2022-03-25T19:05:00, 463.5
2022-03-25T19:10:00, 368.8
2022-03-25T19:15:00, 319.6
2022-03-25T19:20:00, 287.4
2022-03-25T19:25:00, 231.7
2022-03-25T19:30:00, 174.7
2022-03-25T19:35:00, 128
2022-03-25T19:40:00, 85.7
2022-03-25T19:45:00, 41
2022-03-25T19:50:00, 8.7
2022-03-25T19:55:00, 2.1
2022-03-25T20:00:00, 2.8
2022-03-25T20:05:00, 2.9
2022-03-25T20:10:00, 2.8
2022-03-25T20:15:00, 2.7
2022-03-25T20:20:00, 2.4
2022-03-25T20:25:00, 2.4
2022-03-25T20:30:00, 2.6
2022-03-25T20:35:00, 2.9
2022-03-25T20:40:00, 3
2022-03-25T20:45:00, 2.9
2022-03-25T20:50:00, 1.4
2022-03-25T20:55:00, 2.9
2022-03-25T21:00:00, 3
2022-03-25T21:05:00, 3.3
2022-03-25T21:10:00, 3.2
2022-03-25T21:15:00, 3.3
2022-03-25T21:20:00, 3.2
2022-03-25T21:25:00, 3.2
2022-03-25T21:30:00, 1.6
2022-03-25T21:35:00, 2.9
2022-03-25T21:40:00, 2.9
2022-03-25T21:45:00, 2.8
2022-03-25T21:50:00, 1.5
2022-03-25T21:55:00, 2.3
2022-03-25T22:00:00, 2.7
2022-03-25T22:05:00, 2.7
2022-03-25T22:10:00, 3.3
2022-03-25T22:15:00, 2.9
2022-03-25T22:20:00, 2.5
2022-03-25T22:25:00, 2.5
2022-03-25T22:30:00, 2.5
2022-03-25T22:35:00, 2.4
2022-03-25T22:40:00, 2.4
2022-03-25T22:45:00, 2.5
2022-03-25T22:50:00, 2.5
2022-03-25T22:55:00, 2.6
2022-03-25T23:00:00, 2.5
2022-03-25T23:05:00, 2.3
2022-03-25T23:10:00, 2.7
2022-03-25T23:15:00, 2.7
2022-03-25T23:20:00, 2.6
2022-03-25T23:25:00, 2.5
2022-03-25T23:30:00, 2.6
2022-03-25T23:35:00, 2.6
2022-03-25T23:40:00, 2.6
2022-03-25T23:45:00, 2.6
2022-03-25T23:50:00, 2.5
2022-03-25T23:55:00, 2
2022-03-26T00:00:00, 2.3
2022-03-26T00:05:00, 2.4
2022-03-26T00:10:00, 2.4
2022-03-26T00:15:00, 2.5
2022-03-26T00:20:00, 2.4
2022-03-26T00:25:00, 2.4
2022-03-26T00:30:00, 2.5
2022-03-26T00:35:00, 2.5
2022-03-26T00:40:00, 2.5
2022-03-26T00:45:00, 2.6
2022-03-26T00:50:00, 2.5
2022-03-26T00:55:00, 2.5
2022-03-26T01:00:00, 2.6
2022-03-26T01:05:00, 2.5
2022-03-26T01:10:00, 0.9
2022-03-26T01:15:00, 1
2022-03-26T01:20:00, 1
2022-03-26T01:25:00, 0.8
2022-03-26T01:30:00, 0.7
2022-03-26T01:35:00, 0.9
2022-03-26T01:40:00, 2.6
2022-03-26T01:45:00, 2.6
2022-03-26T01:50:00, 2.5
2022-03-26T01:55:00, 2.6
2022-03-26T02:00:00, 2.7
2022-03-26T02:05:00, 2.6
2022-03-26T02:10:00, 2.7
2022-03-26T02:15:00, 2.7
2022-03-26T02:20:00, 2.5
2022-03-26T02:25:00, 2.5
2022-03-26T02:30:00, 2.5
2022-03-26T02:35:00, 2.4
2022-03-26T02:40:00, 2.5
2022-03-26T02:45:00, 2.6
2022-03-26T02:50:00, 2.5
2022-03-26T02:55:00, 2.4
2022-03-26T03:00:00, 2.4
2022-03-26T03:05:00, 2.4
2022-03-26T03:10:00, 2.5
2022-03-26T03:15:00, 2.5
2022-03-26T03:20:00, 2.4
2022-03-26T03:25:00, 2.5
2022-03-26T03:30:00, 2.4
2022-03-26T03:35:00, 2.3
2022-03-26T03:40:00, 2.3
2022-03-26T03:45:00, 2.4
2022-03-26T03:50:00, 2.4
2022-03-26T03:55:00, 2.3
2022-03-26T04:00:00, 2.4
2022-03-26T04:05:00, 2.7
2022-03-26T04:10:00, 2.7
2022-03-26T04:15:00, 2.4
2022-03-26T04:20:00, 1.8
2022-03-26T04:25:00, 2.2
2022-03-26T04:30:00, 2.5
2022-03-26T04:35:00, 2.5
2022-03-26T04:40:00, 2.4
2022-03-26T04:45:00, 2.5
2022-03-26T04:50:00, 2.5
2022-03-26T04:55:00, 2
2022-03-26T05:00:00, 1.9
2022-03-26T05:05:00, 1.9
2022-03-26T05:10:00, 2.1
2022-03-26T05:15:00, 2.7
2022-03-26T05:20:00, 2.8
2022-03-26T05:25:00, 2.8
2022-03-26T05:30:00, 2.8
2022-03-26T05:35:00, 2.6
2022-03-26T05:40:00, 2.3
2022-03-26T05:45:00, 2.1
2022-03-26T05:50:00, 2
2022-03-26T05:55:00, 1.9
2022-03-26T06:00:00, 2
2022-03-26T06:05:00, 1.9
2022-03-26T06:10:00, 1.9
2022-03-26T06:15:00, 1.9
2022-03-26T06:20:00, 1.9
2022-03-26T06:25:00, 1.9
2022-03-26T06:30:00, 1.8
2022-03-26T06:35:00, 1.6
2022-03-26T06:40:00, 1.8
2022-03-26T06:45:00, 1.9
2022-03-26T06:50:00, 1.9
2022-03-26T06:55:00, 1.7
2022-03-26T07:00:00, 2
2022-03-26T07:05:00, 2
2022-03-26T07:10:00, 2
2022-03-26T07:15:00, 1.9
2022-03-26T07:20:00, 1.8
2022-03-26T07:25:00, 2.4
2022-03-26T07:30:00, 5.2
2022-03-26T07:35:00, 54.8
2022-03-26T07:40:00, 112.4
2022-03-26T07:45:00, 161.8
2022-03-26T07:50:00, 210.3
2022-03-26T07:55:00, 256.2
2022-03-26T08:00:00, 303.8
2022-03-26T08:05:00, 356.9
2022-03-26T08:10:00, 391.3
2022-03-26T08:15:00, 457
2022-03-26T08:20:00, 537.8
2022-03-26T08:25:00, 625.7
2022-03-26T08:30:00, 927.4
2022-03-26T08:35:00, 1459.1
2022-03-26T08:40:00, 1828.2
2022-03-26T08:45:00, 1970.4
2022-03-26T08:50:00, 2312.9
2022-03-26T08:55:00, 2559.1
2022-03-26T09:00:00, 2813.5
2022-03-26T09:05:00, 3230.6
2022-03-26T09:10:00, 3524.8
2022-03-26T09:15:00, 3820.4
2022-03-26T09:20:00, 4122.2
2022-03-26T09:25:00, 4418.4
2022-03-26T09:30:00, 4719.7
2022-03-26T09:35:00, 5047.5
2022-03-26T09:40:00, 5361.6
2022-03-26T09:45:00, 5648.2
2022-03-26T09:50:00, 5908.4
2022-03-26T09:55:00, 6178.1
2022-03-26T10:00:00, 6446
2022-03-26T10:05:00, 6684.4
2022-03-26T10:10:00, 6911.8
2022-03-26T10:15:00, 7161.2
2022-03-26T10:20:00, 7392.5
2022-03-26T10:25:00, 7612.8
2022-03-26T10:30:00, 7846.7
2022-03-26T10:35:00, 8070.6
2022-03-26T10:40:00, 8279.1
2022-03-26T10:45:00, 8488.1
2022-03-26T10:50:00, 8709.9
2022-03-26T10:55:00, 8890.7
2022-03-26T11:00:00, 9081.6
2022-03-26T11:05:00, 9212
2022-03-26T11:10:00, 9392.8
2022-03-26T11:15:00, 9592.9
2022-03-26T11:20:00, 9768
2022-03-26T11:25:00, 9918.2
2022-03-26T11:30:00, 10006.9
2022-03-26T11:35:00, 10070.3
2022-03-26T11:40:00, 10266
2022-03-26T11:45:00, 10438
2022-03-26T11:50:00, 10582.4
2022-03-26T11:55:00, 10664.1
2022-03-26T12:00:00, 10788
2022-03-26T12:05:00, 10862.5
2022-03-26T12:10:00, 10971
2022-03-26T12:15:00, 11056.3
2022-03-26T12:20:00, 11092.8
2022-03-26T12:25:00, 11139.2
2022-03-26T12:30:00, 11152.4
2022-03-26T12:35:00, 11166.9
2022-03-26T12:40:00, 11171.1
2022-03-26T12:45:00, 11174.9
2022-03-26T12:50:00, 11176.7
2022-03-26T12:55:00, 11175.9
2022-03-26T13:00:00, 11176.8
2022-03-26T13:05:00, 11179.1
2022-03-26T13:10:00, 11184.4
2022-03-26T13:15:00, 11195.1
2022-03-26T13:20:00, 11193.6
2022-03-26T13:25:00, 11187
2022-03-26T13:30:00, 11182.8
2022-03-26T13:35:00, 11172.2
2022-03-26T13:40:00, 11168.6
2022-03-26T13:45:00, 11170.9
2022-03-26T13:50:00, 11166
2022-03-26T13:55:00, 11167.5
2022-03-26T14:00:00, 11169.3
2022-03-26T14:05:00, 11167.7
2022-03-26T14:10:00, 11186.9
2022-03-26T14:15:00, 11205.6
2022-03-26T14:20:00, 11192.3
2022-03-26T14:25:00, 11195.7
2022-03-26T14:30:00, 11194.7
2022-03-26T14:35:00, 11191.4
2022-03-26T14:40:00, 11189
2022-03-26T14:45:00, 11189.5
2022-03-26T14:50:00, 11189.7
2022-03-26T14:55:00, 11191.3
2022-03-26T15:00:00, 11195
2022-03-26T15:05:00, 11194.9
2022-03-26T15:10:00, 11187.8
2022-03-26T15:15:00, 11175.2
2022-03-26T15:20:00, null
2022-03-26T15:25:00, null
Here is the Enphase data compared to IotaWatt every 5 minutes if anyone has ever wanted to see this.
Enphase IoTaWatt
3/26/2022 3:25PM 11,007 0
3/26/2022 3:20PM 11,134 0
3/26/2022 3:15PM 11,174 11175.2 1.000107392
3/26/2022 3:10PM 11,188 11187.8 0.999982124
3/26/2022 3:05PM 11,195 11194.9 0.999991067
3/26/2022 3:00PM 6,091 11195 1.837957642
3/26/2022 2:55PM 11,339 11191.3 0.98697416
3/26/2022 2:50PM 11,339 11189.7 0.986833054
3/26/2022 2:45PM 11,335 11189.5 0.987163652
3/26/2022 2:40PM 11,341 11189 0.986597302
3/26/2022 2:35PM 11,341 11191.4 0.986808923
3/26/2022 2:30PM 11,332 11194.7 0.987883869
3/26/2022 2:25PM 11,340 11195.7 0.987275132
3/26/2022 2:20PM 11,340 11192.3 0.986975309
3/26/2022 2:15PM 11,336 11205.6 0.988496824
3/26/2022 2:10PM 11,340 11186.9 0.986499118
3/26/2022 2:05PM 11,340 11167.7 0.984805996
3/26/2022 2:00PM 11,334 11169.3 0.985468502
3/26/2022 1:55PM 11,338 11167.5 0.984962074
3/26/2022 1:50PM 11,338 11166 0.984829776
3/26/2022 1:45PM 11,342 11170.9 0.984914477
3/26/2022 1:40PM 11,337 11168.6 0.985145982
3/26/2022 1:35PM 11,337 11172.2 0.985463527
3/26/2022 1:30PM 8,452 11182.8 1.323095125
3/26/2022 1:25PM 11,338 11187 0.986681954
3/26/2022 1:20PM 11,338 11193.6 0.987264068
3/26/2022 1:15PM 11,338 11195.1 0.987396366
3/26/2022 1:10PM 11,342 11184.4 0.986104743
3/26/2022 1:05PM 11,342 11179.1 0.985637454
3/26/2022 1:00PM 11,329 11176.8 0.986565451
3/26/2022 12:55PM 11,337 11175.9 0.985789892
3/26/2022 12:50PM 11,337 11176.7 0.985860457
3/26/2022 12:45PM 11,342 11174.9 0.985267149
3/26/2022 12:40PM 11,333 11171.1 0.985714286
3/26/2022 12:35PM 11,333 11166.9 0.985343687
3/26/2022 12:30PM 11,284 11152.4 0.988337469
3/26/2022 12:25PM 11,244 11139.2 0.990679473
3/26/2022 12:20PM 11,244 11092.8 0.986552828
3/26/2022 12:15PM 11,121 11056.3 0.994182178
3/26/2022 12:10PM 10,977 10971 0.999453403
3/26/2022 12:05PM 10,977 10862.5 0.989569099
3/26/2022 12:00PM 10,824 10788 0.996674058
3/26/2022 11:55AM 10,639 10664.1 1.002359244
3/26/2022 11:50AM 10,639 10582.4 0.994679951
3/26/2022 11:45AM 10,447 10438 0.999138509
3/26/2022 11:40AM 10,181 10266 1.008348885
3/26/2022 11:35AM 10,181 10070.3 0.989126805
3/26/2022 11:30AM 10,005 10006.9 1.000189905
3/26/2022 11:25AM 9,778 9918.2 1.01433831
3/26/2022 11:20AM 9,778 9768 0.998977296
3/26/2022 11:15AM 9,545 9592.9 1.005018334
3/26/2022 11:10AM 9,231 9392.8 1.017527895
3/26/2022 11:05AM 9,231 9212 0.997941718
3/26/2022 11:00AM 8,997 9081.6 1.009403134
3/26/2022 10:55AM 8,665 8890.7 1.026047317
3/26/2022 10:50AM 8,665 8709.9 1.005181766
3/26/2022 10:45AM 8,399 8488.1 1.010608406
3/26/2022 10:40AM 8,013 8279.1 1.033208536
3/26/2022 10:35AM 8,013 8070.6 1.007188319
3/26/2022 10:30AM 7,730 7846.7 1.015097025
3/26/2022 10:25AM 7,317 7612.8 1.040426404
3/26/2022 10:20AM 7,317 7392.5 1.010318437
3/26/2022 10:15AM 7,042 7161.2 1.016927009
3/26/2022 10:10AM 6,604 6911.8 1.046608116
3/26/2022 10:05AM 6,604 6684.4 1.01217444
3/26/2022 10:00AM 6,299 6446 1.023337038
3/26/2022 9:55AM 5,826 6178.1 1.060435977
3/26/2022 9:50AM 5,826 5908.4 1.014143495
3/26/2022 9:45AM 5,489 5648.2 1.029003461
3/26/2022 9:40AM 4,939 5361.6 1.085563879
3/26/2022 9:35AM 4,939 5047.5 1.02196801
3/26/2022 9:30AM 4,616 4719.7 1.022465338
3/26/2022 9:25AM 4,049 4418.4 1.091232403
3/26/2022 9:20AM 4,049 4122.2 1.018078538
3/26/2022 9:15AM 3,678 3820.4 1.038716694
3/26/2022 9:10AM 3,036 3524.8 1.161001318
3/26/2022 9:05AM 3,036 3230.6 1.064097497
3/26/2022 9:00AM 2,813 2813.5 1.000177746
3/26/2022 8:55AM 2,300 2559.1 1.112652174
3/26/2022 8:50AM 1,857 2312.9 1.2455035
3/26/2022 8:45AM 1,603 1970.4 1.229195259
3/26/2022 8:40AM 1,603 1828.2 1.140486588
3/26/2022 8:35AM 1,039 1459.1 1.404331088
3/26/2022 8:30AM 629 927.4 1.474403816
3/26/2022 8:25AM 629 625.7 0.994753577
3/26/2022 8:20AM 520 537.8 1.034230769
3/26/2022 8:15AM 403 457 1.133995037
3/26/2022 8:10AM 403 391.3 0.970967742
3/26/2022 8:05AM 341 356.9 1.046627566
3/26/2022 8:00AM 258 303.8 1.17751938
3/26/2022 7:55AM 258 256.2 0.993023256
3/26/2022 7:50AM 162 210.3 1.298148148
3/26/2022 7:45AM 91 161.8 1.778021978
3/26/2022 7:40AM 91 112.4 1.235164835
3/26/2022 7:35AM 76 54.8 0.721052632
Updating the same data from both the IoTaWatt and Enphase will not work. You can do generation from one and consumption from the other, but calculated values like import and export will not match either system’s values.
My recommendation is to setup a separate PVoutput for each, run them for awhile and see which seems more reliable and accurate.
Most inverters draw power in standby mode. 3W would be normal for some inverters. To differentiate that from inverter output, check “Allow negative values” for the solar_1 input and the standby load will begin to show as -3 Watts. If you don’t want to see the standby power you can create an output to only show the positive generation:
solar = solar_1 max 0
The query does not match the data in PVoutput, so it’s the Enphase data.
The current in the wires is the same at both ends. Any difference would be from voltage calibration or voltage drop.
You just did.
UPDATE:
I notice that there is a white neutral wire of the same gauge coming in through the same conduit as the two PV wires. That suggests that you have a three-wire system. You may need to put a CT on the black wire as well or run both through a 100A CT in opposite directions.
Looking at your PVoutput setup:
You have your timezone set to Australia/Sydney time. Unlike the other uploaders, PVoutput uploads are timestamped with local time. If you are in USA zip 30534, your IoTaWatt should be set to -5 allow DST and your PVoutput should be set to USA Eastern Time.
I updated the timezone for the live view. It does not appear to affect anything.
Enphase gets rid of the neutral and ground in the array. Their Q cable simple has black and red. These are combined in a box and the neutral and ground start there.
I ran this:
http://iotawatt.local/query?select=[time,solar_1.Wh.d2]&begin=2022-03-26T07:36&end=2022-03-26T20:30&group=2m&format=csv
This matches up almost exact to what enphase is showing for the day so far. I will double check it once the sun goes down to see the exact difference and post it in a reply. Should be about 90 kWh and one of my best days since 2018.
I am going to turn off the enphase push tonight and see how it looks with just the data coming from IoTaWatt tomorrow as the weather should be similar. I did this yesterday and it was behaving strange. I will post the results of that as well. Can the docs be updated to mention the fact that one push will override the other if 2 are setup at the same time?
Can I ask what you expected would happen?
I guess I thought I would be able to compare the data from both feeds and it seems that is possible if you have the paid mode of PVOutput and use the extra defined parameters.
For yesterdays(3/26/2022) data and having the push from IotaWatt and the pull from Enphase it appears that Enphase eventually replaces the data for the production but also causes the energy used column to not add all energy.
I compared the IotaWatt production data to the Enphase data and production was 1 kWh less than the Enphase but prob more accurate as it is measured at the main panel anyway. I also compared the IoTaWatt consumption/production data to my utility data and it agrees perfectly. IoTaWatt was 83kWh/84kWh compared to my utility daily usage of -1kWh.
I turned off the Enphase data pull at midnight and the energy used column appears to be adding cumulatively now. I don’t really see the need for the Enphase data anymore.
It looks like Enphase may be killing the access to the API for non-business users anyway:
I replied to this post about my IotaWatt experience as well, sharing the link for this discussion.
