For a while my Iotawatt has been broken and Ive just found the time to investigate properly. My device is flashing GRRG indicating a config.txt problem, and web connections are refused (it doesnt give the GET message Ive seen mentioned, just refuses the connection)
However when I plug the SD card into my computer it seems fine. The config.txt file is included below, but Im unclear what else I could check in order to get the Iotawatt booting again?
Thanks in advance!
"format": 2,
"timezone": 0,
"update": "MINOR",
"device": {
"name": "IotaWatt",
"version": 3,
"channels": "15",
"burden": [
0,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20,
20
"inputs": [
"channel": 0,
"name": "Voltage",
"type": "VT",
"model": "Ideal 77DE-06-09-VI(EU)",
"cal": 18.98
"channel": 1,
"name": "Total",
"type": "CT",
"model": "AcuCT-H063-100",
"phase": 0.6,
"turns": 2000,
"cal": 100,
"reverse": true
"channel": 2,
"name": "Oven",
"type": "CT",
"model": "AcuCT-H040-50",
"phase": 1,
"turns": 1000,
"cal": 50,
"reverse": true
"channel": 3,
"name": "Upstairs",
"type": "CT",
"phase": 1,
"turns": 1000,
"cal": 50,
"reverse": true
"channel": 4,
"name": "Kitchen",
"type": "CT",
"phase": 1,
"turns": 1000,
"cal": 50,
"reverse": true
null,
null,
null,
null,
null,
null,
null,
null,
null,
null
"outputs": [
"name": "RestOfHouse",
"units": "Watts",
"script": "@1-@2-@3-@4"
"dstrule": {
"adj": 60,
"utc": true,
"begin": {
"month": 3,
"weekday": 1,
"instance": -1,
"time": 60
"end": {
"month": 10,
"weekday": 1,
"instance": -1,
"time": 60
