Does anyone know what the short duration inrush or fault current which will be stored in the maximum values?
Would a 100ms motor start current be stored in the maximum values for example?
I am wondering if a iotawatt could be used to detect an intermittent ground fault on a panel (we have a fault which shows up about once a month). There is a 150ms trip time on the main breaker, so I am hoping it could pick that up, even if it were good enough to provide an integration of a 500ms interval, that would likely be enough of a change to find it.
