Dear community, for some reason my system has become quite unstable for the past 2 weeks since the latest firmware upgrade to 2_08_02. The unit would either become non-responsive (unreachable via HTTP) or restart itself for no reason, and sometimes it needs multiple restarts to get it to function again. Has anyone encountered similar behaviour?
Here’re some log entries to help with diagnosis. Appreciate any help! thanks!
3/27/23 15:00:23z Real Time Clock is running. Unix time 1679929223
3/27/23 15:00:23z Reset reason: Software/System restart
3/27/23 15:00:23z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10, 25:18, 25:19
3/27/23 15:00:23z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 15:00:23z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 15:00:23z SPIFFS mounted.
3/28/23 02:00:23 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 02:00:23 device name: IotaWatt
3/28/23 02:00:23 HTTP server started
3/28/23 02:00:24 timeSync: service started.
3/28/23 02:00:24 statService: started.
3/28/23 02:00:24 dataLog: service started.
3/28/23 02:00:26 dataLog: Last log entry 03/28/23 01:53:50
3/27/23 15:09:42z Real Time Clock is running. Unix time 1679929782
3/27/23 15:09:42z Reset reason: Software/System restart
3/27/23 15:09:42z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[5], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 25:18, 25:19
3/27/23 15:09:42z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 15:09:42z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 15:09:42z SPIFFS mounted.
3/28/23 02:09:42 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 02:09:42 device name: IotaWatt
3/28/23 02:09:42 HTTP server started
3/28/23 02:09:42 timeSync: service started.
3/28/23 02:09:43 statService: started.
3/28/23 02:09:43 dataLog: service started.
3/28/23 02:09:45 dataLog: Last log entry 03/28/23 02:00:20
3/28/23 02:09:47 Updater: service started. Auto-update class is MINOR
3/28/23 02:09:47 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -57db
3/28/23 02:09:47 Grid: Started
3/28/23 02:09:49 Grid: Last log entry 03/28/23 01:53:45
3/28/23 02:09:49 historyLog: service started.
3/28/23 02:09:50 historyLog: Last log entry 03/28/23 01:53:00
3/28/23 02:09:51 Updater: Auto-update is current for class MINOR.
3/27/23 16:09:17z Real Time Clock is running. Unix time 1679933357
3/27/23 16:09:17z Reset reason: Software/System restart
3/27/23 16:09:17z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[5], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 25:18, 25:19
3/27/23 16:09:17z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 16:09:17z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 16:09:17z SPIFFS mounted.
3/28/23 03:09:17 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 03:09:17 device name: IotaWatt
3/28/23 03:09:17 HTTP server started
3/28/23 03:09:17 timeSync: service started.
3/28/23 03:09:18 statService: started.
3/28/23 03:09:18 dataLog: service started.
3/28/23 03:09:20 dataLog: Last log entry 03/28/23 03:03:50
3/27/23 16:21:52z Real Time Clock is running. Unix time 1679934112
3/27/23 16:21:52z Reset reason: Software/System restart
3/27/23 16:21:52z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/27/23 16:21:52z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 16:21:52z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 16:21:52z SPIFFS mounted.
3/28/23 03:21:52 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 03:21:52 device name: IotaWatt
3/28/23 03:21:52 HTTP server started
3/27/23 16:29:21z Real Time Clock is running. Unix time 1679934561
3/27/23 16:29:21z Reset Reason: Power-fail restart.
3/27/23 16:29:21z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 16:29:21z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 16:29:21z SPIFFS mounted.
3/28/23 03:29:21 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 03:29:21 device name: IotaWatt
3/28/23 03:29:24 HTTP server started
3/28/23 03:29:24 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -55db
3/28/23 03:29:24 timeSync: service started.
3/28/23 03:29:24 statService: started.
3/28/23 03:29:24 Updater: service started. Auto-update class is MINOR
3/28/23 03:29:24 dataLog: service started.
3/28/23 03:29:26 dataLog: Last log entry 03/28/23 03:09:20
3/28/23 03:29:26 Updater: Auto-update is current for class MINOR.
3/28/23 03:29:28 Grid: Started
3/28/23 03:29:30 Grid: Last log entry 03/28/23 03:03:45
3/28/23 03:29:30 historyLog: service started.
3/28/23 03:29:31 historyLog: Last log entry 03/28/23 03:03:00
3/27/23 18:21:03z Real Time Clock is running. Unix time 1679941263
3/27/23 18:21:03z Reset reason: Software/System restart
3/27/23 18:21:03z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10, 25:18, 25:19
3/27/23 18:21:03z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 18:21:03z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 18:21:03z SPIFFS mounted.
3/28/23 05:21:03 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 05:21:03 device name: IotaWatt
3/28/23 05:21:03 HTTP server started
3/28/23 05:21:03 timeSync: service started.
3/28/23 05:21:04 statService: started.
3/28/23 05:21:04 dataLog: service started.
3/28/23 05:21:06 dataLog: Last log entry 03/28/23 05:13:50
3/28/23 05:21:08 Updater: service started. Auto-update class is MINOR
3/28/23 05:21:08 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -57db
3/28/23 05:21:08 Grid: Started
3/28/23 05:21:09 Grid: Last log entry 03/28/23 05:13:45
3/28/23 05:21:10 historyLog: service started.
3/28/23 05:21:11 historyLog: Last log entry 03/28/23 05:13:00
3/28/23 05:21:11 Updater: Auto-update is current for class MINOR.
3/27/23 21:14:13z Real Time Clock is running. Unix time 1679951653
3/27/23 21:14:13z Reset reason: Software/System restart
3/27/23 21:14:13z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/27/23 21:14:13z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 21:14:13z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 21:14:13z SPIFFS mounted.
3/28/23 08:14:13 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 08:14:13 device name: IotaWatt
3/28/23 08:14:13 HTTP server started
3/27/23 21:21:34z Real Time Clock is running. Unix time 1679952094
3/27/23 21:21:34z Reset Reason: Power-fail restart.
3/27/23 21:21:34z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 21:21:34z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 21:21:34z SPIFFS mounted.
3/28/23 08:21:34 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 08:21:34 device name: IotaWatt
3/28/23 08:21:37 HTTP server started
3/28/23 08:21:37 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -55db
3/27/23 21:44:02z Real Time Clock is running. Unix time 1679953442
3/27/23 21:44:02z Reset Reason: Power-fail restart.
3/27/23 21:44:02z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 21:44:02z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 21:44:02z SPIFFS mounted.
3/28/23 08:44:02 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 08:44:02 device name: IotaWatt
3/27/23 21:50:27z Real Time Clock is running. Unix time 1679953827
3/27/23 21:50:27z Reset Reason: Power-fail restart.
3/27/23 21:50:27z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 21:50:27z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 21:50:27z SPIFFS mounted.
3/28/23 08:50:27 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 08:50:27 device name: IotaWatt
3/28/23 08:50:30 HTTP server started
3/28/23 08:50:30 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -55db
3/28/23 08:50:30 timeSync: service started.
3/28/23 08:50:30 statService: started.
3/28/23 08:50:30 Updater: service started. Auto-update class is MINOR
3/28/23 08:50:30 dataLog: service started.
3/28/23 08:50:32 dataLog: Last log entry 03/28/23 08:08:55
3/28/23 08:50:32 Updater: Auto-update is current for class MINOR.
3/28/23 08:50:34 Grid: Started
3/28/23 08:50:35 Grid: Last log entry 03/28/23 08:08:50
3/28/23 08:50:36 historyLog: service started.
3/28/23 08:50:37 historyLog: Last log entry 03/28/23 08:08:00
3/27/23 23:26:03z Real Time Clock is running. Unix time 1679959563
3/27/23 23:26:03z Reset reason: Software/System restart
3/27/23 23:26:03z Trace: 34:30, 34:30, 33:0, 33:1, 33:1, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17, 10:17, 10:17, 1:3, 1:1[9], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/27/23 23:26:03z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 23:26:03z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 23:26:03z SPIFFS mounted.
3/28/23 10:26:03 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 10:26:03 device name: IotaWatt
3/28/23 10:26:03 HTTP server started
3/28/23 10:26:03 timeSync: service started.
3/28/23 10:26:04 statService: started.
3/28/23 10:26:04 dataLog: service started.
3/28/23 10:26:06 dataLog: Last log entry 03/28/23 10:20:55
3/27/23 23:33:13z Real Time Clock is running. Unix time 1679959993
3/27/23 23:33:13z Reset reason: Software/System restart
3/27/23 23:33:13z Trace: 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[4], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[2], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10[1], 34:0, 34:5, 34:5, 34:5, 34:6[1], 34:10, 25:18, 25:19
3/27/23 23:33:13z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 23:33:13z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 23:33:13z SPIFFS mounted.
3/28/23 10:33:13 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 10:33:13 device name: IotaWatt
3/28/23 10:33:13 HTTP server started
3/28/23 10:33:13 timeSync: service started.
3/28/23 10:33:14 statService: started.
3/28/23 10:33:14 dataLog: service started.
3/28/23 10:33:16 dataLog: Last log entry 03/28/23 10:26:00
3/27/23 23:45:48z Real Time Clock is running. Unix time 1679960748
3/27/23 23:45:48z Reset reason: Software/System restart
3/27/23 23:45:48z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/27/23 23:45:48z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 23:45:48z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 23:45:48z SPIFFS mounted.
3/28/23 10:45:48 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 10:45:48 device name: IotaWatt
3/28/23 10:45:48 HTTP server started
3/28/23 10:45:48 timeSync: service started.
3/28/23 10:45:48 statService: started.
3/28/23 10:45:49 dataLog: service started.
3/28/23 10:45:51 dataLog: Last log entry 03/28/23 10:32:40
3/27/23 23:58:23z Real Time Clock is running. Unix time 1679961503
3/27/23 23:58:23z Reset reason: Software/System restart
3/27/23 23:58:23z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
3/27/23 23:58:23z ESP8266 ID: 510364, RTC M41T81 (68)
3/27/23 23:58:23z IoTaWatt 5.0, Firmware version 02_08_02
3/27/23 23:58:23z SPIFFS mounted.
3/28/23 10:58:23 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 10:58:23 device name: IotaWatt
3/28/23 10:58:23 HTTP server started
3/28/23 10:58:23 timeSync: service started.
3/28/23 10:58:24 statService: started.
3/28/23 10:58:24 dataLog: service started.
3/28/23 10:58:26 dataLog: Last log entry 03/28/23 10:32:40
3/28/23 10:58:28 Updater: service started. Auto-update class is MINOR
3/28/23 10:58:28 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -57db
3/28/23 00:10:58z Real Time Clock is running. Unix time 1679962258
3/28/23 00:10:58z Reset Reason: Power-fail restart.
3/28/23 00:10:58z ESP8266 ID: 510364, RTC M41T81 (68)
3/28/23 00:10:58z IoTaWatt 5.0, Firmware version 02_08_02
3/28/23 00:10:58z SPIFFS mounted.
3/28/23 11:10:58 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 11:10:58 device name: IotaWatt
3/28/23 00:18:11z Real Time Clock is running. Unix time 1679962691
3/28/23 00:18:11z Reset Reason: Power-fail restart.
3/28/23 00:18:11z ESP8266 ID: 510364, RTC M41T81 (68)
3/28/23 00:18:11z IoTaWatt 5.0, Firmware version 02_08_02
3/28/23 00:18:11z SPIFFS mounted.
3/28/23 11:18:11 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 11:18:11 device name: IotaWatt
3/28/23 00:29:53z Real Time Clock is running. Unix time 1679963393
3/28/23 00:29:53z Reset Reason: Power-fail restart.
3/28/23 00:29:53z ESP8266 ID: 510364, RTC M41T81 (68)
3/28/23 00:29:53z IoTaWatt 5.0, Firmware version 02_08_02
3/28/23 00:29:53z SPIFFS mounted.
3/28/23 11:29:53 Local time zone: +10:00, using DST/BST when in effect.
3/28/23 11:29:53 device name: IotaWatt
3/28/23 11:29:56 Connecting with WiFiManager.
3/28/23 11:29:59 HTTP server started
3/28/23 11:29:59 WiFi connected. SSID=IoTaWatt, IP=192.168.8.100, channel=7, RSSI -55db
3/28/23 11:29:59 timeSync: service started.
3/28/23 11:29:59 statService: started.
3/28/23 11:29:59 Updater: service started. Auto-update class is MINOR
3/28/23 11:29:59 dataLog: service started.
3/28/23 11:30:01 dataLog: Last log entry 03/28/23 10:32:40
3/28/23 11:30:01 Updater: Auto-update is current for class MINOR.
3/28/23 11:30:03 Grid: Started
3/28/23 11:30:04 Grid: Last log entry 03/28/23 10:20:50
3/28/23 11:30:05 historyLog: service started.
3/28/23 11:30:06 historyLog: Last log entry 03/28/23 10:20:00
