Hi, I’ve just installed Iotawatt and loving the granular data I’m able to get. I bought some generic SCT-013-050 50a/1v CT Clamps from here SCT-013 10a 20a 30a 50a 100a Open-Close-Stromwandler sct013 nicht-invasiver Wechselstrom sensor Split-Core-Stromwandler - AliExpress 502
I’ve removed the burden resistor from the CT clamps and that’s the only mod I’ve done. I’ve added them as inputs but not sure what to set the phase lead and turns values to. Someone in another forum with similar CT’s told me that Phase Lead of 3 and Turns of 1860 was correct and to leave the iotawatt Burden setting at 20, but I’m seeing measurements are inaccurate at about 12-15% too low. Ie, when I stand infront of my solar inverter screen to check live data it’s showing 3.632kw, but iotawatt Status is showing 3.109kw. It’s also not a fixed difference, could be 8% could be 15% depending on power levels measured.
My physical electricity meter doesn’t show me the actual live consumption/export, but I’m guessing the Grid feed value is correct because that is an unmodified 100a/50a CT, and you can see from the screenshot that I’m exporting more than the solar is reporting being generated (blue is my inverter). I’ll see if I can validate total day consumption from my utility company and compare to iotawatt.
Anyway, I was hoping that someone that has used these Aliexpress CT’s could advise on whether my configuration is correct, or what needs to change in order to get accurate results from the 3x50a CT’s.
Thanks in advance.
