Message log:
8/18/20 20:41:50z Reset reason: Exception
8/18/20 20:41:50z Trace: 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16
8/18/20 20:41:50z ESP8266 ChipID: 6195317
8/18/20 20:41:50z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 20:41:50z SPIFFS mounted.
8/18/20 20:41:50z Config file parse failed.
8/18/20 20:41:50z Local time zone: +0:00
8/18/20 20:41:50z device name: IotaWatt
8/18/20 20:41:50z HTTP server started
8/18/20 20:41:50z timeSync: service started.
8/18/20 20:41:50z statService: started.
8/18/20 20:41:54z WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=11, RSSI -50db
8/18/20 20:41:54z MDNS responder started for hostname IotaWatt
8/18/20 20:41:54z LLMNR responder started for hostname IotaWatt
8/18/20 20:41:54z Updater: service started. Auto-update class is NONE
8/18/20 20:50:10z Restart command received.
8/18/20 20:50:11z Real Time Clock is running. Unix time 1597783811
8/18/20 20:50:11z Reset reason: Software/System restart
8/18/20 20:50:11z Trace: 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 10:2, 10:3
8/18/20 20:50:11z ESP8266 ChipID: 6195317
8/18/20 20:50:11z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 20:50:11z SPIFFS mounted.
8/18/20 16:50:11 Local time zone: -5:00
8/18/20 16:50:11 Using Daylight Saving Time (BST) when in effect.
8/18/20 16:50:11 device name: IotaWatt
8/18/20 16:50:11 HTTP server started
8/18/20 16:50:11 timeSync: service started.
8/18/20 16:50:11 statService: started.
8/18/20 16:50:12 dataLog: service started.
8/18/20 16:50:12 dataLog: Last log entry 08/18/20 16:36:30
8/18/20 16:50:17 WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=11, RSSI -49db
8/18/20 16:50:17 MDNS responder started for hostname IotaWatt
8/18/20 16:50:17 LLMNR responder started for hostname IotaWatt
8/18/20 16:50:17 Updater: service started. Auto-update class is MINOR
8/18/20 16:50:18 Updater: Auto-update is current for class MINOR.
8/18/20 16:51:11 historyLog: service started.
8/18/20 16:51:11 historyLog: Last log entry 08/18/20 16:36:00
8/18/20 16:57:20 dataLog: datalog WDT - restarting
8/18/20 20:57:20z Real Time Clock is running. Unix time 1597784240
8/18/20 20:57:20z Reset reason: Software/System restart
8/18/20 20:57:20z Trace: 1:3, 1:4, 1:3, 1:4, 1:1[9], 1:2[10], 9:0[10], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:11, 15:0[32], 15:1[32], 15:2[32], 15:3[32], 15:10, 15:12, 15:13, 15:14[32], 15:15[2], 15:16, 15:17, 15:4, 10:11
8/18/20 20:57:20z ESP8266 ChipID: 6195317
8/18/20 20:57:20z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 20:57:20z SPIFFS mounted.
8/18/20 20:57:20z Config file parse failed.
8/18/20 20:57:20z Local time zone: +0:00
8/18/20 20:57:20z device name: IotaWatt
8/18/20 20:57:20z HTTP server started
8/18/20 20:57:20z timeSync: service started.
8/18/20 20:57:20z statService: started.
8/18/20 20:57:23z Restart command received.
8/18/20 20:57:25z Real Time Clock is running. Unix time 1597784245
8/18/20 20:57:25z Reset reason: Software/System restart
8/18/20 20:57:25z Trace: 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 10:2, 10:3
8/18/20 20:57:25z ESP8266 ChipID: 6195317
8/18/20 20:57:25z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 20:57:25z SPIFFS mounted.
8/18/20 20:57:25z Config file parse failed.
8/18/20 20:57:25z Local time zone: +0:00
8/18/20 20:57:25z device name: IotaWatt
8/18/20 20:57:25z HTTP server started
8/18/20 20:57:25z timeSync: service started.
8/18/20 20:57:25z statService: started.
8/18/20 20:57:29z WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=11, RSSI -47db
8/18/20 20:57:29z MDNS responder started for hostname IotaWatt
8/18/20 20:57:29z LLMNR responder started for hostname IotaWatt
8/18/20 20:57:29z Updater: service started. Auto-update class is NONE
8/18/20 21:06:03z WiFi disconnected.
8/18/20 21:06:06z WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=1, RSSI -48db
8/18/20 21:10:31z Restart command received.
8/18/20 21:10:33z Real Time Clock is running. Unix time 1597785033
8/18/20 21:10:33z Reset reason: Software/System restart
8/18/20 21:10:33z Trace: 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 1:4, 1:5[19], 1:6, 1:3, 10:2, 10:3
8/18/20 21:10:33z ESP8266 ChipID: 6195317
8/18/20 21:10:33z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 21:10:33z SPIFFS mounted.
8/18/20 17:10:33 Local time zone: -5:00
8/18/20 17:10:33 Using Daylight Saving Time (BST) when in effect.
8/18/20 17:10:33 device name: IotaWatt
8/18/20 17:10:33 HTTP server started
8/18/20 17:10:33 timeSync: service started.
8/18/20 17:10:33 statService: started.
8/18/20 17:10:34 dataLog: service started.
8/18/20 17:10:34 dataLog: Last log entry 08/18/20 16:52:20
8/18/20 17:10:39 WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=1, RSSI -51db
8/18/20 17:10:39 MDNS responder started for hostname IotaWatt
8/18/20 17:10:39 LLMNR responder started for hostname IotaWatt
8/18/20 17:10:39 Updater: service started. Auto-update class is MINOR
8/18/20 17:10:40 Updater: Auto-update is current for class MINOR.
8/18/20 17:11:33 historyLog: service started.
8/18/20 17:11:33 historyLog: Last log entry 08/18/20 16:52:00
8/18/20 17:14:33 Restart command received.
8/18/20 21:14:35z Real Time Clock is running. Unix time 1597785275
8/18/20 21:14:35z Reset reason: Software/System restart
8/18/20 21:14:35z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
8/18/20 21:14:35z ESP8266 ChipID: 6195317
8/18/20 21:14:35z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 21:14:35z SPIFFS mounted.
8/18/20 17:14:35 Local time zone: -5:00
8/18/20 17:14:35 Using Daylight Saving Time (BST) when in effect.
8/18/20 17:14:35 device name: IotaWatt
8/18/20 17:14:35 HTTP server started
8/18/20 17:14:35 timeSync: service started.
8/18/20 17:14:35 statService: started.
8/18/20 17:14:36 dataLog: service started.
8/18/20 17:14:36 dataLog: Last log entry 08/18/20 17:14:30
8/18/20 17:14:41 WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=1, RSSI -51db
8/18/20 17:14:41 MDNS responder started for hostname IotaWatt
8/18/20 17:14:41 LLMNR responder started for hostname IotaWatt
8/18/20 17:14:41 Updater: service started. Auto-update class is MINOR
8/18/20 17:14:42 Updater: Auto-update is current for class MINOR.
8/18/20 17:15:35 historyLog: service started.
8/18/20 17:15:35 historyLog: Last log entry 08/18/20 17:14:00
8/18/20 17:21:45 Restart command received.
8/18/20 21:21:47z Real Time Clock is running. Unix time 1597785707
8/18/20 21:21:47z Reset reason: Software/System restart
8/18/20 21:21:47z Trace: 1:4, 1:1[12], 1:2[13], 9:0[13], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:1[13], 1:2[14], 9:0[14], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
8/18/20 21:21:47z ESP8266 ChipID: 6195317
8/18/20 21:21:47z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 21:21:47z SPIFFS mounted.
8/18/20 17:21:47 Local time zone: -5:00
8/18/20 17:21:47 Using Daylight Saving Time (BST) when in effect.
8/18/20 17:21:47 device name: IotaWatt
8/18/20 17:21:47 HTTP server started
8/18/20 17:21:47 timeSync: service started.
8/18/20 17:21:47 statService: started.
8/18/20 17:21:48 dataLog: service started.
8/18/20 17:21:48 dataLog: Last log entry 08/18/20 17:21:45
8/18/20 17:21:53 WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=1, RSSI -49db
8/18/20 17:21:53 MDNS responder started for hostname IotaWatt
8/18/20 17:21:53 LLMNR responder started for hostname IotaWatt
8/18/20 17:21:53 Updater: service started. Auto-update class is MINOR
8/18/20 17:21:54 Updater: Auto-update is current for class MINOR.
8/18/20 17:22:47 historyLog: service started.
8/18/20 17:22:47 historyLog: Last log entry 08/18/20 17:21:00
8/18/20 17:29:13 Restart command received.
8/18/20 21:29:14z Real Time Clock is running. Unix time 1597786154
8/18/20 21:29:14z Reset reason: Software/System restart
8/18/20 21:29:14z Trace: 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:3, 1:4, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
8/18/20 21:29:14z ESP8266 ChipID: 6195317
8/18/20 21:29:14z IoTaWatt 5.0, Firmware version 02_05_09
8/18/20 21:29:14z SPIFFS mounted.
8/18/20 17:29:14 Local time zone: -5:00
8/18/20 17:29:14 Using Daylight Saving Time (BST) when in effect.
8/18/20 17:29:14 device name: IotaWatt
8/18/20 17:29:14 HTTP server started
8/18/20 17:29:14 timeSync: service started.
8/18/20 17:29:14 statService: started.
8/18/20 17:29:15 dataLog: service started.
8/18/20 17:29:15 dataLog: Last log entry 08/18/20 17:29:10
8/18/20 17:29:20 WiFi connected. SSID=ATT6AbiV3A, IP=192.168.1.100, channel=1, RSSI -70db
8/18/20 17:29:20 MDNS responder started for hostname IotaWatt
8/18/20 17:29:20 LLMNR responder started for hostname IotaWatt
8/18/20 17:29:20 Updater: service started. Auto-update class is MINOR
8/18/20 17:29:21 Updater: Auto-update is current for class MINOR.
8/18/20 17:30:14 historyLog: service started.
8/18/20 17:30:14 historyLog: Last log entry 08/18/20 17:29:00
