The basic gauge in Grafana now has the ability to set the neutral point wherever you want (version 9.3.1)
In practical terms this means that we can show import/export on the same gauge - without the colouring starting from the minimum point.
In this example the minimum is -9 the maximum +9 and the neutral set at 0.
The neutral doesn’t have to be a whole number, the max and min don’t have to be ‘matched’ evenly (though it is nicer if the neutral is at the top in my opinion)
I couldn’t find the neutral setting to begin with so did a search on the options on ‘neutral’ and it showed up - not sure if I missed it the first time or there was some caching from before I did the update to 9.3.1). Screenshot below shows where it should be (With Neutral set at zero)
