Hello,
Yesterday I noticed that my Iotowatt was not online. Went out to the garage and power cycled it and was met with a GRR error code.
Did some internetting, saw there was an issue with the newest update and SD cards. I pulled the original SD card and copied the contents to another SD card. Everything copied except \iotawatt\histlog.log for some reason.
Popped the new SD card in, Iotawatt came back to life, checked the webUI and it was recording power data. Looking at the log file, it looks like I’m still on Firmware 02-07-05 so I figured it was just a failing SD card.
Today after work I tried checking the webUI and it was not online again. Went out to the garage and power cycled and was met with a RRR code. Uh oh.
Again I disconnected the Iotawatt and pulled the SD card. Contents of the SD card are readable.
Timeline of events for the log file to make sense:
12/13/2022 @ 20:11 is when I reconnected the Iotawatt after changing out the SD card and it acted normally again.
12/13/2022 @ 22:28 is the last time Home Assistant saw any data from Iotawatt
12/14/2022 @ 18:00 is when I noticed that Iotawatt was offline again.
Here’s the relevant section of the log file:
12/14/22 00:10:57z Real Time Clock is running. Unix time 1670976657
12/14/22 00:10:57z Reset Reason: Power-fail restart.
12/14/22 00:10:57z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 00:10:57z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 00:10:57z SPIFFS mounted.
12/13/22 20:10:57 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 20:10:57 device name: IotaWatt
12/13/22 20:11:00 HTTP server started
12/13/22 20:11:00 WiFi connected. SSID=Phoebe, IP=192.168.1.6, channel=11, RSSI -55db
12/13/22 20:11:00 MDNS responder started for hostname IotaWatt
12/13/22 20:11:00 LLMNR responder started for hostname IotaWatt
12/13/22 20:11:00 timeSync: service started.
12/13/22 20:11:00 statService: started.
12/13/22 20:11:00 Updater: service started. Auto-update class is MAJOR
12/13/22 20:11:00 dataLog: service started.
12/13/22 20:11:01 dataLog: Last log entry 12/10/22 02:10:20
12/13/22 20:11:01 Updater: Auto-update is current for class MAJOR.
12/13/22 20:11:05 historyLog: service started.
12/13/22 20:11:05 historyLog: first entry 12/09/21 21:07:00
12/14/22 00:35:32z Real Time Clock is running. Unix time 1670978132
12/14/22 00:35:32z Reset reason: Software/System restart
12/14/22 00:35:32z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
12/14/22 00:35:32z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 00:35:32z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 00:35:32z SPIFFS mounted.
12/13/22 20:35:32 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 20:35:32 device name: IotaWatt
12/13/22 20:35:32 HTTP server started
12/13/22 20:35:32 timeSync: service started.
12/13/22 20:35:32 statService: started.
12/13/22 20:35:32 dataLog: service started.
12/13/22 20:35:33 dataLog: Last log entry 12/13/22 20:21:10
12/13/22 20:35:37 historyLog: service started.
12/13/22 20:35:37 historyLog: Last log entry 12/22/21 11:05:00
12/13/22 20:35:37 WiFi connected. SSID=Phoebe, IP=192.168.1.6, channel=11, RSSI -55db
12/13/22 20:35:37 MDNS responder started for hostname IotaWatt
12/13/22 20:35:37 LLMNR responder started for hostname IotaWatt
12/13/22 20:35:37 Updater: service started. Auto-update class is MAJOR
12/13/22 20:35:38 Updater: Auto-update is current for class MAJOR.
12/14/22 00:48:08z Real Time Clock is running. Unix time 1670978888
12/14/22 00:48:08z Reset reason: Software/System restart
12/14/22 00:48:08z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[8], 1:2[9], 9:0[9], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
12/14/22 00:48:08z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 00:48:08z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 00:48:08z SPIFFS mounted.
12/13/22 20:48:08 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 20:48:08 device name: IotaWatt
12/13/22 20:48:08 HTTP server started
12/13/22 20:48:08 timeSync: service started.
12/13/22 20:48:08 statService: started.
12/13/22 20:48:08 dataLog: service started.
12/13/22 20:48:09 dataLog: Last log entry 12/13/22 20:36:20
12/13/22 20:48:13 historyLog: service started.
12/13/22 20:48:13 historyLog: Last log entry 12/23/21 08:59:00
12/13/22 20:48:13 WiFi connected. SSID=Phoebe, IP=192.168.1.6, channel=11, RSSI -56db
12/13/22 20:48:13 MDNS responder started for hostname IotaWatt
12/13/22 20:48:13 LLMNR responder started for hostname IotaWatt
12/13/22 20:48:13 Updater: service started. Auto-update class is MAJOR
12/13/22 20:48:14 Updater: Auto-update is current for class MAJOR.
12/14/22 01:00:43z Real Time Clock is running. Unix time 1670979643
12/14/22 01:00:43z Reset reason: Software/System restart
12/14/22 01:00:43z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
12/14/22 01:00:43z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 01:00:43z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 01:00:43z SPIFFS mounted.
12/13/22 21:00:43 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 21:00:43 device name: IotaWatt
12/13/22 21:00:43 HTTP server started
12/13/22 21:00:43 timeSync: service started.
12/13/22 21:00:43 statService: started.
12/13/22 21:00:43 dataLog: service started.
12/13/22 21:00:44 dataLog: Last log entry 12/13/22 20:49:10
12/13/22 21:00:48 historyLog: service started.
12/13/22 21:00:48 historyLog: Last log entry 12/24/21 15:10:00
12/13/22 21:00:48 WiFi connected. SSID=Phoebe, IP=192.168.1.6, channel=11, RSSI -58db
12/14/22 01:05:57z Real Time Clock is running. Unix time 1670979957
12/14/22 01:05:57z Reset reason: Exception
12/14/22 01:05:57z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2
12/14/22 01:05:57z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 01:05:57z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 01:05:57z SPIFFS mounted.
12/13/22 21:05:57 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 21:05:57 device name: IotaWatt
12/13/22 21:05:57 HTTP server started
12/14/22 01:08:36z Real Time Clock is running. Unix time 1670980116
12/14/22 01:08:36z Reset Reason: Power-fail restart.
12/14/22 01:08:36z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 01:08:36z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 01:08:36z SPIFFS mounted.
12/13/22 21:08:36 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 21:08:36 device name: IotaWatt
12/13/22 21:08:39 HTTP server started
12/13/22 21:08:39 WiFi connected. SSID=Phoebe, IP=192.168.1.6, channel=11, RSSI -53db
12/13/22 21:08:39 MDNS responder started for hostname IotaWatt
12/13/22 21:08:39 LLMNR responder started for hostname IotaWatt
12/13/22 21:08:39 timeSync: service started.
12/13/22 21:08:39 statService: started.
12/13/22 21:08:39 Updater: service started. Auto-update class is MAJOR
12/13/22 21:08:39 dataLog: service started.
12/13/22 21:08:40 dataLog: Last log entry 12/13/22 21:00:45
12/13/22 21:08:42 Updater: Auto-update is current for class MAJOR.
12/13/22 21:08:44 historyLog: service started.
12/13/22 21:08:44 historyLog: Last log entry 12/24/21 15:10:00
12/14/22 01:35:23z Real Time Clock is running. Unix time 1670981723
12/14/22 01:35:23z Reset reason: Software/System restart
12/14/22 01:35:23z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4]
12/14/22 01:35:23z ESP8266 ID: 16295206, RTC PCF8523 (68)
12/14/22 01:35:23z IoTaWatt 5.0, Firmware version 02_07_05
12/14/22 01:35:23z SPIFFS mounted.
12/13/22 21:35:23 Local time zone: -4:00, using DST/BST when in effect.
12/13/22 21:35:23 device name: IotaWatt
12/13/22 21:35:23 HTTP server started
12/13/22 21:35:23 timeSync: service started.
12/13/22 21:35:23 statService: started.
12/13/22 21:35:23 dataLog: service started.
I currently have the Iotawatt unit on my desk plugged into a microUSB. It is currently flashing green and the webUI is reachable.
Any ideas?
Thank you!
