I think that I am OK now. I was using the latest SD card contents from the git, instead of the one for Firmware version 02_07_05. I was able to see a directory containing “iotamsgs.txt” on the Pana SD card, but not the supplied one. I downloaded the correct SD contents for the 02_07_07 FW.
Same result, but I decided to try a better power supply, one of my Raspberry Pi CanaKit units.
I now have a steady green LED and can access the status on the Android phone, Linux box and Win box.
My Order number is 126805, but now that I have it working, I am going to stick with this unit. I have my 230V VT on order so I can use it on a subpanel without a Neutral connection. (HVAC only)
Thanks, I’ll keep monitoring it with my temporary setup.
Greg
Real Time Clock not running.
Reset reason: External System
Trace: 216:125[238], 191:10[72], 194:251[46], 8:87[148], 184:175[57], 186:124[225], 43:63[246], 185:130[167], 135:54[186], 129:16[16], 112:90[208], 69:92[231], 142:176[86], 75:26[1], 10:146[83], 173:238[5], 122:225[181], 36:10[29], 124:225[62], 17:130[224], 2:79[24], 108:69[97], 117:240[251], 46:20[97], 168:103[31], 225:16[229], 93:13[177], 92:50[82], 63:20[134], 234:70[237], 1:191[170], 160:233[93]
ESP8266 ID: 15892855, RTC PCF8523 (68)
IoTaWatt 5.0, Firmware version 02_07_05
