Whenever I try to access the Graph+ or the Original Graph I keep getting the login prompt and no matter how many times I enter the correct credentials it keeps popping up. Am I missing something?
Thanks in advance!!
Thanks in advance!!
What version are you running?
Firmware Version: 02_05_02
That is fixed in release 02_05_03 which is making it’s way into general release. Right now it’s auto-update class ALPHA and BETA.
In the short term, you can set auto-update to BETA to get that release and then switch back to your current level in a month or so when it is in general release.
Or if you have a user password set, you can try using just the admin password and removing the user password.
The password enhancements in 02_05_03 are substantial and support both the admin and user as designed.
Thanks! That fixed it. Appreciate your help!
