I think you’re close. The Energy configuration uses the outputs of the Riemann sum integrations that you created in the YAML file, so Grid consumption should be import_wh_calculated and Return to grid should be export_wh_calculated.
Ok awesome- i just flipped them. Ready for a clean run tomorrow on these settings. Will screenshot the dashboard tomorrow after we start getting solar in.
Just one more thing. I don’t know if Hass sensor names are case-sensitive, your YAML integrations are all lower case source: names. The outputs from IoTaWatt have some upper case. Might be prudent to make those the same.
And while we are at it, heres the value of the export_wh_caculated you had me define in the YAML:
im a bit confused about why we need YAML config for 2 out of my 3 IoTaWatt outputs (we are missing the ‘Consumption’ one… actually checking my HASS config i dont believe ii even reference this anywhere? do i even need that output?)
Now that i know this works, ill go through and rename stuff to make it a bit more user-friendly to me (so i can remember what the hell we did here a year down the track).
thank you so much again! You have done your small part for the environment today my friend
