Hi,
I’ve been struggeling setting up the Home Assistant measured energy.
I have the exact setup like explained in the docs.
1 mains phase + 1 solar connected after the mains CT. (solar reduces measured flow on the mains CT)
For some reason now my export equals my import and I don’t understand why.
EDIT: Nevermind, I just noticed in my own screenshots that I made an error in the export output. It was set as “grid.net abs”, this should have been “grid.neg abs”.
Here you see a high peak in usage between 3:00 and 7:00.
This is my boiler that’s heating up at night. This should be all mains usage because there’s no sun yet at that point. But this is also measured in the export.
