I have what is probably a very simple question, I’m looking to calculate watts used in a given time period (most likely a month). Is there an easy way to do that without subscribing to influxDB or emoncms?
Assuming you want to know Watt Hours, you can get that with Graph+. Note also that if you actually did want Watts, the average for the period was 2.57 KW.
For periods longer than a day I recommend using units Wh:
Shows the Wh for each of the last 6 months. Divide by 1,000 to get kWh as in 720092.20 Wh = 720.1 kWh.
Thank you! I will give that a shot.
