Log snippet:
7/17/25 22:07:09z Real Time Clock is running. Unix time 1752790029
7/17/25 22:07:09z Reset reason: Software/System restart
7/17/25 22:07:09z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
7/17/25 22:07:09z ESP8266 ID: 15827424, RTC PCF8523 (68)
7/17/25 22:07:09z IoTaWatt 5.0, Firmware version 02_08_03
7/17/25 22:07:09z SPIFFS mounted.
7/17/25 18:07:09 Local time zone: -5:00, using DST/BST when in effect.
7/17/25 18:07:09 device name: IotaWatt
7/17/25 18:07:09 HTTP server started
7/17/25 18:07:09 timeSync: service started.
7/17/25 18:07:09 statService: started.
7/17/25 18:07:09 dataLog: service started.
7/17/25 18:07:12 dataLog: Last log entry 07/17/25 18:07:05
7/17/25 18:07:14 historyLog: service started.
7/17/25 18:07:15 historyLog: Last log entry 07/17/25 18:07:00
7/17/25 18:07:15 WiFi connected. SSID=NETGEAR22, IP=192.168.1.240, channel=11, RSSI -61db
7/17/25 18:07:15 Updater: service started. Auto-update class is MINOR
7/17/25 18:07:15 Heat: Started
7/17/25 18:07:16 Heat: Last log entry 07/17/25 18:07:05
7/17/25 18:07:17 Updater: Auto-update is current for class MINOR.
7/17/25 18:09:00 Heap memory has degraded below safe minimum, restarting.
7/17/25 22:09:01z Real Time Clock is running. Unix time 1752790141
7/17/25 22:09:01z Reset reason: Software/System restart
7/17/25 22:09:01z Trace: 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
7/17/25 22:09:01z ESP8266 ID: 15827424, RTC PCF8523 (68)
7/17/25 22:09:01z IoTaWatt 5.0, Firmware version 02_08_03
7/17/25 22:09:01z SPIFFS mounted.
7/17/25 18:09:01 Local time zone: -5:00, using DST/BST when in effect.
7/17/25 18:09:01 device name: IotaWatt
7/17/25 18:09:01 HTTP server started
7/17/25 18:09:01 timeSync: service started.
7/17/25 18:09:01 statService: started.
7/17/25 18:09:01 dataLog: service started.
7/17/25 18:09:04 dataLog: Last log entry 07/17/25 18:09:00
7/17/25 18:09:06 historyLog: service started.
7/17/25 18:09:07 historyLog: Last log entry 07/17/25 18:09:00
7/17/25 18:09:07 WiFi connected. SSID=NETGEAR22, IP=192.168.1.240, channel=11, RSSI -62db
7/17/25 18:09:07 Updater: service started. Auto-update class is MINOR
7/17/25 18:09:07 Heat: Started
7/17/25 18:09:08 Heat: Last log entry 07/17/25 18:09:00
7/17/25 18:09:09 Updater: Auto-update is current for class MINOR.
7/17/25 18:09:27 Heap memory has degraded below safe minimum, restarting.
7/17/25 22:09:28z Real Time Clock is running. Unix time 1752790168
7/17/25 22:09:28z Reset reason: Software/System restart
7/17/25 22:09:28z Trace: 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 10:13, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
7/17/25 22:09:28z ESP8266 ID: 15827424, RTC PCF8523 (68)
7/17/25 22:09:28z IoTaWatt 5.0, Firmware version 02_08_03
7/17/25 22:09:28z SPIFFS mounted.
7/17/25 18:09:28 Local time zone: -5:00, using DST/BST when in effect.
7/17/25 18:09:28 device name: IotaWatt
7/17/25 18:09:28 HTTP server started
7/17/25 18:09:28 timeSync: service started.
7/17/25 18:09:28 statService: started.
7/17/25 18:09:28 dataLog: service started.
7/17/25 18:09:31 dataLog: Last log entry 07/17/25 18:09:25
7/17/25 18:09:33 historyLog: service started.
7/17/25 18:09:34 historyLog: Last log entry 07/17/25 18:09:00
7/17/25 18:09:34 WiFi connected. SSID=NETGEAR22, IP=192.168.1.240, channel=11, RSSI -62db
7/17/25 18:09:34 Updater: service started. Auto-update class is MINOR
7/17/25 18:09:34 Updater: Auto-update is current for class MINOR.
7/17/25 18:09:34 Heat: Started
7/17/25 18:09:36 Heat: Last log entry 07/17/25 18:09:25
I’m not uploading anything. I do keep a browser tab pointed at Graph+, but that’s been the case more-or-less forever, and I do the same with two other IoTaWatt units in different locations and don’t have this kind of issue with them.
Any suggestions would be appreciated.
