Something seems to keep going wrong on one of my units:
7/31/21 22:49:50 influxDB_v2: Starting, interval:10, url:http://influx.my.com:8086/api/v2
7/31/21 22:49:50 timeSync: service started.
7/31/21 22:49:50 statService: started.
7/31/21 22:49:51 dataLog: service started.
7/31/21 22:49:51 dataLog: Last log entry 07/31/21 22:49:45
7/31/21 22:49:55 historyLog: service started.
7/31/21 22:49:55 historyLog: Last log entry 07/31/21 22:49:00
7/31/21 22:50:01 WiFi connected. SSID=SMRT, IP=10.59.55.139, channel=11, RSSI -87db
7/31/21 22:50:01 MDNS responder started for hostname IotaKit
7/31/21 22:50:01 LLMNR responder started for hostname IotaKit
7/31/21 22:50:01 Updater: service started. Auto-update class is MINOR
7/31/21 22:50:01 influxDB_v1: Authentication failed. Stopping influx service.
7/31/21 22:50:01 influxDB_v1: stopped, Last post 02/05/06 20:28:16
7/31/21 22:50:07 Updater: Auto-update is current for class MINOR.
7/31/21 22:51:08 influxDB_v2: Start posting 03/01/21 00:00:10
7/31/21 22:51:55 Heap memory has degraded below safe minimum, restarting.
8/01/21 08:51:56z Real Time Clock is running. Unix time 1627807916
8/01/21 08:51:56z Reset reason: Software/System restart
8/01/21 08:51:56z Trace: 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/01/21 08:51:56z ESP8266 ChipID: 12694594
8/01/21 08:51:56z IoTaWatt 5.0, Firmware version 02_06_02
8/01/21 08:51:56z SPIFFS mounted.
7/31/21 22:51:56 Local time zone: -10:00
7/31/21 22:51:56 device name: IotaKit
7/31/21 22:51:56 HTTP server started
7/31/21 22:51:56 influxDB_v1: Starting, interval:5, url:http://influx.my.com:8086
7/31/21 22:51:56 influxDB_v2: Starting, interval:10, url:http://influx.my.com:8086/api/v2
7/31/21 22:51:56 timeSync: service started.
7/31/21 22:51:56 statService: started.
7/31/21 22:51:57 dataLog: service started.
7/31/21 22:51:57 dataLog: Last log entry 07/31/21 22:51:55
7/31/21 22:52:01 historyLog: service started.
7/31/21 22:52:01 historyLog: Last log entry 07/31/21 22:51:00
7/31/21 22:52:06 WiFi connected. SSID=SMRT, IP=10.59.55.139, channel=11, RSSI -89db
7/31/21 22:52:06 MDNS responder started for hostname IotaKit
7/31/21 22:52:06 LLMNR responder started for hostname IotaKit
7/31/21 22:52:06 Updater: service started. Auto-update class is MINOR
7/31/21 22:52:06 influxDB_v1: Authentication failed. Stopping influx service.
7/31/21 22:52:06 influxDB_v1: stopped, Last post 02/05/06 20:28:16
7/31/21 22:52:06 Updater: Auto-update is current for class MINOR.
7/31/21 22:53:12 influxDB_v2: Start posting 03/01/21 00:00:10
7/31/21 22:53:44 Heap memory has degraded below safe minimum, restarting.
8/01/21 08:53:45z Real Time Clock is running. Unix time 1627808025
8/01/21 08:53:45z Reset reason: Software/System restart
8/01/21 08:53:45z Trace: 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[8], 31:5, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/01/21 08:53:45z ESP8266 ChipID: 12694594
8/01/21 08:53:45z IoTaWatt 5.0, Firmware version 02_06_02
8/01/21 08:53:45z SPIFFS mounted.
7/31/21 22:53:45 Local time zone: -10:00
7/31/21 22:53:45 device name: IotaKit
There are several other duplicate entries in the logs as well. Not sure if it keeps rebooting, but based on where it is on the upload process it looks unlikely. (It has uploaded from the beginning of the date range.)
