Just set everything up. Influxdb v2 is running on a server along with my webserver and icecast server.
My error
My setup
My error
My setup
The message says your server is returning 302 permanent redirect. That’s usually caused by the server requiring https. IoTaWatt posts using http. There are two solutions:
Configure your server to accept http.
Setup a HTTPS reverse proxy and add https:// to your URL.
The webserver and icecast servers are SSL not InfluxDB.
I added the port number after the IP and got a new error
The URI /orgs/7915f0f003d8a01d cannot be used. The IP:port should be sufficient to access the server.
overeasy,
I posted that URL in the browser to show that 10.0.0.13:8086 is not https. I’m not using that in the iotawatt config.
If i use just the ip in iotawatt config I get the 302 error, if I use the ip:port I get the 400 error.
This will require some investigation to try to recreate. If you want to pursue other solutions, you might try setting up the uploader using the default for field-key and removing the ct tag. If that works, I’d have a lot more to go on. If it doesn’t, I know there are users with that exact configuration so it would indicate a problem with your influxDB instance.
My pcap…
Not sure if this helps but it looks like Influx can’t find the organization…so could be on that end for me.
FROM IOTAWATT host:10.0.0.13:8086 content-type:application/vnd.flux Authorization:Token J_nPpj3rvEu08UxcPsF7CMYDQZr8IfCtMhCaTKSIPw8oRD2mikdWZS6PhquQaoKN7x_9Oeh6RIGa1hLAFmC0XA== Content-Length:318 from(bucket: "uwpltd") |> range(start: 1629377270, stop: 1629380870) |> filter(fn: (r) => r["device"] == "iotawatt" and (r["_measurement"] == "Total_Power")) |> last() |> map(fn: (r) => ({_measurement: r._measurement, _time: (uint(v:r._time)) / uint(v:1000000000)})) |> sort (columns: ["_time"], desc: true) RESPONSE HTTP/1.1 400 Bad Request Content-Type: application/json; charset=utf-8 Vary: Accept-Encoding X-Platform-Error-Code: invalid Date: Thu, 19 Aug 2021 13:47:52 GMT Content-Length: 84 {"code":"invalid","message":"failed to decode request body: organization not found"}
Ok its fixed. InfluxDb was setup correctly. I restarted the iotawatt device and it connected with no error.
Thanks for help
