Thanks Bob.
Connection is up and managed via VPN
My message log is downloading now (11.2Mb) I can include a snippet from the last of the log
"2/01/20 16:54:37z timeSync: service started.
2/01/20 16:54:38z statService: started.
2/01/20 16:54:38z Updater: service started. Auto-update class is MAJOR
2/01/20 16:54:39z dataLog: service started.
2/01/20 16:54:51z dataLog: Last log entry 02/01/20 16:53:50
2/01/20 16:54:51z Updater: Update from 02_04_02 to 02_05_02
2/01/20 16:54:52z Updater: download 02_05_02
2/01/20 16:55:09z Updater: Release downloaded 15840ms, size 762848
2/01/20 16:55:17z Updater: signature verified
2/01/20 16:55:24z Updater: firmware upgraded to version 02_05_02
2/01/20 16:55:24z Updater: Firmware updated, restarting.
2/01/20 16:55:31z Real Time Clock is running. Unix time 1580576131
2/01/20 16:55:31z Reset reason: Software/System restart
2/01/20 16:55:32z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:7
2/01/20 16:55:33z ESP8266 ChipID: 2518062
2/01/20 16:55:34z IoTaWatt 4.x, Firmware version 02_05_02
2/01/20 16:55:34z Updater: Installing update files for version 02_05_02
2/01/20 16:55:35z Updater: Installing GRAPH.JS
2/01/20 16:55:36z Updater: Installing GRAPH2.HTM
2/01/20 16:55:42z Updater: Installing GRAPH2.JS
2/01/20 16:55:48z Updater: Installing INDEX.HTM
2/01/20 16:55:53z Updater: Installing TABLES.TXT
2/01/20 16:55:53z Updater: Installing CNFSTYLE.CSS
2/01/20 16:55:54z Updater: Installing EDIT.HTM
2/01/20 16:55:55z Updater: Installing GRAPH.HTM
2/01/20 16:55:57z Updater: Installation complete.
2/01/20 16:55:57z SPIFFS mounted.
2/01/20 16:55:59z Local time zone: +0:00
2/01/20 16:55:59z device name: JohnFitz
2/01/20 16:56:00z MDNS responder started for hostname JohnFitz
2/01/20 16:56:00z LLMNR responder started for hostname JohnFitz
2/01/20 16:56:01z HTTP server started
2/01/20 16:56:02z WiFi connected. SSID=DCSIXBH24, IP=192.168.8.184, channel=2, RSSI -64db
2/01/20 16:56:02z timeSync: service started.
2/01/20 16:56:03z statService: started.
2/01/20 16:56:03z Updater: service started. Auto-update class is MAJOR
2/01/20 16:56:04z dataLog: service started.
2/01/20 16:56:22z dataLog: Last log entry 02/01/20 16:55:05
2/01/20 16:56:23z Updater: Auto-update is current for class MAJOR.
2/01/20 16:57:04z historyLog: service started.
2/01/20 16:57:14z historyLog: Last log entry 02/01/20 00:05:00
2/01/20 19:55:12z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=5
2/01/20 19:55:17z influxDB: Start posting at 12/30/19 18:46:05
2/01/20 19:56:05z influxDB: Restart. Last post 12/30/19 18:46:20
2/01/20 19:56:06z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=5
2/01/20 19:56:10z influxDB: Start posting at 12/30/19 18:46:25
2/01/20 19:58:24z influxDB: Restart. Last post 12/30/19 18:48:20
2/01/20 19:58:25z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=10
2/01/20 19:58:29z influxDB: Start posting at 12/30/19 18:48:30
2/03/20 03:59:45z Updater: Invalid response from server. HTTPcode: -4
2/03/20 04:16:35z influxDB: Post Failed: -4
2/06/20 09:56:43z Real Time Clock is running. Unix time 1580983003
2/06/20 09:56:43z Power failure detected.
2/06/20 09:56:44z Reset reason: Power on
2/06/20 09:56:44z ESP8266 ChipID: 2518062
2/06/20 09:56:44z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 09:56:45z SPIFFS mounted.
2/06/20 09:56:46z Local time zone: +0:00
2/06/20 09:56:47z device name: JohnFitz
2/06/20 09:56:50z Connecting with WiFiManager.
2/06/20 10:00:08z Real Time Clock is running. Unix time 1580983208
2/06/20 10:00:08z Reset reason: Hardware Watchdog
2/06/20 10:00:09z Trace: 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 11:8, 11:9, 16:0, 11:10, 17:0, 17:0, 17:0, 17:4, 17:5, 17:7, 17:7, 17:7, 17:7, 17:8, 17:9, 17:10, 11:11, 11:12
2/06/20 10:00:11z ESP8266 ChipID: 2518062
2/06/20 10:00:11z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 10:00:11z SPIFFS mounted.
2/06/20 10:00:13z Local time zone: +0:00
2/06/20 10:00:13z device name: JohnFitz
2/06/20 10:00:14z MDNS responder started for hostname JohnFitz
2/06/20 10:00:15z LLMNR responder started for hostname JohnFitz
2/06/20 10:00:15z HTTP server started
2/06/20 10:00:16z WiFi connected. SSID=DCSIXBH24, IP=192.168.8.184, channel=6, RSSI -61db
2/06/20 10:00:17z timeSync: service started.
2/06/20 10:00:24z statService: started.
2/06/20 10:00:25z Updater: service started. Auto-update class is MAJOR
2/06/20 10:00:26z dataLog: service started.
2/06/20 10:00:43z dataLog: Last log entry 02/06/20 09:40:30
2/06/20 10:00:44z Updater: Invalid response from server. HTTPcode: -4
2/06/20 10:00:45z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=10
2/06/20 10:01:30z historyLog: service started.
2/06/20 10:01:40z historyLog: Last log entry 02/06/20 09:40:00
2/06/20 10:08:29z influxDB: last entry query failed: -4, retrying.
2/06/20 15:26:41z Real Time Clock is running. Unix time 1581002801
2/06/20 15:26:41z Power failure detected.
2/06/20 15:26:42z Reset reason: Power on
2/06/20 15:26:42z ESP8266 ChipID: 2518062
2/06/20 15:26:42z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 15:26:43z SPIFFS mounted.
2/06/20 15:26:44z Local time zone: +0:00
2/06/20 15:26:45z device name: JohnFitz
2/06/20 15:26:48z Connecting with WiFiManager.
2/06/20 15:30:07z Real Time Clock is running. Unix time 1581003007
2/06/20 15:30:07z Reset reason: Hardware Watchdog
2/06/20 15:30:08z Trace: 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 15:0[6], 15:2[6], 15:3, 11:8, 11:9, 16:0, 11:10, 17:0, 17:0, 17:0, 17:4, 17:5, 17:7, 17:7, 17:7, 17:7, 17:8, 17:9, 17:10, 11:11, 11:12
2/06/20 15:30:10z ESP8266 ChipID: 2518062
2/06/20 15:30:10z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 15:30:10z SPIFFS mounted.
2/06/20 15:30:12z Local time zone: +0:00
2/06/20 15:30:12z device name: JohnFitz
2/06/20 15:30:13z MDNS responder started for hostname JohnFitz
2/06/20 15:30:14z LLMNR responder started for hostname JohnFitz
2/06/20 15:30:14z HTTP server started
2/06/20 15:30:15z WiFi connected. SSID=DCSIXBH24, IP=192.168.8.184, channel=6, RSSI -61db
2/06/20 15:30:16z timeSync: service started.
2/06/20 15:30:23z statService: started.
2/06/20 15:30:23z Updater: service started. Auto-update class is MAJOR
2/06/20 15:30:25z dataLog: service started.
2/06/20 15:30:45z dataLog: Last log entry 02/06/20 13:11:45
2/06/20 15:30:45z Updater: Invalid response from server. HTTPcode: -4
2/06/20 15:30:46z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=10
2/06/20 15:31:29z historyLog: service started.
2/06/20 15:31:39z historyLog: Last log entry 02/06/20 13:11:00
2/06/20 15:34:21z influxDB: Start posting at 01/08/20 18:46:40
2/06/20 16:08:16z dataLog: datalog WDT - restarting
2/06/20 16:08:18z Real Time Clock is running. Unix time 1581005298
2/06/20 16:08:18z Reset reason: Software/System restart
2/06/20 16:08:19z Trace: 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:2, 18:3, 18:4, 18:5, 1:6, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19]
2/06/20 16:08:20z ESP8266 ChipID: 2518062
2/06/20 16:08:21z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 16:08:21z SPIFFS mounted.
2/06/20 16:08:23z Local time zone: +0:00
2/06/20 16:08:23z device name: JohnFitz
2/06/20 16:08:23z MDNS responder started for hostname JohnFitz
2/06/20 16:08:24z LLMNR responder started for hostname JohnFitz
2/06/20 16:08:25z HTTP server started
2/06/20 16:08:25z WiFi connected. SSID=DCSIXBH24, IP=192.168.8.184, channel=6, RSSI -61db
2/06/20 16:08:26z timeSync: service started.
2/06/20 16:08:27z statService: started.
2/06/20 16:08:27z Updater: service started. Auto-update class is MAJOR
2/06/20 16:08:28z dataLog: service started.
2/06/20 16:08:47z dataLog: Last log entry 02/06/20 16:07:45
2/06/20 16:08:48z Updater: Auto-update is current for class MAJOR.
2/06/20 16:08:49z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=10
2/06/20 16:08:54z influxDB: Start posting at 01/08/20 19:47:40
2/06/20 16:09:41z dataLog: datalog WDT - restarting
2/06/20 16:09:42z Real Time Clock is running. Unix time 1581005382
2/06/20 16:09:42z Reset reason: Software/System restart
2/06/20 16:09:43z Trace: 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:71, 7:7, 7:7, 1:6, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:13
2/06/20 16:09:44z ESP8266 ChipID: 2518062
2/06/20 16:09:45z IoTaWatt 4.x, Firmware version 02_05_02
2/06/20 16:09:45z SPIFFS mounted.
2/06/20 16:09:47z Local time zone: +0:00
2/06/20 16:09:47z device name: JohnFitz
2/06/20 16:09:48z MDNS responder started for hostname JohnFitz
2/06/20 16:09:48z LLMNR responder started for hostname JohnFitz
2/06/20 16:09:49z HTTP server started
2/06/20 16:09:50z WiFi connected. SSID=DCSIXBH24, IP=192.168.8.184, channel=6, RSSI -63db
2/06/20 16:09:50z timeSync: service started.
2/06/20 16:09:51z statService: started.
2/06/20 16:09:52z Updater: service started. Auto-update class is MAJOR
2/06/20 16:09:53z dataLog: service started.
2/06/20 16:10:14z dataLog: Last log entry 02/06/20 16:09:10
2/06/20 16:10:15z Updater: Auto-update is current for class MAJOR.
2/06/20 16:10:16z influxDB: started, url=192.168.2.187:8086, db=JohnFitzFrm, interval=10
2/06/20 16:10:22z influxDB: Start posting at 01/08/20 19:47:40
2/06/20 16:10:55z historyLog: service started.
2/06/20 16:11:05z historyLog: Last log entry 02/06/20 16:07:00"
Hope this helps, you will see some failed writes as I intentionally renamed the DB to verify that it was in fact writing to influx
The Data seems spot on and I am bringing back 18 measurands.
Thanks,
J
