Hi @overeasy – just wanted to report an influx bug in 2_05_07 – I rolled back to major _02 and its working again.
4/20/20 20:47:42z Updater: Update from 02_05_02 to 02_05_07
4/20/20 20:47:42z Updater: download 02_05_07
4/20/20 20:48:03z Updater: Release downloaded 20913ms, size 803168
4/20/20 20:48:20z Updater: signature verified
4/20/20 20:48:27z Updater: firmware upgraded to version 02_05_07
4/20/20 20:48:28z Updater: Firmware updated, restarting.
4/20/20 20:48:36z Real Time Clock is running. Unix time 1587415716
4/20/20 20:48:36z Reset reason: Software/System restart
4/20/20 20:48:36z Trace: 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[19], 1:6, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:4, 1:5[5], 5:0, 5:7
4/20/20 20:48:36z ESP8266 ChipID: 6920629
4/20/20 20:48:36z IoTaWatt 4.x, Firmware version 02_05_07
4/20/20 20:48:36z Updater: Installing update files for version 02_05_07
4/20/20 20:48:36z Updater: Installing EDIT.HTM
4/20/20 20:48:36z Updater: Installing GRAPH.HTM
4/20/20 20:48:37z Updater: Installing GRAPH.JS
4/20/20 20:48:37z Updater: Installing GRAPH2.HTM
4/20/20 20:48:38z Updater: Installing GRAPH2.JS
4/20/20 20:48:39z Updater: Installing INDEX.HTM
4/20/20 20:48:41z Updater: Installing TABLES.TXT
4/20/20 20:48:41z Updater: Installing CNFSTYLE.CSS
4/20/20 20:48:41z Updater: Installation complete.
4/20/20 20:48:41z SPIFFS mounted.
4/20/20 20:48:42z EmonService: Invalid configuration.
4/20/20 20:48:42z Local time zone: +0:00
4/20/20 20:48:42z device name: IotaWatt
4/20/20 20:48:42z HTTP server started
4/20/20 20:48:42z timeSync: service started.
4/20/20 20:48:42z statService: started.
4/20/20 20:48:42z dataLog: service started.
4/20/20 20:48:45z dataLog: Last log entry 04/20/20 20:48:00
4/20/20 20:48:45z historyLog: service started.
4/20/20 20:48:46z historyLog: Last log entry 04/20/20 20:47:00
4/20/20 20:48:47z influxDB: started, url=HTTP://<INFLUX>/, db=power, interval=10
4/20/20 20:48:47z WiFi connected. SSID=<SSID>, IP=<IP>, channel=11, RSSI -82db
4/20/20 20:48:47z MDNS responder started for hostname IotaWatt
4/20/20 20:48:47z LLMNR responder started for hostname IotaWatt
4/20/20 20:48:47z Updater: service started. Auto-update class is MINOR
4/20/20 20:48:48z influxDB: Last entry query failed.
4/20/20 20:48:48z influxDB: HTTPcode 404, 404 page not found
4/20/20 20:48:48z influxDB: Stopped. Last post 01/06/18 00:00:00
4/20/20 20:48:49z Updater: Auto-update is current for class MINOR.
4/22/20 23:54:15z Updater: Invalid response from server. HTTPcode: -11
4/23/20 00:01:37z WiFi disconnected.
4/23/20 00:01:38z WiFi connected. SSID=<SSID>, IP=<IP>, channel=11, RSSI -83db
4/23/20 00:05:08z EmonService: Invalid configuration.
4/23/20 00:05:08z influxDB: started, url=HTTP://<INFLUX_SERVER>/, db=power, interval=10
4/23/20 00:05:09z influxDB: Last entry query failed.
4/23/20 00:05:09z influxDB: HTTPcode 404, 404 page not found
4/23/20 00:05:09z influxDB: Stopped. Last post 01/06/18 00:00:00
4/23/20 00:07:53z EmonService: Invalid configuration.
4/23/20 00:07:53z influxDB: started, url=HTTP://<INFLUX_SERVER>/, db=power, interval=10
4/23/20 00:07:53z influxDB: Last entry query failed.
4/23/20 00:07:53z influxDB: HTTPcode 404, 404 page not found
4/23/20 00:07:53z influxDB: Stopped. Last post 04/20/20 00:00:00
4/23/20 00:09:00z EmonService: Invalid configuration.
4/23/20 00:09:00z influxDB: started, url=HTTP://<INFLUX_SERVER>/, db=power, interval=10
4/23/20 00:09:00z influxDB: Last entry query failed.
4/23/20 00:09:00z influxDB: HTTPcode 404, 404 page not found
4/23/20 00:09:00z influxDB: Stopped. Last post 04/20/20 00:00:00
4/23/20 00:10:54z EmonService: Invalid configuration.
4/23/20 00:10:54z influxDB: started, url=HTTP://<INFLUX_SERVER>/, db=power, interval=10
4/23/20 00:10:54z influxDB: Last entry query failed.
4/23/20 00:10:54z influxDB: HTTPcode 404, 404 page not found
4/23/20 00:10:54z influxDB: Stopped. Last post 04/20/20 00:00:00
4/23/20 00:11:35z EmonService: Invalid configuration.
4/23/20 00:11:36z influxDB: started, url=HTTP://<INFLUX_SERVER>/, db=power, interval=10
4/23/20 00:11:36z influxDB: Last entry query failed.
4/23/20 00:11:36z influxDB: HTTPcode 404, 404 page not found
4/23/20 00:11:36z influxDB: Stopped. Last post 04/20/20 00:00:00
4/23/20 00:12:26z EmonService: Invalid configuration.
4/23/20 00:14:06z EmonService: Invalid configuration.
4/23/20 00:14:33z Restart command received.
I can attach the config as well if its useful, but the “404” suggests to me something else is going on. I haven’t done a packet capture there yet, letting it do a backfill of the last few days it missed.
Let me know if there is something specific that would be helpful!
