from IWsolr:
8/06/22 00:42:52z Real Time Clock is running. Unix time 1659746572
8/06/22 00:42:52z Reset reason: Software/System restart
8/06/22 00:42:52z Trace: 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:5, 34:5, 34:5, 34:6[1], 34:10[3], 34:5, 34:5, 34:5, 34:6[1], 34:10, 32:101, 32:101, 32:102, 32:103, 32:103, 31:105, 31:105, 31:106, 11:45, 11:50, 11:55, 11:70
8/06/22 00:42:52z ESP8266 ID: 16295187, RTC PCF8523 (68)
8/06/22 00:42:52z IoTaWatt 5.0, Firmware version 02_07_05
8/06/22 00:42:52z SPIFFS mounted.
8/05/22 19:42:52 Local time zone: -5:00
8/05/22 19:42:52 device name: IWsolr
8/05/22 19:42:52 HTTP server started
8/05/22 19:42:52 influxDB_v1: Starting, interval:5, url:http://influxdb-iot.tabris.net:8086
8/05/22 19:42:52 timeSync: service started.
8/05/22 19:42:52 statService: started.
8/05/22 19:42:52 dataLog: service started.
8/05/22 19:42:53 dataLog: Last log entry 08/05/22 19:40:25
8/05/22 19:42:54 historyLog: service started.
8/05/22 19:42:54 historyLog: Last log entry 08/05/22 19:40:00
8/05/22 19:45:39 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=11, RSSI -71db
8/05/22 19:45:39 MDNS responder started for hostname IWsolr
8/05/22 19:45:39 LLMNR responder started for hostname IWsolr
8/05/22 19:45:39 Updater: service started. Auto-update class is NONE
8/05/22 20:02:31 influxDB_v1: Start posting at 08/03/22 18:57:40
8/16/22 13:15:18 WiFi disconnected.
8/16/22 13:15:42 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=6, RSSI -70db
8/16/22 13:37:29 WiFi disconnected.
8/16/22 13:37:50 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=6, RSSI -72db
8/17/22 06:07:05 WiFi disconnected.
8/17/22 06:07:14 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=1, RSSI -72db
8/17/22 06:14:43 WiFi disconnected.
8/17/22 06:18:10 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=6, RSSI -70db
8/21/22 09:56:07 WiFi disconnected.
8/21/22 09:56:32 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=6, RSSI -70db
9/16/22 20:07:22 timeSync: Six week routine restart.
9/17/22 01:07:23z Real Time Clock is running. Unix time 1663376843
9/17/22 01:07:23z Reset reason: Software/System restart
9/17/22 01:07:23z Trace: 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
9/17/22 01:07:23z ESP8266 ID: 16295187, RTC PCF8523 (68)
9/17/22 01:07:23z IoTaWatt 5.0, Firmware version 02_07_05
9/17/22 01:07:23z SPIFFS mounted.
9/16/22 20:07:23 Local time zone: -5:00
9/16/22 20:07:23 device name: IWsolr
9/16/22 20:07:23 HTTP server started
9/16/22 20:07:23 influxDB_v1: Starting, interval:5, url:http://influxdb-iot.tabris.net:8086
9/16/22 20:07:23 timeSync: service started.
9/16/22 20:07:23 statService: started.
9/16/22 20:07:23 dataLog: service started.
9/16/22 20:07:24 dataLog: Last log entry 09/16/22 20:07:20
9/16/22 20:07:24 historyLog: service started.
9/16/22 20:07:25 historyLog: Last log entry 09/16/22 20:07:00
9/16/22 20:07:28 WiFi connected. SSID=IoTnet, IP=192.168.82.53, channel=6, RSSI -69db
9/16/22 20:07:28 MDNS responder started for hostname IWsolr
9/16/22 20:07:28 LLMNR responder started for hostname IWsolr
9/16/22 20:07:28 Updater: service started. Auto-update class is NONE
From IWbsmt
8/06/22 00:45:42z Real Time Clock is running. Unix time 1659746742
8/06/22 00:45:42z Reset Reason: Power-fail restart.
8/06/22 00:45:42z ESP8266 ID: 16274938, RTC PCF8523 (68)
8/06/22 00:45:42z IoTaWatt 5.0, Firmware version 02_07_05
8/06/22 00:45:42z SPIFFS mounted.
8/05/22 20:45:43 Local time zone: -5:00, using DST/BST when in effect.
8/05/22 20:45:43 device name: IWbsmt
8/05/22 20:45:46 Connecting with WiFiManager.
8/05/22 20:45:49 HTTP server started
8/05/22 20:45:49 influxDB_v1: Starting, interval:5, url:http://influxdb-iot.tabris.net:8086
8/05/22 20:45:49 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=11, RSSI -61db
8/05/22 20:45:49 MDNS responder started for hostname IWbsmt
8/05/22 20:45:49 LLMNR responder started for hostname IWbsmt
8/05/22 20:45:49 timeSync: service started.
8/05/22 20:45:49 statService: started.
8/05/22 20:45:49 Updater: service started. Auto-update class is NONE
8/05/22 20:45:49 dataLog: service started.
8/05/22 20:45:50 dataLog: Last log entry 08/03/22 21:35:05
8/05/22 20:45:54 historyLog: service started.
8/05/22 20:45:54 historyLog: Last log entry 08/03/22 21:35:00
8/05/22 21:07:50 influxDB_v1: Start posting at 08/03/22 19:57:55
8/16/22 14:16:42 WiFi disconnected.
8/16/22 14:18:45 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=11, RSSI -94db
8/16/22 14:37:29 WiFi disconnected.
8/16/22 14:38:01 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=11, RSSI -62db
8/21/22 10:56:07 WiFi disconnected.
8/21/22 10:56:58 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=11, RSSI -93db
8/21/22 21:39:51 WiFi disconnected.
8/21/22 21:40:08 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=1, RSSI -67db
9/16/22 21:06:22 timeSync: Six week routine restart.
9/17/22 01:06:23z Real Time Clock is running. Unix time 1663376783
9/17/22 01:06:23z Reset reason: Software/System restart
9/17/22 01:06:23z Trace: 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:1, 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
9/17/22 01:06:23z ESP8266 ID: 16274938, RTC PCF8523 (68)
9/17/22 01:06:23z IoTaWatt 5.0, Firmware version 02_07_05
9/17/22 01:06:23z SPIFFS mounted.
9/16/22 21:06:23 Local time zone: -5:00, using DST/BST when in effect.
9/16/22 21:06:23 device name: IWbsmt
9/16/22 21:06:23 HTTP server started
9/16/22 21:06:23 influxDB_v1: Starting, interval:5, url:http://influxdb-iot.tabris.net:8086
9/16/22 21:06:23 timeSync: service started.
9/16/22 21:06:23 statService: started.
9/16/22 21:06:23 dataLog: service started.
9/16/22 21:06:25 dataLog: Last log entry 09/16/22 21:06:20
9/16/22 21:06:28 historyLog: service started.
9/16/22 21:06:28 historyLog: Last log entry 09/16/22 21:06:00
9/16/22 21:06:28 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=1, RSSI -65db
9/16/22 21:06:28 MDNS responder started for hostname IWbsmt
9/16/22 21:06:28 LLMNR responder started for hostname IWbsmt
9/16/22 21:06:29 Updater: service started. Auto-update class is NONE
9/16/22 21:25:10 Restart command received.
9/17/22 01:25:12z Real Time Clock is running. Unix time 1663377912
9/17/22 01:25:12z Reset reason: Software/System restart
9/17/22 01:25:12z Trace: 1:3, 1:1[4], 1:2[5], 9:0[5], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
9/17/22 01:25:12z ESP8266 ID: 16274938, RTC PCF8523 (68)
9/17/22 01:25:12z IoTaWatt 5.0, Firmware version 02_07_05
9/17/22 01:25:12z SPIFFS mounted.
9/16/22 21:25:12 Local time zone: -5:00, using DST/BST when in effect.
9/16/22 21:25:12 device name: IWbsmt
9/16/22 21:25:12 HTTP server started
9/16/22 21:25:12 influxDB_v1: Starting, interval:5, url:http://influxdb-iot.tabris.net:8086
9/16/22 21:25:12 timeSync: service started.
9/16/22 21:25:12 statService: started.
9/16/22 21:25:12 dataLog: service started.
9/16/22 21:25:14 dataLog: Last log entry 09/16/22 21:25:10
9/16/22 21:25:17 historyLog: service started.
9/16/22 21:25:17 historyLog: Last log entry 09/16/22 21:25:00
9/16/22 21:25:17 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=1, RSSI -65db
9/16/22 21:25:17 MDNS responder started for hostname IWbsmt
9/16/22 21:25:17 LLMNR responder started for hostname IWbsmt
9/16/22 21:25:17 Updater: service started. Auto-update class is NONE
9/16/22 21:36:57 WiFi disconnected.
9/16/22 21:37:04 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=1, RSSI -78db
9/16/22 21:57:49 WiFi disconnected.
9/16/22 21:57:51 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=1, RSSI -77db
9/16/22 21:59:26 WiFi disconnected.
9/16/22 21:59:30 WiFi connected. SSID=IoTnet, IP=192.168.82.50, channel=11, RSSI -52db
9/16/22 22:02:07 influxDB_v1: stopped, Last post 09/16/22 21:06:10
This is also the latest log message from this unit.
