InfluxDB_v2 uploader stopped working after 6 week routine restart on 12/29/21
Log:
11/17/21 21:47:57z Real Time Clock is running. Unix time 1637185677
11/17/21 21:47:57z Reset reason: Software/System restart
11/17/21 21:47:57z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3
11/17/21 21:47:57z ESP8266 ID: 2517697, RTC PCF8523
11/17/21 21:47:57z IoTaWatt 4.x, Firmware version 02_07_04
11/17/21 21:47:57z Updater: Installing update files for version 02_07_04
11/17/21 21:47:57z Updater: Installing FAVICON.ICO
11/17/21 21:47:57z Updater: Installing GRAPH.HTM
11/17/21 21:47:57z Updater: Installing GRAPH.JS
11/17/21 21:47:57z Updater: Installing GRAPH2.HTM
11/17/21 21:47:57z Updater: Installing GRAPH2.JS
11/17/21 21:47:58z Updater: Installing INDEX.HTM
11/17/21 21:47:58z Updater: Installing TABLES.TXT
11/17/21 21:47:58z Updater: Installing CNFSTYLE.CSS
11/17/21 21:47:58z Updater: Installing EDIT.HTM
11/17/21 21:47:59z Updater: Installation complete.
11/17/21 21:47:59z SPIFFS mounted.
11/17/21 22:47:59 Local time zone: +1:00, using DST/BST when in effect.
11/17/21 22:47:59 device name: strom1
11/17/21 22:47:59 HTTP server started
11/17/21 22:47:59 influxDB_v1: Starting, interval:10, url:http://192.168.1.120:8086
11/17/21 22:47:59 influxDB_v2: Starting, interval:10, url:http://192.168.1.120:38086
11/17/21 22:47:59 timeSync: service started.
11/17/21 22:47:59 statService: started.
11/17/21 22:47:59 dataLog: service started.
11/17/21 22:48:01 dataLog: Last log entry 11/17/21 22:47:30
11/17/21 22:48:04 historyLog: service started.
11/17/21 22:48:04 historyLog: Last log entry 11/17/21 22:47:00
11/17/21 22:48:04 WiFi connected. SSID=***, IP=192.168.1.145, channel=6, RSSI -49db
11/17/21 22:48:04 MDNS responder started for hostname strom1
11/17/21 22:48:04 LLMNR responder started for hostname strom1
11/17/21 22:48:04 Updater: service started. Auto-update class is NONE
11/17/21 22:48:06 influxDB_v1: Start posting at 11/17/21 22:47:10
11/17/21 22:48:30 influxDB_v2: stopped, Last post 01/01/70 01:00:00
11/17/21 22:55:18 influxDB_v2: stopped, Last post 01/01/70 01:00:00
11/17/21 22:56:44 influxDB_v2: stopped, Last post 01/01/70 01:00:00
11/17/21 22:56:53 influxDB_v2: Resume posting 11/05/21 14:16:30
12/29/21 22:49:03 timeSync: Six week routine restart.
12/29/21 21:49:05z Real Time Clock is running. Unix time 1640814545
12/29/21 21:49:05z Reset reason: Software/System restart
12/29/21 21:49:05z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
12/29/21 21:49:05z ESP8266 ID: 2517697, RTC PCF8523
12/29/21 21:49:05z IoTaWatt 4.x, Firmware version 02_07_04
12/29/21 21:49:05z SPIFFS mounted.
12/29/21 22:49:05 Local time zone: +1:00, using DST/BST when in effect.
12/29/21 22:49:05 device name: strom1
12/29/21 22:49:05 HTTP server started
12/29/21 22:49:05 influxDB_v1: Starting, interval:10, url:http://192.168.1.120:8086
12/29/21 22:49:05 influxDB_v2: Starting, interval:10, url:http://192.168.1.120:38086
12/29/21 22:49:05 timeSync: service started.
12/29/21 22:49:05 statService: started.
12/29/21 22:49:05 dataLog: service started.
12/29/21 22:49:08 dataLog: Last log entry 12/29/21 22:49:00
12/29/21 22:49:10 historyLog: service started.
12/29/21 22:49:10 historyLog: Last log entry 12/29/21 22:49:00
12/29/21 22:49:10 WiFi connected. SSID=***, IP=192.168.1.145, channel=6, RSSI -50db
12/29/21 22:49:10 MDNS responder started for hostname strom1
12/29/21 22:49:10 LLMNR responder started for hostname strom1
12/29/21 22:49:10 Updater: service started. Auto-update class is NONE
12/29/21 22:49:26 influxDB_v1: Start posting at 12/29/21 22:49:00
I also tried firmware 02_07_05
InfluxDB Version 2.1.1
I have two iotawatt devices. both have the same issue.
Does anyone have the same issue?
