Hi,
I just got the iotaWatt wired and setting up the software and it is not clear on how the software should be setup for the CT’s. I did not have enough CT’s for everything so I placed the two 200 amp clamps on the two bus bars, and my Air Conditioner I only put a CT on a single leg. So when configure these CT’s for the mains do I select double since it is 240 that comes into the house or leave that un-checked? For the Air conditioner it is 240 with two breakers with a single CT so do I select double on that one as well? It is not clear when to select double, is that basically doubling the value or just doubling the voltage for 120v systems here in the U.S?
I also have two 100 am clamps for solar panels feeding into the panel.
thanks.
