Hey there overeasy. I hope this helps.
![image](https://community.iotawatt.com/uploads/db6340/original/2X/f/f89e17c689655b2e787085bcf11459db42ba9575.png)
9/15/23 02:29:29z Reset reason: Software/System restart
9/15/23 02:29:29z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[3], 1:2[4], 9:0[4], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
9/15/23 02:29:29z ESP8266 ID: 6735387, RTC PCF8523 (68)
9/15/23 02:29:29z IoTaWatt 5.0, Firmware version 02_07_05
9/15/23 02:29:29z SPIFFS mounted.
9/15/23 12:29:30 Local time zone: +10:00
9/15/23 12:29:30 device name: IotaWatt
9/15/23 12:29:30 HTTP server started
9/15/23 12:29:30 timeSync: service started.
9/15/23 12:29:30 statService: started.
9/15/23 12:29:30 dataLog: service started.
9/15/23 12:29:32 dataLog: Last log entry 09/15/23 12:29:25
9/15/23 12:29:35 historyLog: service started.
9/15/23 12:29:35 historyLog: Last log entry 09/15/23 12:29:00
9/15/23 12:29:35 Battery_cab: Started
9/15/23 12:29:36 Battery_cab: Last log entry 09/15/23 12:29:25
9/15/23 12:29:36 Export_Power: Started
9/15/23 12:29:36 Export_Power: Last log entry 09/15/23 12:29:25
9/15/23 12:29:37 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -85db
9/15/23 12:29:37 MDNS responder started for hostname IotaWatt
9/15/23 12:29:37 LLMNR responder started for hostname IotaWatt
9/15/23 12:29:37 Updater: service started. Auto-update class is NONE
9/17/23 17:58:14 WiFi disconnected.
9/17/23 18:58:14 WiFi disconnected more than 60 minutes, restarting.
9/17/23 08:58:16z Real Time Clock is running. Unix time 1694941096
9/17/23 08:58:16z Reset reason: Software/System restart
9/17/23 08:58:16z Trace: 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:2
9/17/23 08:58:16z ESP8266 ID: 6735387, RTC PCF8523 (68)
9/17/23 08:58:16z IoTaWatt 5.0, Firmware version 02_07_05
9/17/23 08:58:16z SPIFFS mounted.
9/17/23 18:58:17 Local time zone: +10:00
9/17/23 18:58:17 device name: IotaWatt
9/17/23 18:58:17 HTTP server started
9/17/23 18:58:17 timeSync: service started.
9/17/23 18:58:17 statService: started.
9/17/23 18:58:17 dataLog: service started.
9/17/23 18:58:19 dataLog: Last log entry 09/17/23 18:58:10
9/17/23 18:58:22 historyLog: service started.
9/17/23 18:58:22 historyLog: Last log entry 09/17/23 18:58:00
9/17/23 18:58:22 Battery_cab: Started
9/17/23 18:58:23 Battery_cab: Last log entry 09/17/23 18:58:10
9/17/23 18:58:23 Export_Power: Started
9/17/23 18:58:23 Export_Power: Last log entry 09/17/23 18:58:10
9/17/23 19:09:36 WiFi connected. SSID=Two_Foos_IOT, IP=169.254.28.198, channel=13, RSSI -81db
9/17/23 19:09:36 MDNS responder started for hostname IotaWatt
9/17/23 19:09:36 LLMNR responder started for hostname IotaWatt
9/17/23 19:09:36 Updater: service started. Auto-update class is NONE
9/18/23 16:05:24 WiFi disconnected.
9/18/23 16:05:44 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -84db
9/19/23 16:53:52 WiFi disconnected.
9/19/23 17:31:50 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -78db
9/21/23 19:07:34 WiFi disconnected.
9/21/23 19:09:14 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -76db
9/26/23 11:00:01 WiFi disconnected.
9/26/23 11:01:42 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -77db
10/15/23 05:53:33 WiFi disconnected.
10/15/23 05:55:12 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -76db
10/15/23 21:35:14 WiFi disconnected.
10/15/23 21:35:59 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -77db
10/20/23 15:10:44 WiFi disconnected.
10/20/23 15:12:17 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -76db
10/22/23 09:38:48 WiFi disconnected.
10/22/23 09:40:32 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -79db
10/29/23 19:44:15 timeSync: Six week routine restart.
10/29/23 09:44:16z Real Time Clock is running. Unix time 1698572656
10/29/23 09:44:16z Reset reason: Software/System restart
10/29/23 09:44:16z Trace: 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[10], 1:2[11], 9:0[11], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
10/29/23 09:44:16z ESP8266 ID: 6735387, RTC PCF8523 (68)
10/29/23 09:44:16z IoTaWatt 5.0, Firmware version 02_07_05
10/29/23 09:44:16z SPIFFS mounted.
10/29/23 19:44:17 Local time zone: +10:00
10/29/23 19:44:17 device name: IotaWatt
10/29/23 19:44:17 HTTP server started
10/29/23 19:44:17 timeSync: service started.
10/29/23 19:44:17 statService: started.
10/29/23 19:44:17 dataLog: service started.
10/29/23 19:44:20 dataLog: Last log entry 10/29/23 19:44:15
10/29/23 19:44:22 historyLog: service started.
10/29/23 19:44:23 historyLog: Last log entry 10/29/23 19:44:00
10/29/23 19:44:23 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -74db
10/29/23 19:44:23 MDNS responder started for hostname IotaWatt
10/29/23 19:44:23 LLMNR responder started for hostname IotaWatt
10/29/23 19:44:24 Updater: service started. Auto-update class is NONE
10/29/23 19:44:24 Battery_cab: Started
10/29/23 19:44:24 Battery_cab: Last log entry 10/29/23 19:44:15
10/29/23 19:44:24 Export_Power: Started
10/29/23 19:44:24 Export_Power: Last log entry 10/29/23 19:44:15
11/03/23 03:16:59 WiFi disconnected.
11/03/23 03:18:36 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -76db
11/25/23 21:43:14 WiFi disconnected.
11/25/23 21:44:15 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -75db
11/26/23 06:35:02z Real Time Clock is running. Unix time 1700980502
11/26/23 06:35:02z Reset Reason: Power-fail restart.
11/26/23 06:35:02z ESP8266 ID: 6735387, RTC PCF8523 (68)
11/26/23 06:35:02z IoTaWatt 5.0, Firmware version 02_07_05
11/26/23 06:35:02z SPIFFS mounted.
11/26/23 16:35:02 Local time zone: +10:00
11/26/23 16:35:02 device name: IotaWatt
11/26/23 16:35:05 HTTP server started
11/26/23 16:35:06 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -75db
11/26/23 16:35:06 MDNS responder started for hostname IotaWatt
11/26/23 16:35:06 LLMNR responder started for hostname IotaWatt
11/26/23 16:35:06 timeSync: service started.
11/26/23 16:35:06 statService: started.
11/26/23 16:35:06 Updater: service started. Auto-update class is NONE
11/26/23 16:35:07 dataLog: service started.
11/26/23 16:35:10 dataLog: Last log entry 11/26/23 15:32:35
11/26/23 16:35:10 Battery_cab: Started
11/26/23 16:35:10 Battery_cab: Last log entry 11/26/23 15:32:35
11/26/23 16:35:11 Export_Power: Started
11/26/23 16:35:11 Export_Power: Last log entry 11/26/23 15:32:30
11/26/23 16:35:12 historyLog: service started.
11/26/23 16:35:12 historyLog: Last log entry 11/26/23 15:32:00
12/07/23 12:44:48 WiFi disconnected.
12/07/23 12:46:42 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -80db
12/14/23 03:00:27 WiFi disconnected.
12/14/23 03:03:03 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -75db
12/23/23 14:12:13 WiFi disconnected.
12/23/23 14:13:51 WiFi connected. SSID=Two_Foos_IOT, IP=192.168.130.101, channel=13, RSSI -75db
12/26/23 17:34:46 influxDB_v1: HTTPS specified but no HTTPSproxy server configured, stopping.
12/26/23 17:34:46 influxDB_v1: Invalid configuration.
1/02/24 21:20:20 influxDB_v1: Starting, interval:10, url:http://influx-lxc.localdomain:8086
1/02/24 21:20:20 influxDB_v1: Start posting at 01/02/24 00:00:10
1/02/24 21:20:55 influxDB_v1: stopped, Last post 01/02/24 02:13:00
1/02/24 21:22:24 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:22:27 influxDB_v1: Start posting at 01/02/24 00:00:10
1/02/24 21:22:45 influxDB_v1: stopped, Last post 01/02/24 00:57:50
1/02/24 21:23:41 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:23:59 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:27:10 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:27:19 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:51:05 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:51:51 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:56:01 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 21:59:01 influxDB_v1: Start posting at 01/01/24 00:00:10
1/02/24 21:59:10 influxDB_v1: stopped, Last post 01/01/24 00:22:30
1/02/24 22:00:52 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:01:55 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:02:05 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:04:50 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:13:50 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:14:01 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:15:30 influxDB_v1: stopped, Last post 01/01/70 10:00:00
1/02/24 22:15:49 influxDB_v1: Start posting at 01/01/24 00:00:05
1/02/24 22:16:02 influxDB_v1: stopped, Last post 01/01/24 00:00:00
1/02/24 22:17:29 influxDB_v1: Start posting at 01/01/24 00:00:05
1/02/24 22:17:43 influxDB_v1: stopped, Last post 01/01/24 00:37:35
1/02/24 22:18:38 influxDB_v1: Start posting at 01/01/24 00:00:05
1/02/24 22:18:56 influxDB_v1: stopped, Last post 01/01/24 00:45:15
1/02/24 22:20:13 influxDB_v1: Start posting at 01/01/24 00:00:05
1/02/24 22:20:31 influxDB_v1: stopped, Last post 01/01/24 00:47:05
1/02/24 22:21:29 influxDB_v1: Start posting at 01/01/24 00:47:10
1/02/24 22:21:39 influxDB_v1: stopped, Last post 01/01/24 01:06:45
1/02/24 22:22:35 influxDB_v1: Start posting at 01/01/24 00:00:05
1/02/24 22:22:50 influxDB_v1: stopped, Last post 01/01/24 00:32:00
Ok good to know im on the right track thinking they should line up.
