Hi Overeasy, can I please have some more help? The grid integrator broke again, but this time I have logs. Or at least, I have the iotamsgs.txt file. Both iotalog.log and histlog.log fail to download due to their size, a timeout, or a min speed (not sure). I’ll have to get the SD card later if they are needed.
The last day Home Assistant showed anything working was the 24th August, and then the 25th was weird, but broken. After that, there is no data reported.
For some reason, the logs are empty during this period.
8/18/25 00:12:10z Real Time Clock is running. Unix time 1755475930
8/18/25 00:12:10z Reset reason: Software/System restart
8/18/25 00:12:10z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[6], 1:2[7], 9:0[7], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
8/18/25 00:12:10z ESP8266 ID: 14622602, RTC PCF8523 (68)
8/18/25 00:12:10z IoTaWatt 5.0, Firmware version 02_08_03
8/18/25 00:12:10z SPIFFS mounted.
8/18/25 08:12:10 Local time zone: +8:00
8/18/25 08:12:10 device name: IotaWatt
8/18/25 08:12:10 HTTP server started
8/18/25 08:12:10 timeSync: service started.
8/18/25 08:12:10 statService: started.
8/18/25 08:12:10 dataLog: service started.
8/18/25 08:12:11 dataLog: Last log entry 08/18/25 08:12:05
8/18/25 08:12:14 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -59db
8/18/25 08:12:14 Updater: service started. Auto-update class is MINOR
8/18/25 08:12:15 historyLog: service started.
8/18/25 08:12:15 historyLog: Last log entry 08/18/25 08:12:00
8/18/25 08:12:15 Updater: Auto-update is current for class MINOR.
8/18/25 08:12:15 Grid: Started
8/18/25 08:12:16 Grid: Last log entry 08/18/25 08:12:05
9/06/25 05:59:50z Real Time Clock is running. Unix time 1757138390
On the 6th of September, the watchdog reset the device.
9/06/25 05:59:50z Reset Reason: Power-fail restart.
9/06/25 05:59:50z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/06/25 05:59:50z IoTaWatt 5.0, Firmware version 02_08_03
9/06/25 05:59:50z SPIFFS mounted.
9/06/25 13:59:50 Local time zone: +8:00
9/06/25 13:59:50 device name: IotaWatt
9/06/25 13:59:53 HTTP server started
9/06/25 13:59:53 WiFi connected. SSID=Ghostwater IoT, IP=192.168.2.13, channel=1, RSSI -59db
9/06/25 13:59:53 timeSync: service started.
9/06/25 13:59:53 statService: started.
9/06/25 13:59:53 Updater: service started. Auto-update class is MINOR
9/06/25 13:59:53 dataLog: service started.
9/06/25 13:59:54 dataLog: Last log entry 08/25/25 11:45:05
9/06/25 13:59:54 Updater: Auto-update is current for class MINOR.
9/06/25 13:59:58 historyLog: service started.
9/06/25 13:59:58 historyLog: Last log entry 08/25/25 11:44:00
9/06/25 06:03:16z SPIFFS mounted.
9/06/25 06:03:19z Real Time Clock is running. Unix time 1757138599
9/06/25 06:03:19z Reset reason: Software Watchdog
9/06/25 06:03:19z Trace: 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 0:0, 11:0, 11:4, 11:5, 11:5, 11:10, 11:15, 11:20, 11:20[1], 11:20[2], 11:25, 11:30, 11:30[1], 11:30[2], 11:31, 11:31[1], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55
9/06/25 06:03:19z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/06/25 06:03:19z IoTaWatt 5.0, Firmware version 02_08_03
9/06/25 06:03:19z SPIFFS mounted.
9/06/25 14:03:19 Local time zone: +8:00
9/06/25 14:03:19 device name: IotaWatt
9/06/25 14:03:19 HTTP server started
9/06/25 14:03:19 timeSync: service started.
9/06/25 14:03:19 statService: started.
On the 17th oif September, I realised something was wrong when I checked my energy graphs, and since I couldn’t access the iotawatt webserver, I restarted it with a smart plug. Looking at the logs, it must have tried to boot a few times because of the exception restarts. Only the first power fail restart was me.
9/17/25 14:33:59z Real Time Clock is running. Unix time 1758119639
9/17/25 14:33:59z Reset Reason: Power-fail restart.
9/17/25 14:33:59z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:33:59z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:33:59z SPIFFS mounted.
9/17/25 22:33:59 Local time zone: +8:00
9/17/25 22:33:59 device name: IotaWatt
9/17/25 22:34:02 HTTP server started
9/17/25 22:34:02 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -60db
9/17/25 22:34:02 timeSync: service started.
9/17/25 22:34:02 statService: started.
9/17/25 22:34:02 Updater: service started. Auto-update class is MINOR
9/17/25 22:34:02 dataLog: service started.
9/17/25 22:34:03 dataLog: Last log entry 09/14/25 21:01:15
9/17/25 22:34:04 Updater: Auto-update is current for class MINOR.
9/17/25 22:34:07 historyLog: service started.
9/17/25 22:34:07 historyLog: Last log entry 09/05/25 00:33:00
9/17/25 14:35:18z Real Time Clock is running. Unix time 1758119718
9/17/25 14:35:18z Reset reason: Exception
9/17/25 14:35:18z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:35:18z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:35:18z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:35:18z SPIFFS mounted.
9/17/25 22:35:18 Local time zone: +8:00
9/17/25 22:35:18 device name: IotaWatt
9/17/25 22:35:18 HTTP server started
9/17/25 22:35:18 timeSync: service started.
9/17/25 22:35:18 statService: started.
9/17/25 22:35:18 dataLog: service started.
9/17/25 22:35:19 dataLog: Last log entry 09/17/25 22:35:15
9/17/25 22:35:23 historyLog: service started.
9/17/25 22:35:23 historyLog: Last log entry 09/06/25 03:22:00
9/17/25 22:35:23 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -60db
9/17/25 22:35:23 Updater: service started. Auto-update class is MINOR
9/17/25 22:35:25 Updater: Auto-update is current for class MINOR.
9/17/25 14:35:34z Real Time Clock is running. Unix time 1758119734
9/17/25 14:35:34z Reset reason: Exception
9/17/25 14:35:34z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:35:34z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:35:34z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:35:34z SPIFFS mounted.
9/17/25 22:35:34 Local time zone: +8:00
9/17/25 22:35:34 device name: IotaWatt
9/17/25 22:35:34 HTTP server started
9/17/25 22:35:34 timeSync: service started.
9/17/25 22:35:34 statService: started.
9/17/25 22:35:34 dataLog: service started.
9/17/25 22:35:35 dataLog: Last log entry 09/17/25 22:35:30
9/17/25 22:35:38 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -59db
9/17/25 22:35:38 Updater: service started. Auto-update class is MINOR
9/17/25 22:35:39 historyLog: service started.
9/17/25 22:35:39 historyLog: Last log entry 09/06/25 06:24:00
9/17/25 22:35:39 Updater: Auto-update is current for class MINOR.
9/17/25 14:35:45z Real Time Clock is running. Unix time 1758119745
9/17/25 14:35:45z Reset reason: Exception
9/17/25 14:35:45z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:35:45z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:35:45z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:35:45z SPIFFS mounted.
9/17/25 22:35:45 Local time zone: +8:00
9/17/25 22:35:45 device name: IotaWatt
9/17/25 22:35:45 HTTP server started
9/17/25 22:35:45 timeSync: service started.
9/17/25 22:35:45 statService: started.
9/17/25 22:35:45 dataLog: service started.
9/17/25 22:35:46 dataLog: Last log entry 09/17/25 22:35:40
9/17/25 22:35:49 Updater: service started. Auto-update class is MINOR
9/17/25 14:35:51z Real Time Clock is running. Unix time 1758119751
9/17/25 14:35:51z Reset reason: Exception
9/17/25 14:35:51z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:35:51z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:35:51z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:35:51z SPIFFS mounted.
9/17/25 22:35:51 Local time zone: +8:00
9/17/25 22:35:51 device name: IotaWatt
9/17/25 22:35:51 HTTP server started
9/17/25 22:35:51 timeSync: service started.
9/17/25 22:35:51 statService: started.
9/17/25 22:35:51 dataLog: service started.
9/17/25 22:35:52 dataLog: Last log entry 09/17/25 22:35:45
9/17/25 22:35:55 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -60db
9/17/25 22:35:55 Updater: service started. Auto-update class is MINOR
9/17/25 22:35:56 historyLog: service started.
9/17/25 22:35:56 historyLog: Last log entry 09/06/25 08:18:00
9/17/25 22:35:57 Updater: Auto-update is current for class MINOR.
9/17/25 14:36:34z Real Time Clock is running. Unix time 1758119794
9/17/25 14:36:34z Reset reason: Exception
9/17/25 14:36:34z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:36:34z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:36:34z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:36:34z SPIFFS mounted.
9/17/25 22:36:34 Local time zone: +8:00
9/17/25 22:36:34 device name: IotaWatt
9/17/25 22:36:34 HTTP server started
9/17/25 22:36:34 timeSync: service started.
9/17/25 22:36:34 statService: started.
9/17/25 22:36:34 dataLog: service started.
9/17/25 22:36:35 dataLog: Last log entry 09/17/25 22:36:30
9/17/25 22:36:38 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -61db
9/17/25 22:36:38 Updater: service started. Auto-update class is MINOR
9/17/25 22:36:39 historyLog: service started.
9/17/25 22:36:39 historyLog: Last log entry 09/06/25 22:46:00
9/17/25 22:36:39 Updater: Auto-update is current for class MINOR.
9/17/25 14:37:23z Real Time Clock is running. Unix time 1758119843
9/17/25 14:37:23z Reset reason: Exception
9/17/25 14:37:23z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:37:23z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:37:23z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:37:23z SPIFFS mounted.
9/17/25 22:37:23 Local time zone: +8:00
9/17/25 22:37:23 device name: IotaWatt
9/17/25 22:37:23 HTTP server started
9/17/25 22:37:23 timeSync: service started.
9/17/25 22:37:23 statService: started.
9/17/25 22:37:23 dataLog: service started.
9/17/25 22:37:24 dataLog: Last log entry 09/17/25 22:37:20
9/17/25 22:37:27 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -60db
9/17/25 22:37:27 Updater: service started. Auto-update class is MINOR
9/17/25 22:37:28 historyLog: service started.
9/17/25 22:37:28 historyLog: Last log entry 09/07/25 14:26:00
9/17/25 22:37:28 Updater: Auto-update is current for class MINOR.
9/17/25 14:38:06z Real Time Clock is running. Unix time 1758119886
9/17/25 14:38:06z Reset reason: Exception
9/17/25 14:38:06z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:38:06z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:38:06z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:38:06z SPIFFS mounted.
9/17/25 22:38:06 Local time zone: +8:00
9/17/25 22:38:06 device name: IotaWatt
9/17/25 22:38:06 HTTP server started
9/17/25 22:38:06 timeSync: service started.
9/17/25 22:38:06 statService: started.
9/17/25 22:38:06 dataLog: service started.
9/17/25 22:38:07 dataLog: Last log entry 09/17/25 22:38:05
9/17/25 22:38:11 historyLog: service started.
9/17/25 22:38:11 historyLog: Last log entry 09/08/25 04:06:00
9/17/25 22:38:11 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -62db
9/17/25 22:38:11 Updater: service started. Auto-update class is MINOR
9/17/25 22:38:13 Updater: Auto-update is current for class MINOR.
9/17/25 22:38:23 Restart command received.
9/17/25 14:38:25z Real Time Clock is running. Unix time 1758119905
9/17/25 14:38:25z Reset reason: Software/System restart
9/17/25 14:38:25z Trace: 18:2, 18:3, 18:4, 18:5, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[14], 1:6[4], 14:0, 14:4, 14:5, 14:7, 14:8, 1:6[6], 1:1[5], 1:2[6], 9:0[6], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 10:2, 10:3
9/17/25 14:38:25z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:38:25z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:38:25z SPIFFS mounted.
9/17/25 22:38:25 Local time zone: +8:00
9/17/25 22:38:25 device name: IotaWatt
9/17/25 22:38:25 HTTP server started
9/17/25 22:38:25 timeSync: service started.
9/17/25 22:38:25 statService: started.
9/17/25 22:38:25 dataLog: service started.
9/17/25 22:38:26 dataLog: Last log entry 09/17/25 22:38:20
9/17/25 22:38:29 Updater: service started. Auto-update class is MINOR
9/17/25 22:38:30 historyLog: service started.
9/17/25 22:38:30 historyLog: Last log entry 09/08/25 08:23:00
9/17/25 22:38:31 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -56db
9/17/25 22:38:31 Updater: Auto-update is current for class MINOR.
9/17/25 14:38:52z Real Time Clock is running. Unix time 1758119932
9/17/25 14:38:52z Reset reason: Exception
9/17/25 14:38:52z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:38:52z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:38:52z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:38:52z SPIFFS mounted.
9/17/25 22:38:52 Local time zone: +8:00
9/17/25 22:38:52 device name: IotaWatt
9/17/25 22:38:52 HTTP server started
9/17/25 22:38:52 timeSync: service started.
9/17/25 22:38:52 statService: started.
9/17/25 22:38:52 dataLog: service started.
9/17/25 22:38:53 dataLog: Last log entry 09/17/25 22:38:50
9/17/25 22:38:57 historyLog: service started.
9/17/25 22:38:58 historyLog: Last log entry 09/08/25 15:56:00
9/17/25 22:38:58 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -57db
9/17/25 22:38:58 Updater: service started. Auto-update class is MINOR
9/17/25 22:39:00 Updater: Auto-update is current for class MINOR.
9/17/25 14:39:29z Real Time Clock is running. Unix time 1758119969
9/17/25 14:39:29z Reset reason: Exception
9/17/25 14:39:29z Trace: 1:3, 10:0, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:14, 10:15, 10:16, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 34:30, 34:30, 33:0, 34:30, 10:16[1], 10:16[1], 10:16[2], 10:17, 10:17, 10:18, 10:23, 10:17
9/17/25 14:39:29z ESP8266 ID: 14622602, RTC PCF8523 (68)
9/17/25 14:39:29z IoTaWatt 5.0, Firmware version 02_08_03
9/17/25 14:39:29z SPIFFS mounted.
9/17/25 22:39:29 Local time zone: +8:00
9/17/25 22:39:29 device name: IotaWatt
9/17/25 22:39:29 HTTP server started
9/17/25 22:39:29 timeSync: service started.
9/17/25 22:39:29 statService: started.
9/17/25 22:39:29 dataLog: service started.
9/17/25 22:39:30 dataLog: Last log entry 09/17/25 22:39:25
9/17/25 22:39:34 historyLog: service started.
9/17/25 22:39:35 historyLog: Last log entry 09/09/25 03:16:00
9/17/25 22:39:35 WiFi connected. SSID=[redacted], IP=[redacted], channel=1, RSSI -59db
9/17/25 22:39:35 Updater: service started. Auto-update class is MINOR
9/17/25 22:39:36 Updater: Auto-update is current for class MINOR.
9/17/25 22:39:56 Grid: Started
9/17/25 22:39:56 Grid: Couldn't open integration file /iotawatt/integrations//Grid.log.
Logs stop on the 17th of September, and today is the 19th. But the iotawatt webserver has remained accessible since I reset it through the smart plug on the 17th. Just with no integrator data, or the outputs that rely on the integrator.
I can’t see anything in /iotawatt/integrations//Grid.log , which is referenced at the end of the last log snippet above. Unless this window doesn’t show hidden files.
