My IotaWatt was quite reliable - out of site, out-of-mind - for about 1.5 years. Starting around March the device has stopped uploading (HomeAssistant and influxdB2), eventually I notice and then find I cannot reach it by HTTP interface either.
I reset the device by cycling power off/on and find that everything restores / reconnects immediately and that the IotaWatt has valid power/energy data covering the duration of the connectivity outage. So it was alive and recording, but not doing desired network things.
I have not changed the location of my WiFi access points (Aruba AP22’s WiFi 6) or the IotaWatt. I have not moved walls or furniture.
Over the course of four months, I see just one WiFi disconnected.
log message with reconnect ~2 minutes later.
Why is my IotaWatt now unstable?
I do notice a firmware update logged just before this problem began. All restarts following that firmware update are unannounced - i.e. nothing is logged for a long duration until the restart sequence is logged - the restart sequence triggered by my power off-on cycle.
BTW, Since I have multiple WiFi access points serving the same network, it would be helpful if the WiFi connected
log entry included the access point’s MAC address.
My latest log, year-to-date follows:
1/05/23 06:17:21z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 07:17:27z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 08:17:33z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 09:17:39z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 10:17:46z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 11:17:52z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 12:17:59z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 13:18:05z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 14:18:11z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 15:18:17z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 16:18:23z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 17:18:29z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 18:18:35z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 19:18:41z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 20:18:47z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 21:18:53z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 22:18:59z Updater: update tables from 0.0.6 to 0.0.7
1/05/23 23:19:05z Updater: update tables from 0.0.6 to 0.0.7
1/06/23 00:19:11z Updater: update tables from 0.0.6 to 0.0.7
1/06/23 01:19:17z Updater: update tables from 0.0.6 to 0.0.7
1/18/23 02:11:42z timeSync: Six week routine restart.
1/18/23 02:11:44z Real Time Clock is running. Unix time 1674007904
1/18/23 02:11:44z Reset reason: Software/System restart
1/18/23 02:11:44z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[2], 1:2[3], 9:0[3], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
1/18/23 02:11:44z ESP8266 ID: 8528520, RTC PCF8523 (68)
1/18/23 02:11:44z IoTaWatt 5.0, Firmware version 02_07_05
1/18/23 02:11:44z SPIFFS mounted.
1/18/23 02:11:44z Local time zone: +0:00
1/18/23 02:11:44z device name: IotaWatt
1/18/23 02:11:44z HTTP server started
1/18/23 02:11:44z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
1/18/23 02:11:44z timeSync: service started.
1/18/23 02:11:44z statService: started.
1/18/23 02:11:44z dataLog: service started.
1/18/23 02:11:47z dataLog: Last log entry 01/18/23 02:11:40
1/18/23 02:11:49z historyLog: service started.
1/18/23 02:11:50z historyLog: Last log entry 01/18/23 02:11:00
1/18/23 02:11:54z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -67db
1/18/23 02:11:54z MDNS responder started for hostname IotaWatt
1/18/23 02:11:54z LLMNR responder started for hostname IotaWatt
1/18/23 02:11:54z Updater: service started. Auto-update class is MINOR
1/18/23 02:11:54z influxDB_v2: Resume posting 01/18/23 02:11:30
1/18/23 02:11:56z Updater: Auto-update is current for class MINOR.
1/25/23 06:29:25z Updater: Invalid response from server. HTTPcode: -4
2/25/23 23:50:52z Real Time Clock is running. Unix time 1677369052
2/25/23 23:50:52z Reset Reason: Power-fail restart.
2/25/23 23:50:52z ESP8266 ID: 8528520, RTC PCF8523 (68)
2/25/23 23:50:52z IoTaWatt 5.0, Firmware version 02_07_05
2/25/23 23:50:52z SPIFFS mounted.
2/25/23 23:50:53z Local time zone: +0:00
2/25/23 23:50:53z device name: IotaWatt
2/25/23 23:50:56z Connecting with WiFiManager.
2/25/23 23:51:02z HTTP server started
2/25/23 23:51:02z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
2/25/23 23:51:02z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -67db
2/25/23 23:51:02z MDNS responder started for hostname IotaWatt
2/25/23 23:51:02z LLMNR responder started for hostname IotaWatt
2/25/23 23:51:02z timeSync: service started.
2/25/23 23:51:02z statService: started.
2/25/23 23:51:02z Updater: service started. Auto-update class is MINOR
2/25/23 23:51:02z dataLog: service started.
2/25/23 23:51:05z dataLog: Last log entry 02/25/23 23:41:35
2/25/23 23:51:07z historyLog: service started.
2/25/23 23:51:08z historyLog: Last log entry 02/25/23 23:41:00
2/25/23 23:51:08z influxDB_v2: Resume posting 02/25/23 23:41:20
2/25/23 23:51:08z Updater: Auto-update is current for class MINOR.
3/03/23 21:05:19z Updater: Update from 02_07_05 to 02_08_02
3/03/23 21:05:19z Updater: download 02_08_02
3/03/23 21:05:26z Updater: Release downloaded 7443ms, size 964192
3/03/23 21:05:38z Updater: signature verified
3/03/23 21:05:47z Updater: firmware upgraded to version 02_08_02
3/03/23 21:05:47z Updater: Firmware updated, restarting.
3/03/23 21:05:58z Real Time Clock is running. Unix time 1677877558
3/03/23 21:05:58z Reset reason: Software/System restart
3/03/23 21:05:58z Trace: 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 29:60, 29:60, 29:61, 31:1, 1:6[6], 1:1[13], 1:2[14], 9:0[14], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
3/03/23 21:05:58z ESP8266 ID: 8528520, RTC PCF8523 (68)
3/03/23 21:05:58z IoTaWatt 5.0, Firmware version 02_08_02
3/03/23 21:05:58z Updater: Installing update files for version 02_08_02
3/03/23 21:05:58z Updater: Installing EDIT.HTM
3/03/23 21:05:58z Updater: Installing FAVICON.ICO
3/03/23 21:05:59z Updater: Installing GRAPH.HTM
3/03/23 21:05:59z Updater: Installing GRAPH.JS
3/03/23 21:05:59z Updater: Installing GRAPH2.HTM
3/03/23 21:05:59z Updater: Installing GRAPH2.JS
3/03/23 21:06:00z Updater: Installing INDEX.HTM
3/03/23 21:06:01z Updater: Installing TABLES.TXT
3/03/23 21:06:02z Updater: Installing CNFSTYLE.CSS
3/03/23 21:06:02z Updater: Installation complete.
3/03/23 21:06:02z SPIFFS mounted.
3/03/23 21:06:02z Local time zone: +0:00
3/03/23 21:06:02z device name: IotaWatt
3/03/23 21:06:02z HTTP server started
3/03/23 21:06:02z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
3/03/23 21:06:02z timeSync: service started.
3/03/23 21:06:02z statService: started.
3/03/23 21:06:03z dataLog: service started.
3/03/23 21:06:06z dataLog: Last log entry 03/03/23 21:05:25
3/03/23 21:06:08z historyLog: service started.
3/03/23 21:06:08z historyLog: Last log entry 03/03/23 21:05:00
3/03/23 21:06:12z Updater: service started. Auto-update class is MINOR
3/03/23 21:06:12z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -66db
3/03/23 21:06:12z influxDB_v2: Resume posting 03/03/23 21:04:50
3/03/23 21:06:13z Updater: Auto-update is current for class MINOR.
3/18/23 05:46:46z Real Time Clock is running. Unix time 1679118406
3/18/23 05:46:46z Reset Reason: Power-fail restart.
3/18/23 05:46:46z ESP8266 ID: 8528520, RTC PCF8523 (68)
3/18/23 05:46:46z IoTaWatt 5.0, Firmware version 02_08_02
3/18/23 05:46:46z SPIFFS mounted.
3/18/23 05:46:47z Local time zone: +0:00
3/18/23 05:46:47z device name: IotaWatt
3/18/23 05:46:50z Connecting with WiFiManager.
3/18/23 05:46:55z HTTP server started
3/18/23 05:46:56z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
3/18/23 05:46:56z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -68db
3/18/23 05:46:56z timeSync: service started.
3/18/23 05:46:56z statService: started.
3/18/23 05:46:56z Updater: service started. Auto-update class is MINOR
3/18/23 05:46:56z dataLog: service started.
3/18/23 05:46:59z dataLog: Last log entry 03/18/23 05:46:35
3/18/23 05:46:59z influxDB_v2: Resume posting 03/18/23 05:46:20
3/18/23 05:47:00z Updater: Auto-update is current for class MINOR.
3/18/23 05:47:01z historyLog: service started.
3/18/23 05:47:01z historyLog: Last log entry 03/18/23 05:46:00
3/26/23 10:02:39z WiFi disconnected.
3/26/23 10:05:00z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -64db
3/31/23 19:08:14z Real Time Clock is running. Unix time 1680289694
3/31/23 19:08:14z Reset Reason: Power-fail restart.
3/31/23 19:08:14z ESP8266 ID: 8528520, RTC PCF8523 (68)
3/31/23 19:08:14z IoTaWatt 5.0, Firmware version 02_08_02
3/31/23 19:08:14z SPIFFS mounted.
3/31/23 19:08:15z Local time zone: +0:00
3/31/23 19:08:15z device name: IotaWatt
3/31/23 19:08:18z Connecting with WiFiManager.
3/31/23 19:08:21z HTTP server started
3/31/23 19:08:21z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
3/31/23 19:08:21z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -66db
3/31/23 19:08:22z timeSync: service started.
3/31/23 19:08:22z statService: started.
3/31/23 19:08:22z Updater: service started. Auto-update class is MINOR
3/31/23 19:08:22z dataLog: service started.
3/31/23 19:08:25z dataLog: Last log entry 03/31/23 19:08:05
3/31/23 19:08:25z influxDB_v2: Resume posting 03/31/23 19:07:50
3/31/23 19:08:26z Updater: Auto-update is current for class MINOR.
3/31/23 19:08:27z historyLog: service started.
3/31/23 19:08:27z historyLog: Last log entry 03/31/23 19:08:00
4/27/23 14:02:23z Real Time Clock is running. Unix time 1682604143
4/27/23 14:02:23z Reset Reason: Power-fail restart.
4/27/23 14:02:23z ESP8266 ID: 8528520, RTC PCF8523 (68)
4/27/23 14:02:23z IoTaWatt 5.0, Firmware version 02_08_02
4/27/23 14:02:23z SPIFFS mounted.
4/27/23 14:02:24z Local time zone: +0:00
4/27/23 14:02:24z device name: IotaWatt
4/27/23 14:02:27z Connecting with WiFiManager.
4/27/23 14:02:30z HTTP server started
4/27/23 14:02:30z influxDB_v2: Starting, interval:5, url:http://10.0.1.143:8086
4/27/23 14:02:30z WiFi connected. SSID=New6, IP=10.0.1.177, channel=1, RSSI -71db
4/27/23 14:02:30z timeSync: service started.
4/27/23 14:02:30z statService: started.
4/27/23 14:02:30z Updater: service started. Auto-update class is MINOR
4/27/23 14:02:30z dataLog: service started.
4/27/23 14:02:33z dataLog: Last log entry 04/27/23 14:02:15
4/27/23 14:02:34z influxDB_v2: Resume posting 04/27/23 14:02:00
4/27/23 14:02:35z historyLog: service started.
4/27/23 14:02:35z historyLog: Last log entry 04/27/23 14:02:00
4/27/23 14:02:35z Updater: Auto-update is current for class MINOR.
