Hi,
I have 3 IoTaWatt running for several years now. Lately I have a problem with two of them. Both are constantly resetting after about 10s of runtime.
The Message Log looks like this:
1/15/22 17:24:12z Real Time Clock is running. Unix time 1642267452
1/15/22 17:24:12z Reset reason: Software Watchdog
1/15/22 17:24:12z Trace: 3:60, 3:62, 3:62, 3:64, 3:65, 31:1, 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 3:60, 3:60, 3:60
1/15/22 17:24:12z ESP8266 ID: 188414, RTC PCF8523 (68)
1/15/22 17:24:12z IoTaWatt 4.x, Firmware version 02_07_05
1/15/22 17:24:12z SPIFFS mounted.
1/15/22 19:24:12 Local time zone: +2:00
1/15/22 19:24:13 device name: IotaL3
1/15/22 19:24:13 HTTP server started
1/15/22 19:24:13 emoncms: Starting, interval:10, url:http://10.1.1.96:9999
1/15/22 19:24:13 influxDB_v2: Starting, interval:5, url:http://influxdb.s1.betagate.de:8086
1/15/22 19:24:13 timeSync: service started.
1/15/22 19:24:13 statService: started.
1/15/22 19:24:13 dataLog: service started.
1/15/22 19:24:14 dataLog: Last log entry 01/15/22 19:24:05
1/15/22 19:24:17 WiFi connected. SSID=Betagate-Rack, IP=10.1.1.40, channel=11, RSSI -24db
1/15/22 19:24:17 MDNS responder started for hostname IotaL3
1/15/22 19:24:17 LLMNR responder started for hostname IotaL3
1/15/22 19:24:17 Updater: service started. Auto-update class is MINOR
1/15/22 19:24:17 emoncms: Start posting at 01/07/22 15:03:50
1/15/22 19:24:18 historyLog: service started.
1/15/22 19:24:18 historyLog: Last log entry 01/15/22 19:24:00
1/15/22 19:24:19 influxDB_v2: Resume posting 01/15/22 19:23:40
1/15/22 17:24:23z Real Time Clock is running. Unix time 1642267463
1/15/22 17:24:23z Reset reason: Software Watchdog
1/15/22 17:24:23z Trace: 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 3:60, 3:60, 3:60
1/15/22 17:24:23z ESP8266 ID: 188414, RTC PCF8523 (68)
1/15/22 17:24:23z IoTaWatt 4.x, Firmware version 02_07_05
1/15/22 17:24:23z SPIFFS mounted.
1/15/22 19:24:23 Local time zone: +2:00
1/15/22 19:24:24 device name: IotaL3
1/15/22 19:24:24 HTTP server started
1/15/22 19:24:24 emoncms: Starting, interval:10, url:http://10.1.1.96:9999
1/15/22 19:24:24 influxDB_v2: Starting, interval:5, url:http://influxdb.s1.betagate.de:8086
1/15/22 19:24:24 timeSync: service started.
1/15/22 19:24:24 statService: started.
1/15/22 19:24:24 dataLog: service started.
1/15/22 19:24:25 dataLog: Last log entry 01/15/22 19:24:15
1/15/22 19:24:28 WiFi connected. SSID=Betagate-Rack, IP=10.1.1.40, channel=11, RSSI -23db
1/15/22 19:24:28 MDNS responder started for hostname IotaL3
1/15/22 19:24:28 LLMNR responder started for hostname IotaL3
1/15/22 19:24:28 Updater: service started. Auto-update class is MINOR
1/15/22 19:24:28 emoncms: Start posting at 01/07/22 15:03:50
1/15/22 19:24:29 historyLog: service started.
1/15/22 19:24:29 historyLog: Last log entry 01/15/22 19:24:00
1/15/22 19:24:30 influxDB_v2: Resume posting 01/15/22 19:24:05
1/15/22 19:24:30 Updater: Auto-update is current for class MINOR.
1/15/22 17:24:35z Real Time Clock is running. Unix time 1642267475
1/15/22 17:24:35z Reset reason: Software Watchdog
1/15/22 17:24:35z Trace: 3:65, 31:1, 1:6[6], 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 3:60, 3:60, 3:60, 3:62, 3:62, 3:64, 3:65, 3:60
1/15/22 17:24:35z ESP8266 ID: 188414, RTC PCF8523 (68)
1/15/22 17:24:35z IoTaWatt 4.x, Firmware version 02_07_05
1/15/22 17:24:35z SPIFFS mounted.
1/15/22 19:24:35 Local time zone: +2:00
1/15/22 19:24:35 device name: IotaL3
1/15/22 19:24:36 HTTP server started
1/15/22 19:24:36 emoncms: Starting, interval:10, url:http://10.1.1.96:9999
1/15/22 19:24:36 influxDB_v2: Starting, interval:5, url:http://influxdb.s1.betagate.de:8086
1/15/22 19:24:36 timeSync: service started.
1/15/22 19:24:36 statService: started.
1/15/22 19:24:36 dataLog: service started.
1/15/22 19:24:36 dataLog: Last log entry 01/15/22 19:24:30
1/15/22 19:24:40 WiFi connected. SSID=Betagate-Rack, IP=10.1.1.40, channel=11, RSSI -23db
1/15/22 19:24:40 MDNS responder started for hostname IotaL3
1/15/22 19:24:40 LLMNR responder started for hostname IotaL3
1/15/22 19:24:40 Updater: service started. Auto-update class is MINOR
1/15/22 19:24:40 emoncms: Start posting at 01/07/22 15:03:50
1/15/22 19:24:41 historyLog: service started.
1/15/22 19:24:41 historyLog: Last log entry 01/15/22 19:24:00
I found this other post that looks pretty similar. It mentions that this might be duo to a corrupted log file, sadly no details are mentioned.
Any idea on what could cause these resets?
