Randomly it seems to be working now, i noticed my Grafana graphs were updated so i checked the iotawatt web interface and it’s responsive.
Logs:
8/09/23 03:00:16z Trace: 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:00:16z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:00:16z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:00:16z SPIFFS mounted.
8/08/23 23:00:16 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:00:16 device name: IotaWatt
8/08/23 23:00:16 HTTP server started
8/08/23 23:00:16 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:00:16 timeSync: service started.
8/08/23 23:00:16 statService: started.
8/08/23 23:00:16 dataLog: service started.
8/08/23 23:00:19 dataLog: Last log entry 08/08/23 23:00:15
8/08/23 23:00:21 historyLog: service started.
8/08/23 23:00:21 historyLog: Last log entry 08/08/23 23:00:00
8/08/23 23:00:27 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -77db
8/08/23 23:00:27 Updater: service started. Auto-update class is BETA
8/08/23 23:00:30 Updater: Auto-update is current for class BETA.
8/08/23 23:00:33 influxDB_v1: Start posting at 08/08/23 19:49:50
8/08/23 23:01:30 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:01:31z Real Time Clock is running. Unix time 1691550091
8/09/23 03:01:31z Reset reason: Software/System restart
8/09/23 03:01:31z Trace: 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[19], 1:6[4], 1:6[6], 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:01:31z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:01:31z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:01:31z SPIFFS mounted.
8/08/23 23:01:31 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:01:31 device name: IotaWatt
8/08/23 23:01:31 HTTP server started
8/08/23 23:01:31 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:01:31 timeSync: service started.
8/08/23 23:01:31 statService: started.
8/08/23 23:01:31 dataLog: service started.
8/08/23 23:01:34 dataLog: Last log entry 08/08/23 23:01:30
8/08/23 23:01:36 historyLog: service started.
8/08/23 23:01:36 historyLog: Last log entry 08/08/23 23:01:00
8/08/23 23:01:36 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -75db
8/08/23 23:01:36 Updater: service started. Auto-update class is BETA
8/08/23 23:01:41 Updater: Auto-update is current for class BETA.
8/08/23 23:01:42 influxDB_v1: Start posting at 08/08/23 19:49:50
8/08/23 23:02:39 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:02:40z Real Time Clock is running. Unix time 1691550160
8/09/23 03:02:40z Reset reason: Software/System restart
8/09/23 03:02:40z Trace: 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:02:40z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:02:40z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:02:40z SPIFFS mounted.
8/08/23 23:02:40 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:02:40 device name: IotaWatt
8/08/23 23:02:40 HTTP server started
8/08/23 23:02:40 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:02:40 timeSync: service started.
8/08/23 23:02:40 statService: started.
8/08/23 23:02:40 dataLog: service started.
8/08/23 23:02:43 dataLog: Last log entry 08/08/23 23:02:35
8/08/23 23:02:45 historyLog: service started.
8/08/23 23:02:45 historyLog: Last log entry 08/08/23 23:02:00
8/08/23 23:02:45 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -76db
8/08/23 23:02:46 Updater: service started. Auto-update class is BETA
8/08/23 23:02:55 Updater: Auto-update is current for class BETA.
8/08/23 23:03:06 influxDB_v1: Start posting at 08/08/23 19:49:50
8/08/23 23:04:03 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:04:04z Real Time Clock is running. Unix time 1691550244
8/09/23 03:04:04z Reset reason: Software/System restart
8/09/23 03:04:04z Trace: 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:04:04z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:04:04z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:04:04z SPIFFS mounted.
8/08/23 23:04:04 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:04:04 device name: IotaWatt
8/08/23 23:04:04 HTTP server started
8/08/23 23:04:04 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:04:04 timeSync: service started.
8/08/23 23:04:04 statService: started.
8/08/23 23:04:04 dataLog: service started.
8/08/23 23:04:07 dataLog: Last log entry 08/08/23 23:04:00
8/08/23 23:04:09 historyLog: service started.
8/08/23 23:04:09 historyLog: Last log entry 08/08/23 23:04:00
8/08/23 23:04:11 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -77db
8/08/23 23:04:11 Updater: service started. Auto-update class is BETA
8/08/23 23:04:25 Updater: Auto-update is current for class BETA.
8/08/23 23:04:48 influxDB_v1: Start posting at 08/08/23 19:49:50
8/08/23 23:06:59 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:07:00z Real Time Clock is running. Unix time 1691550420
8/09/23 03:07:00z Reset reason: Software/System restart
8/09/23 03:07:00z Trace: 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:2, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:07:00z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:07:00z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:07:00z SPIFFS mounted.
8/08/23 23:07:00 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:07:00 device name: IotaWatt
8/08/23 23:07:00 HTTP server started
8/08/23 23:07:00 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:07:00 timeSync: service started.
8/08/23 23:07:00 statService: started.
8/08/23 23:07:00 dataLog: service started.
8/08/23 23:07:03 dataLog: Last log entry 08/08/23 23:06:55
8/08/23 23:07:05 historyLog: service started.
8/08/23 23:07:05 historyLog: Last log entry 08/08/23 23:06:00
8/08/23 23:07:11 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -76db
8/08/23 23:07:11 Updater: service started. Auto-update class is BETA
8/08/23 23:07:13 Updater: Auto-update is current for class BETA.
8/08/23 23:07:30 influxDB_v1: Start posting at 08/08/23 19:50:30
8/08/23 23:08:26 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:08:27z Real Time Clock is running. Unix time 1691550507
8/09/23 03:08:27z Reset reason: Software/System restart
8/09/23 03:08:27z Trace: 8:4, 8:6, 8:8, 9:3, 9:5, 9:9, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:08:27z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:08:27z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:08:27z SPIFFS mounted.
8/08/23 23:08:27 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:08:27 device name: IotaWatt
8/08/23 23:08:27 HTTP server started
8/08/23 23:08:27 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:08:27 timeSync: service started.
8/08/23 23:08:27 statService: started.
8/08/23 23:08:27 dataLog: service started.
8/08/23 23:08:30 dataLog: Last log entry 08/08/23 23:08:25
8/08/23 23:08:32 historyLog: service started.
8/08/23 23:08:32 historyLog: Last log entry 08/08/23 23:08:00
8/08/23 23:08:43 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -77db
8/08/23 23:08:43 Updater: service started. Auto-update class is BETA
8/08/23 23:08:58 influxDB_v1: Start posting at 08/08/23 19:50:30
8/08/23 23:09:00 Updater: Auto-update is current for class BETA.
8/08/23 23:09:56 Heap memory has degraded below safe minimum, restarting.
8/09/23 03:09:57z Real Time Clock is running. Unix time 1691550597
8/09/23 03:09:57z Reset reason: Software/System restart
8/09/23 03:09:57z Trace: 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 31:93, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:2, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[21], 1:6[4], 21:0, 21:1, 21:10, 21:10
8/09/23 03:09:57z ESP8266 ID: 6308249, RTC PCF8523 (68)
8/09/23 03:09:57z IoTaWatt 5.0, Firmware version 02_08_02
8/09/23 03:09:57z SPIFFS mounted.
8/08/23 23:09:57 Local time zone: -5:00, using DST/BST when in effect.
8/08/23 23:09:57 device name: IotaWatt
8/08/23 23:09:57 HTTP server started
8/08/23 23:09:57 influxDB_v1: Starting, interval:10, url:http://192.168.1.135:8086
8/08/23 23:09:57 timeSync: service started.
8/08/23 23:09:57 statService: started.
8/08/23 23:09:57 dataLog: service started.
8/08/23 23:10:00 dataLog: Last log entry 08/08/23 23:09:55
8/08/23 23:10:02 historyLog: service started.
8/08/23 23:10:02 historyLog: Last log entry 08/08/23 23:09:00
8/08/23 23:10:04 WiFi connected. SSID=VirusWIFI, IP=192.168.1.254, channel=11, RSSI -76db
8/08/23 23:10:04 Updater: service started. Auto-update class is BETA
8/08/23 23:10:12 Updater: Auto-update is current for class BETA.
8/08/23 23:11:13 influxDB_v1: Start posting at 08/08/23 19:50:30
