That was quick. Pretyy sure it was nothing more than a communications problem.
After I posted the above I checked the data during the “down” period it appears to be all there… The issue occurred sometime between 4:30 - 5:00 PM on Nov 17/22. The message log is below:
11/16/22 12:19:13 WiFi disconnected.
11/16/22 12:20:47 WiFi connected. SSID=CKZ_2HA, IP=192.168.1.139, channel=11, RSSI -50db
11/17/22 21:49:34z Real Time Clock is running. Unix time 1668721774
11/17/22 21:49:34z Reset Reason: Power-fail restart.
11/17/22 21:49:34z ESP8266 ID: 499544, RTC M41T81 (68)
11/17/22 21:49:34z IoTaWatt 5.0, Firmware version 02_07_05
11/17/22 21:49:34z SPIFFS mounted.
11/17/22 16:49:34 Local time zone: -5:00, using DST/BST when in effect.
11/17/22 16:49:34 device name: IotaWatt
11/17/22 16:49:37 Connecting with WiFiManager.
11/17/22 16:52:37 Did not connect after power-fail. Restarting to reset WiFi.
11/17/22 21:52:38z Real Time Clock is running. Unix time 1668721958
11/17/22 21:52:38z Reset reason: Software/System restart
11/17/22 21:52:38z Trace: 34:30, 34:10[8], 34:30, 34:10[9], 34:30, 34:10[10], 34:30, 34:10[11], 34:30, 34:10[12], 34:30, 34:10[13], 34:30, 34:10[14], 34:30, 34:5, 34:5, 34:5, 34:6[3], 34:10[6], 34:30, 34:10[9], 11:31[3], 11:30[3], 11:35, 11:36, 11:35, 11:40, 11:45, 11:50, 11:55, 11:70
11/17/22 21:52:38z ESP8266 ID: 499544, RTC M41T81 (68)
11/17/22 21:52:38z IoTaWatt 5.0, Firmware version 02_07_05
11/17/22 21:52:38z SPIFFS mounted.
11/17/22 16:52:38 Local time zone: -5:00, using DST/BST when in effect.
11/17/22 16:52:38 device name: IotaWatt
11/17/22 16:52:38 HTTP server started
11/17/22 16:52:38 timeSync: service started.
11/17/22 16:52:38 statService: started.
11/17/22 16:52:38 dataLog: service started.
11/17/22 16:52:39 dataLog: Last log entry 11/17/22 16:49:05
11/17/22 16:52:43 historyLog: service started.
11/17/22 16:52:43 historyLog: Last log entry 11/17/22 16:49:00
11/17/22 16:52:45 WiFi connected. SSID=CKZ_2HA, IP=192.168.1.139, channel=11, RSSI -48db
11/17/22 16:52:45 MDNS responder started for hostname IotaWatt
11/17/22 16:52:45 LLMNR responder started for hostname IotaWatt
11/17/22 16:52:45 Updater: service started. Auto-update class is MINOR
11/17/22 16:52:47 Updater: Auto-update is current for class MINOR.
