Hi,
Was working well for a long time, and seemed to stop uploading back in July '23. Seems to be stuck and not sending current data to influx. Thoughts?
Logs:
11/10/23 05:02:33z Real Time Clock is running. Unix time 1699592553
11/10/23 05:02:33z Reset reason: Software/System restart
11/10/23 05:02:33z Trace: 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[14], 1:6[4], 14:0, 14:4, 14:5, 14:7, 14:8, 1:6[6], 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
11/10/23 05:02:33z ESP8266 ID: 6145049, RTC PCF8523 (68)
11/10/23 05:02:33z IoTaWatt 5.0, Firmware version 02_07_05
11/10/23 05:02:33z SPIFFS mounted.
11/09/23 21:02:33 Local time zone: -8:00, using DST/BST when in effect.
11/09/23 21:02:33 device name: IotaWatt
11/09/23 21:02:33 HTTP server started
11/09/23 21:02:33 influxDB_v1: Starting, interval:5, url:http://172.16.0.6:8086
11/09/23 21:02:33 timeSync: service started.
11/09/23 21:02:33 statService: started.
11/09/23 21:02:33 dataLog: service started.
11/09/23 21:02:35 dataLog: Last log entry 11/09/23 21:02:30
11/09/23 21:02:38 historyLog: service started.
11/09/23 21:02:39 historyLog: Last log entry 10/26/23 23:58:00
11/09/23 21:02:39 WiFi connected. SSID=deepblue, IP=172.16.0.48, channel=1, RSSI -60db
11/09/23 21:02:39 MDNS responder started for hostname IotaWatt
11/09/23 21:02:39 LLMNR responder started for hostname IotaWatt
11/09/23 21:02:39 Updater: service started. Auto-update class is MAJOR
11/09/23 21:02:41 Updater: Auto-update is current for class MAJOR.
11/09/23 21:02:42 influxDB_v1: stopped, Last post 07/19/23 06:13:25
11/09/23 21:04:39 influxDB_v1: Start posting at 07/19/23 06:13:30
