Hi all,
Had my Iota watt for a few years with no probs uploading to emoncms.org (and sometimes a local InfluxDB). I changed this week to a local EmonPi for emoncms and the Iotawatt had been uploading data to the new device ok.
Today it stopped and on investigation the Iotawatt was flashing the LED sequence indicating there was a problem with a log file and scanning was taking place. Once it came back online I noticed it was rebooting frequently. It’s possible this may have been happening before I noticed it doing its log file scan. Here is the latest log:
1/10/23 20:43:48z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -56db
1/10/23 20:43:48z MDNS responder started for hostname IotaWatt
1/10/23 20:43:49z LLMNR responder started for hostname IotaWatt
1/10/23 20:43:49z emoncms: Start posting at 01/10/23 20:43:10
1/10/23 20:43:50z Updater: Auto-update is current for class MAJOR.
1/10/23 20:44:20z influxDB_v1: stopped, Last post 01/01/70 00:00:00
1/10/23 20:44:21z Real Time Clock is running. Unix time 1673383461
1/10/23 20:44:21z Reset reason: Exception
1/10/23 20:44:21z Trace: 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:44:21z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:44:21z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:44:21z SPIFFS mounted.
1/10/23 20:44:21z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:44:21z device name: IotaWatt
1/10/23 20:44:21z HTTP server started
1/10/23 20:44:21z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:44:21z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:44:21z timeSync: service started.
1/10/23 20:44:22z statService: started.
1/10/23 20:44:22z dataLog: service started.
1/10/23 20:44:22z dataLog: Last log entry 01/10/23 20:44:20
1/10/23 20:44:22z historyLog: service started.
1/10/23 20:44:22z historyLog: Last log entry 01/10/23 20:44:00
1/10/23 20:44:28z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -57db
1/10/23 20:44:28z MDNS responder started for hostname IotaWatt
1/10/23 20:44:28z LLMNR responder started for hostname IotaWatt
1/10/23 20:44:28z Updater: service started. Auto-update class is MAJOR
1/10/23 20:44:28z emoncms: Start posting at 01/10/23 20:43:50
1/10/23 20:44:58z influxDB_v1: stopped, Last post 01/01/70 00:00:00
1/10/23 20:44:59z Real Time Clock is running. Unix time 1673383499
1/10/23 20:44:59z Reset reason: Exception
1/10/23 20:44:59z Trace: 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:44:59z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:44:59z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:44:59z SPIFFS mounted.
1/10/23 20:44:59z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:44:59z device name: IotaWatt
1/10/23 20:44:59z HTTP server started
1/10/23 20:44:59z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:44:59z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:44:59z timeSync: service started.
1/10/23 20:44:59z statService: started.
1/10/23 20:45:00z dataLog: service started.
1/10/23 20:45:00z dataLog: Last log entry 01/10/23 20:44:55
1/10/23 20:45:00z historyLog: service started.
1/10/23 20:45:00z historyLog: Last log entry 01/10/23 20:44:00
1/10/23 20:45:06z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -57db
1/10/23 20:45:06z MDNS responder started for hostname IotaWatt
1/10/23 20:45:06z LLMNR responder started for hostname IotaWatt
1/10/23 20:45:06z Updater: service started. Auto-update class is MAJOR
1/10/23 20:45:06z emoncms: Start posting at 01/10/23 20:44:30
1/10/23 20:45:07z Updater: Auto-update is current for class MAJOR.
1/10/23 20:45:08z Real Time Clock is running. Unix time 1673383508
1/10/23 20:45:08z Reset reason: Exception
1/10/23 20:45:08z Trace: 15:14[15], 15:15, 15:16, 32:95, 31:126, 31:1, 1:6[6], 1:1, 1:2[1], 9:0[1], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:45:08z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:45:08z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:45:08z SPIFFS mounted.
1/10/23 20:45:08z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:45:08z device name: IotaWatt
1/10/23 20:45:08z HTTP server started
1/10/23 20:45:08z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:45:08z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:45:08z timeSync: service started.
1/10/23 20:45:08z statService: started.
1/10/23 20:45:09z dataLog: service started.
1/10/23 20:45:09z dataLog: Last log entry 01/10/23 20:45:05
1/10/23 20:45:13z historyLog: service started.
1/10/23 20:45:13z historyLog: Last log entry 01/10/23 20:45:00
1/10/23 20:45:14z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -57db
1/10/23 20:45:14z MDNS responder started for hostname IotaWatt
1/10/23 20:45:14z LLMNR responder started for hostname IotaWatt
1/10/23 20:45:14z Updater: service started. Auto-update class is MAJOR
1/10/23 20:45:14z emoncms: Start posting at 01/10/23 20:45:10
1/10/23 20:45:44z influxDB_v1: stopped, Last post 01/01/70 00:00:00
1/10/23 20:45:45z Real Time Clock is running. Unix time 1673383545
1/10/23 20:45:45z Reset reason: Exception
1/10/23 20:45:45z Trace: 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[8], 31:5, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:45:45z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:45:45z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:45:45z SPIFFS mounted.
1/10/23 20:45:45z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:45:45z device name: IotaWatt
1/10/23 20:45:45z HTTP server started
1/10/23 20:45:45z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:45:45z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:45:45z timeSync: service started.
1/10/23 20:45:45z statService: started.
1/10/23 20:45:46z dataLog: service started.
1/10/23 20:45:46z dataLog: Last log entry 01/10/23 20:45:40
1/10/23 20:45:50z historyLog: service started.
1/10/23 20:45:50z historyLog: Last log entry 01/10/23 20:45:00
1/10/23 20:45:51z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -57db
1/10/23 20:45:51z MDNS responder started for hostname IotaWatt
1/10/23 20:45:51z LLMNR responder started for hostname IotaWatt
1/10/23 20:45:51z Updater: service started. Auto-update class is MAJOR
1/10/23 20:45:51z emoncms: Start posting at 01/10/23 20:45:20
1/10/23 20:46:21z influxDB_v1: stopped, Last post 01/01/70 00:00:00
1/10/23 20:46:22z Real Time Clock is running. Unix time 1673383582
1/10/23 20:46:22z Reset reason: Exception
1/10/23 20:46:22z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:46:22z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:46:22z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:46:22z SPIFFS mounted.
1/10/23 20:46:22z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:46:22z device name: IotaWatt
1/10/23 20:46:22z HTTP server started
1/10/23 20:46:22z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:46:22z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:46:22z timeSync: service started.
1/10/23 20:46:22z statService: started.
1/10/23 20:46:23z dataLog: service started.
1/10/23 20:46:23z dataLog: Last log entry 01/10/23 20:46:20
1/10/23 20:46:28z historyLog: service started.
1/10/23 20:46:28z historyLog: Last log entry 01/10/23 20:46:00
1/10/23 20:46:28z Updater: service started. Auto-update class is MAJOR
1/10/23 20:46:28z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -57db
1/10/23 20:46:28z MDNS responder started for hostname IotaWatt
1/10/23 20:46:29z LLMNR responder started for hostname IotaWatt
1/10/23 20:46:29z emoncms: Start posting at 01/10/23 20:45:50
1/10/23 20:46:30z Updater: Auto-update is current for class MAJOR.
1/10/23 20:47:00z influxDB_v1: stopped, Last post 01/01/70 00:00:00
1/10/23 20:47:02z Real Time Clock is running. Unix time 1673383622
1/10/23 20:47:02z Reset reason: Exception
1/10/23 20:47:02z Trace: 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
1/10/23 20:47:02z ESP8266 ID: 192587, RTC PCF8523 (68)
1/10/23 20:47:02z IoTaWatt 4.x, Firmware version 02_07_05
1/10/23 20:47:02z SPIFFS mounted.
1/10/23 20:47:02z Local time zone: +0:00, using DST/BST when in effect.
1/10/23 20:47:02z device name: IotaWatt
1/10/23 20:47:02z HTTP server started
1/10/23 20:47:02z emoncms: Starting, interval:10, url:ht tp://193. xx .1.94/emoncms
1/10/23 20:47:02z influxDB_v1: Starting, interval:5, url:ht tp://193. xx .1.100:8086
1/10/23 20:47:02z timeSync: service started.
1/10/23 20:47:02z statService: started.
1/10/23 20:47:03z dataLog: service started.
1/10/23 20:47:03z dataLog: Last log entry 01/10/23 20:47:00
1/10/23 20:47:07z historyLog: service started.
1/10/23 20:47:07z historyLog: Last log entry 01/10/23 20:47:00
1/10/23 20:47:08z WiFi connected. SSID=Router57657374, IP=193. xx .1.95, channel=3, RSSI -58db
1/10/23 20:47:08z MDNS responder started for hostname IotaWatt
1/10/23 20:47:08z LLMNR responder started for hostname IotaWatt
1/10/23 20:47:08z Updater: service started. Auto-update class is MAJOR
1/10/23 20:47:08z emoncms: Start posting at 01/10/23 20:46:30
(URLs masked as forum wouldn’t let me post them)
Just realised if I stop the emoncms upload the Iotawatt doesn’t keep restarting, but whilst it is running it successfully posts to my EmonPi for the 30-odd seconds.
Any ideas folks?
