Hello!
I have recently purchased an IoTaWatt and have it all set up with no problems. Except that I notice in the Message Log that it restarts a couple of times a day or so. I just wanted to see if there was anything I could look at to see why. I attach the message log and would really appreciate any pointers!
Thanks
James
11/22/21 22:51:25z Real Time Clock is running. Unix time 1637621485
11/22/21 22:51:25z Reset reason: Exception
11/22/21 22:51:25z Trace: 31:2[5], 31:120, 21:100[31], 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/22/21 22:51:25z ESP8266 ID: 16307851, RTC PCF8523
11/22/21 22:51:25z IoTaWatt 5.0, Firmware version 02_06_06
11/22/21 22:51:25z SPIFFS mounted.
11/22/21 22:51:25z Local time zone: +0:00, using DST/BST when in effect.
11/22/21 22:51:25z device name: IotaWatt
11/22/21 22:51:25z HTTP server started
11/22/21 22:51:25z emoncms: Starting, interval:10, url:
11/22/21 22:51:25z influxDB_v1: Starting, interval:10, url:
11/22/21 22:51:25z timeSync: service started.
11/22/21 22:51:25z statService: started.
11/22/21 22:51:25z dataLog: service started.
11/22/21 22:51:25z dataLog: Last log entry 11/22/21 22:51:20
11/22/21 22:51:29z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -68db
11/22/21 22:51:29z MDNS responder started for hostname IotaWatt
11/22/21 22:51:29z LLMNR responder started for hostname IotaWatt
11/22/21 22:51:29z Updater: service started. Auto-update class is MINOR
11/22/21 22:51:29z emoncms: Start posting at 11/22/21 22:51:10
11/22/21 22:51:30z historyLog: service started.
11/22/21 22:51:30z historyLog: Last log entry 11/22/21 22:51:00
11/22/21 22:51:30z influxDB_v1: Start posting at 11/22/21 22:51:10
11/22/21 22:51:32z Updater: Auto-update is current for class MINOR.
11/22/21 23:24:15z Real Time Clock is running. Unix time 1637623455
11/22/21 23:24:15z Reset reason: Exception
11/22/21 23:24:15z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/22/21 23:24:15z ESP8266 ID: 16307851, RTC PCF8523
11/22/21 23:24:15z IoTaWatt 5.0, Firmware version 02_06_06
11/22/21 23:24:15z SPIFFS mounted.
11/22/21 23:24:15z Local time zone: +0:00, using DST/BST when in effect.
11/22/21 23:24:15z device name: IotaWatt
11/22/21 23:24:15z HTTP server started
11/22/21 23:24:15z emoncms: Starting, interval:10, url:
11/22/21 23:24:15z influxDB_v1: Starting, interval:10, url:
11/22/21 23:24:15z timeSync: service started.
11/22/21 23:24:15z statService: started.
11/22/21 23:24:15z dataLog: service started.
11/22/21 23:24:16z dataLog: Last log entry 11/22/21 23:24:10
11/22/21 23:24:20z historyLog: service started.
11/22/21 23:24:20z historyLog: Last log entry 11/22/21 23:24:00
11/22/21 23:24:20z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -70db
11/22/21 23:24:20z MDNS responder started for hostname IotaWatt
11/22/21 23:24:20z LLMNR responder started for hostname IotaWatt
11/22/21 23:24:20z Updater: service started. Auto-update class is MINOR
11/22/21 23:24:20z emoncms: Start posting at 11/22/21 23:24:00
11/22/21 23:24:22z influxDB_v1: Start posting at 11/22/21 23:24:00
11/22/21 23:24:23z Updater: Auto-update is current for class MINOR.
11/23/21 00:31:44z Real Time Clock is running. Unix time 1637627504
11/23/21 00:31:44z Reset reason: Exception
11/23/21 00:31:44z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/23/21 00:31:44z ESP8266 ID: 16307851, RTC PCF8523
11/23/21 00:31:44z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 00:31:44z SPIFFS mounted.
11/23/21 00:31:44z Local time zone: +0:00, using DST/BST when in effect.
11/23/21 00:31:44z device name: IotaWatt
11/23/21 00:31:44z HTTP server started
11/23/21 00:31:44z emoncms: Starting, interval:10, url:
11/23/21 00:31:44z influxDB_v1: Starting, interval:10, url:
11/23/21 00:31:44z timeSync: service started.
11/23/21 00:31:44z statService: started.
11/23/21 00:31:44z dataLog: service started.
11/23/21 00:31:45z dataLog: Last log entry 11/23/21 00:31:40
11/23/21 00:31:49z historyLog: service started.
11/23/21 00:31:49z historyLog: Last log entry 11/23/21 00:31:00
11/23/21 00:31:49z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -72db
11/23/21 00:31:49z MDNS responder started for hostname IotaWatt
11/23/21 00:31:49z LLMNR responder started for hostname IotaWatt
11/23/21 00:31:49z Updater: service started. Auto-update class is MINOR
11/23/21 00:31:49z emoncms: Start posting at 11/23/21 00:31:30
11/23/21 00:31:50z Updater: Auto-update is current for class MINOR.
11/23/21 00:31:50z influxDB_v1: Start posting at 11/23/21 00:31:30
11/23/21 05:47:04z Real Time Clock is running. Unix time 1637646424
11/23/21 05:47:04z Reset reason: Exception
11/23/21 05:47:04z Trace: 31:2[3], 32:60, 32:60, 32:60, 32:62, 32:63, 31:1, 1:6[6], 1:1[7], 1:2[8], 9:0[8], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/23/21 05:47:04z ESP8266 ID: 16307851, RTC PCF8523
11/23/21 05:47:04z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 05:47:04z SPIFFS mounted.
11/23/21 05:47:04z Local time zone: +0:00, using DST/BST when in effect.
11/23/21 05:47:04z device name: IotaWatt
11/23/21 05:47:04z HTTP server started
11/23/21 05:47:04z emoncms: Starting, interval:10, url:
11/23/21 05:47:04z influxDB_v1: Starting, interval:10, url:
11/23/21 05:47:04z timeSync: service started.
11/23/21 05:47:04z statService: started.
11/23/21 05:47:04z dataLog: service started.
11/23/21 05:47:04z dataLog: Last log entry 11/23/21 05:47:00
11/23/21 05:47:09z historyLog: service started.
11/23/21 05:47:09z historyLog: Last log entry 11/23/21 05:47:00
11/23/21 05:47:09z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -73db
11/23/21 05:47:09z MDNS responder started for hostname IotaWatt
11/23/21 05:47:09z LLMNR responder started for hostname IotaWatt
11/23/21 05:47:09z Updater: service started. Auto-update class is MINOR
11/23/21 05:47:09z emoncms: Start posting at 11/23/21 05:46:50
11/23/21 05:47:11z Updater: Auto-update is current for class MINOR.
11/23/21 05:47:11z influxDB_v1: Start posting at 11/23/21 05:46:50
11/23/21 05:56:23z Real Time Clock is running. Unix time 1637646983
11/23/21 05:56:23z Reset reason: Exception
11/23/21 05:56:23z Trace: 31:2[5], 31:120, 21:100[31], 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/23/21 05:56:23z ESP8266 ID: 16307851, RTC PCF8523
11/23/21 05:56:23z IoTaWatt 5.0, Firmware version 02_06_06
11/23/21 05:56:23z SPIFFS mounted.
11/23/21 05:56:23z Local time zone: +0:00, using DST/BST when in effect.
11/23/21 05:56:23z device name: IotaWatt
11/23/21 05:56:23z HTTP server started
11/23/21 05:56:23z emoncms: Starting, interval:10, url:
11/23/21 05:56:23z influxDB_v1: Starting, interval:10, url:
11/23/21 05:56:23z timeSync: service started.
11/23/21 05:56:23z statService: started.
11/23/21 05:56:23z dataLog: service started.
11/23/21 05:56:24z dataLog: Last log entry 11/23/21 05:56:20
11/23/21 05:56:28z historyLog: service started.
11/23/21 05:56:28z historyLog: Last log entry 11/23/21 05:56:00
11/23/21 05:56:28z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -73db
11/23/21 05:56:28z MDNS responder started for hostname IotaWatt
11/23/21 05:56:28z LLMNR responder started for hostname IotaWatt
11/23/21 05:56:28z Updater: service started. Auto-update class is MINOR
11/23/21 05:56:28z emoncms: Start posting at 11/23/21 05:56:00
11/23/21 05:56:29z influxDB_v1: Start posting at 11/23/21 05:56:00
11/23/21 05:56:31z Updater: Auto-update is current for class MINOR.
11/24/21 14:32:34z Real Time Clock is running. Unix time 1637764354
11/24/21 14:32:34z Reset reason: Exception
11/24/21 14:32:34z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
11/24/21 14:32:34z ESP8266 ID: 16307851, RTC PCF8523
11/24/21 14:32:34z IoTaWatt 5.0, Firmware version 02_06_06
11/24/21 14:32:34z SPIFFS mounted.
11/24/21 14:32:34z Local time zone: +0:00, using DST/BST when in effect.
11/24/21 14:32:34z device name: IotaWatt
11/24/21 14:32:34z HTTP server started
11/24/21 14:32:34z emoncms: Starting, interval:10, url:
11/24/21 14:32:34z influxDB_v1: Starting, interval:10, url:
11/24/21 14:32:34z timeSync: service started.
11/24/21 14:32:34z statService: started.
11/24/21 14:32:34z dataLog: service started.
11/24/21 14:32:35z dataLog: Last log entry 11/24/21 14:32:30
11/24/21 14:32:39z historyLog: service started.
11/24/21 14:32:39z historyLog: Last log entry 11/24/21 14:32:00
11/24/21 14:32:39z WiFi connected. SSID=BFH, IP=192.168.1.135, channel=1, RSSI -73db
11/24/21 14:32:39z MDNS responder started for hostname IotaWatt
11/24/21 14:32:39z LLMNR responder started for hostname IotaWatt
11/24/21 14:32:39z Updater: service started. Auto-update class is MINOR
11/24/21 14:32:39z emoncms: Start posting at 11/24/21 14:32:10
11/24/21 14:32:41z Updater: Auto-update is current for class MINOR.
11/24/21 14:32:42z influxDB_v1: Start posting at 11/24/21 14:32:10
Firmware version: 02_06_06
Running time: 7h 38m 54s
free Heap: 23536
772 samples per AC cycle
31.7 AC cycles sampled/second
50.0 Hz
Data Logs
|Current Log:|10/27/2021 16:57:35 - 11/24/2021 22:11:25|119.2 MB|
|History Log:|10/27/2021 16:58:00 - 11/24/2021 22:11:00|9.935 MB|
