7/06/21 15:04:18z Real Time Clock is running. Unix time 1625583858
7/06/21 15:04:18z Reset reason: Software/System restart
7/06/21 15:04:18z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[1], 1:2[2], 9:0[2], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[20], 1:6[4], 20:0, 20:1
7/06/21 15:04:18z ESP8266 ChipID: 12703771
7/06/21 15:04:18z IoTaWatt 5.0, Firmware version 02_06_02
7/06/21 15:04:18z SPIFFS mounted.
7/06/21 11:04:18 Local time zone: -5:00
7/06/21 11:04:18 Using Daylight Saving Time (BST) when in effect.
7/06/21 11:04:18 device name: IotaWatt
7/06/21 11:04:18 HTTP server started
7/06/21 11:04:18 emoncms: Starting, interval:10, url:http://emoncms.org
7/06/21 11:04:18 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/06/21 11:04:18 timeSync: service started.
7/06/21 11:04:18 statService: started.
7/06/21 11:04:18 dataLog: service started.
7/06/21 11:04:18 dataLog: Last log entry 07/06/21 11:04:15
7/06/21 11:04:22 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -74db
7/06/21 11:04:22 MDNS responder started for hostname IotaWatt
7/06/21 11:04:22 LLMNR responder started for hostname IotaWatt
7/06/21 11:04:22 Updater: service started. Auto-update class is MINOR
7/06/21 11:04:22 emoncms: Query failed 401
7/06/21 11:04:22 emoncms: Start posting at 03/02/21 16:03:50
7/06/21 11:04:23 historyLog: service started.
7/06/21 11:04:23 historyLog: Last log entry 07/06/21 11:04:00
7/06/21 11:04:26 influxDB_v1: Start posting at 07/06/21 11:04:00
7/06/21 11:04:27 Updater: Auto-update is current for class MINOR.
7/18/21 00:00:19 WiFi disconnected.
7/18/21 00:00:34 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=6, RSSI -88db
7/19/21 21:30:18 WiFi disconnected.
7/19/21 21:30:20 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=6, RSSI -90db
7/22/21 11:30:19 WiFi disconnected.
7/22/21 11:30:24 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -78db
7/24/21 10:10:50z Real Time Clock is running. Unix time 1627121450
7/24/21 10:10:50z Reset reason: Exception
7/24/21 10:10:50z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/24/21 10:10:50z ESP8266 ChipID: 12703771
7/24/21 10:10:50z IoTaWatt 5.0, Firmware version 02_06_02
7/24/21 10:10:50z SPIFFS mounted.
7/24/21 06:10:50 Local time zone: -5:00
7/24/21 06:10:50 Using Daylight Saving Time (BST) when in effect.
7/24/21 06:10:50 device name: IotaWatt
7/24/21 06:10:50 HTTP server started
7/24/21 06:10:50 emoncms: Starting, interval:10, url:http://emoncms.org
7/24/21 06:10:50 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/24/21 06:10:50 timeSync: service started.
7/24/21 06:10:50 statService: started.
7/24/21 06:10:50 dataLog: service started.
7/24/21 06:10:50 dataLog: Last log entry 07/24/21 06:10:45
7/24/21 06:10:54 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -76db
7/24/21 06:10:54 MDNS responder started for hostname IotaWatt
7/24/21 06:10:54 LLMNR responder started for hostname IotaWatt
7/24/21 06:10:54 Updater: service started. Auto-update class is MINOR
7/24/21 06:10:55 historyLog: service started.
7/24/21 06:10:55 historyLog: Last log entry 07/24/21 06:10:00
7/24/21 06:10:55 emoncms: Start posting at 03/02/21 16:03:50
7/24/21 06:10:57 Updater: Auto-update is current for class MINOR.
7/24/21 10:10:59z Real Time Clock is running. Unix time 1627121459
7/24/21 10:10:59z Reset reason: Exception
7/24/21 10:10:59z Trace: 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/24/21 10:10:59z ESP8266 ChipID: 12703771
7/24/21 10:10:59z IoTaWatt 5.0, Firmware version 02_06_02
7/24/21 10:10:59z SPIFFS mounted.
7/24/21 06:10:59 Local time zone: -5:00
7/24/21 06:10:59 Using Daylight Saving Time (BST) when in effect.
7/24/21 06:10:59 device name: IotaWatt
7/24/21 06:10:59 HTTP server started
7/24/21 06:10:59 emoncms: Starting, interval:10, url:http://emoncms.org
7/24/21 06:10:59 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/24/21 06:10:59 timeSync: service started.
7/24/21 06:10:59 statService: started.
7/24/21 06:10:59 dataLog: service started.
7/24/21 06:10:59 dataLog: Last log entry 07/24/21 06:10:55
7/24/21 06:11:03 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -75db
7/24/21 06:11:03 MDNS responder started for hostname IotaWatt
7/24/21 06:11:03 LLMNR responder started for hostname IotaWatt
7/24/21 06:11:03 Updater: service started. Auto-update class is MINOR
7/24/21 06:11:04 historyLog: service started.
7/24/21 06:11:04 historyLog: Last log entry 07/24/21 06:10:00
7/24/21 06:11:04 emoncms: Start posting at 03/02/21 16:03:50
7/24/21 10:11:09z Real Time Clock is running. Unix time 1627121469
7/24/21 10:11:09z Reset reason: Exception
7/24/21 10:11:09z Trace: 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:1[14], 1:2, 9:0, 9:0, 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/24/21 10:11:09z ESP8266 ChipID: 12703771
7/24/21 10:11:09z IoTaWatt 5.0, Firmware version 02_06_02
7/24/21 10:11:09z SPIFFS mounted.
7/24/21 06:11:09 Local time zone: -5:00
7/24/21 06:11:09 Using Daylight Saving Time (BST) when in effect.
7/24/21 06:11:09 device name: IotaWatt
7/24/21 06:11:09 HTTP server started
7/24/21 06:11:09 emoncms: Starting, interval:10, url:http://emoncms.org
7/24/21 06:11:09 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/24/21 06:11:09 timeSync: service started.
7/24/21 06:11:09 statService: started.
7/24/21 06:11:09 dataLog: service started.
7/24/21 06:11:09 dataLog: Last log entry 07/24/21 06:11:05
7/24/21 06:11:13 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -76db
7/24/21 06:11:13 MDNS responder started for hostname IotaWatt
7/24/21 06:11:13 LLMNR responder started for hostname IotaWatt
7/24/21 06:11:13 Updater: service started. Auto-update class is MINOR
7/24/21 06:11:14 historyLog: service started.
7/24/21 06:11:14 historyLog: Last log entry 07/24/21 06:11:00
7/24/21 06:11:14 emoncms: Start posting at 03/02/21 16:03:50
7/24/21 06:11:17 Updater: Auto-update is current for class MINOR.
7/24/21 06:11:17 influxDB_v1: Start posting at 07/24/21 06:10:00
7/24/21 10:11:18z Real Time Clock is running. Unix time 1627121478
7/24/21 10:11:18z Reset reason: Exception
7/24/21 10:11:18z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/24/21 10:11:18z ESP8266 ChipID: 12703771
7/24/21 10:11:18z IoTaWatt 5.0, Firmware version 02_06_02
7/24/21 10:11:18z SPIFFS mounted.
7/24/21 06:11:18 Local time zone: -5:00
7/24/21 06:11:18 Using Daylight Saving Time (BST) when in effect.
7/24/21 06:11:18 device name: IotaWatt
7/24/21 06:11:18 HTTP server started
7/24/21 06:11:18 emoncms: Starting, interval:10, url:http://emoncms.org
7/24/21 06:11:18 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/24/21 06:11:18 timeSync: service started.
7/24/21 06:11:18 statService: started.
7/24/21 06:11:18 dataLog: service started.
7/24/21 06:11:18 dataLog: Last log entry 07/24/21 06:11:15
7/24/21 06:11:22 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -76db
7/24/21 06:11:22 MDNS responder started for hostname IotaWatt
7/24/21 06:11:22 LLMNR responder started for hostname IotaWatt
7/24/21 06:11:22 Updater: service started. Auto-update class is MINOR
7/24/21 06:11:22 emoncms: Start posting at 03/02/21 16:03:50
7/24/21 06:11:23 historyLog: service started.
7/24/21 06:11:23 historyLog: Last log entry 07/24/21 06:11:00
7/24/21 06:11:26 Updater: Auto-update is current for class MINOR.
7/24/21 06:11:26 influxDB_v1: Start posting at 07/24/21 06:10:00
7/24/21 10:11:28z Real Time Clock is running. Unix time 1627121488
7/24/21 10:11:28z Reset reason: Exception
7/24/21 10:11:28z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/24/21 10:11:28z ESP8266 ChipID: 12703771
7/24/21 10:11:28z IoTaWatt 5.0, Firmware version 02_06_02
7/24/21 10:11:28z SPIFFS mounted.
7/24/21 06:11:28 Local time zone: -5:00
7/24/21 06:11:28 Using Daylight Saving Time (BST) when in effect.
7/24/21 06:11:28 device name: IotaWatt
7/24/21 06:11:28 HTTP server started
7/24/21 06:11:28 emoncms: Starting, interval:10, url:http://emoncms.org
7/24/21 06:11:28 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/24/21 06:11:28 timeSync: service started.
7/24/21 06:11:28 statService: started.
7/24/21 06:11:28 dataLog: service started.
7/24/21 06:11:28 dataLog: Last log entry 07/24/21 06:11:25
7/24/21 06:11:32 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -76db
7/24/21 06:11:32 MDNS responder started for hostname IotaWatt
7/24/21 06:11:32 LLMNR responder started for hostname IotaWatt
7/24/21 06:11:32 Updater: service started. Auto-update class is MINOR
7/24/21 06:11:32 emoncms: Start posting at 03/02/21 16:03:50
7/24/21 06:11:33 historyLog: service started.
7/24/21 06:11:33 historyLog: Last log entry 07/24/21 06:11:00
7/24/21 06:11:36 Updater: Auto-update is current for class MINOR.
7/24/21 06:11:37 influxDB_v1: Start posting at 07/24/21 06:10:00
7/27/21 07:05:17z Real Time Clock is running. Unix time 1627369517
7/27/21 07:05:17z Reset reason: Exception
7/27/21 07:05:17z Trace: 8:4, 8:6, 8:8, 8:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/27/21 07:05:17z ESP8266 ChipID: 12703771
7/27/21 07:05:17z IoTaWatt 5.0, Firmware version 02_06_02
7/27/21 07:05:17z SPIFFS mounted.
7/27/21 03:05:17 Local time zone: -5:00
7/27/21 03:05:17 Using Daylight Saving Time (BST) when in effect.
7/27/21 03:05:17 device name: IotaWatt
7/27/21 03:05:17 HTTP server started
7/27/21 03:05:17 emoncms: Starting, interval:10, url:http://emoncms.org
7/27/21 03:05:17 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
7/27/21 03:05:17 timeSync: service started.
7/27/21 03:05:17 statService: started.
7/27/21 03:05:17 dataLog: service started.
7/27/21 03:05:17 dataLog: Last log entry 07/27/21 03:05:10
7/27/21 03:05:21 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -76db
7/27/21 03:05:21 MDNS responder started for hostname IotaWatt
7/27/21 03:05:21 LLMNR responder started for hostname IotaWatt
7/27/21 03:05:21 Updater: service started. Auto-update class is MINOR
7/27/21 03:05:21 emoncms: Query failed 401
7/27/21 03:05:21 emoncms: Start posting at 03/02/21 16:03:50
7/27/21 03:05:22 historyLog: service started.
7/27/21 03:05:22 historyLog: Last log entry 07/27/21 03:05:00
7/27/21 03:05:24 influxDB_v1: Start posting at 07/27/21 03:05:00
7/27/21 03:05:26 Updater: Auto-update is current for class MINOR.
8/07/21 14:33:04 Updater: Update from 02_06_02 to 02_06_05
8/07/21 14:33:04 Updater: download 02_06_05
8/07/21 14:33:08 Updater: Release downloaded 4801ms, size 834296
8/07/21 14:33:14 Updater: signature verified
8/07/21 14:33:22 Updater: firmware upgraded to version 02_06_05
8/07/21 14:33:22 Updater: Firmware updated, restarting.
8/07/21 18:33:30z Real Time Clock is running. Unix time 1628361210
8/07/21 18:33:30z Reset reason: Software/System restart
8/07/21 18:33:30z Trace: 1:6[1], 1:6[2], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[3], 32:60, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[2], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[7], 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[5], 1:6[4], 5:0, 5:7
8/07/21 18:33:30z ESP8266 ChipID: 12703771
8/07/21 18:33:30z IoTaWatt 5.0, Firmware version 02_06_05
8/07/21 18:33:30z Updater: Installing update files for version 02_06_05
8/07/21 18:33:30z Updater: Installing GRAPH.HTM
8/07/21 18:33:30z Updater: Installing GRAPH.JS
8/07/21 18:33:30z Updater: Installing GRAPH2.HTM
8/07/21 18:33:30z Updater: Installing GRAPH2.JS
8/07/21 18:33:30z Updater: Installing INDEX.HTM
8/07/21 18:33:31z Updater: Installing TABLES.TXT
8/07/21 18:33:31z Updater: Installing CNFSTYLE.CSS
8/07/21 18:33:31z Updater: Installing EDIT.HTM
8/07/21 18:33:31z Updater: Installation complete.
8/07/21 18:33:31z SPIFFS mounted.
8/07/21 14:33:31 Local time zone: -5:00
8/07/21 14:33:31 Using Daylight Saving Time (BST) when in effect.
8/07/21 14:33:31 device name: IotaWatt
8/07/21 14:33:31 HTTP server started
8/07/21 14:33:31 emoncms: Starting, interval:10, url:http://emoncms.org
8/07/21 14:33:31 influxDB_v1: Starting, interval:60, url:http://192.168.186.50:8086
8/07/21 14:33:31 timeSync: service started.
8/07/21 14:33:31 statService: started.
8/07/21 14:33:32 dataLog: service started.
8/07/21 14:33:32 dataLog: Last log entry 08/07/21 14:33:05
8/07/21 14:33:35 Updater: service started. Auto-update class is MINOR
8/07/21 14:33:35 emoncms: Query failed 401
8/07/21 14:33:36 historyLog: service started.
8/07/21 14:33:36 historyLog: Last log entry 08/07/21 14:33:00
8/07/21 14:33:36 WiFi connected. SSID=Not4U4other, IP=192.168.186.52, channel=11, RSSI -78db
8/07/21 14:33:36 MDNS responder started for hostname IotaWatt
8/07/21 14:33:36 LLMNR responder started for hostname IotaWatt
8/07/21 14:33:38 influxDB_v1: Start posting at 08/07/21 14:33:00
8/07/21 14:33:40 Updater: Auto-update is current for class MINOR.
8/07/21 14:33:41 emoncms: Query failed 401
8/07/21 14:33:46 emoncms: Query failed 401
8/07/21 14:33:51 emoncms: Query failed 401
8/07/21 14:33:56 emoncms: Query failed 401
… Thouansa moew
