IotaWatt to Esphome
May be somebody have expirience to migrate device from Iotawatt firmware to EspHome?
I need only power meter, without output to emoncms and etc, only working with HomeAssisstant
Second time i had lost my sd card :frowning:
I have device about 6 or 7 years, use only for power meter to HomeAssistant , so i think esphome will be best decision
It might be better to explain the actual problem you are having, instead of what you believe to be the solution. You solution sounds like “throwing out the baby with the bath water”.
I am pretty sure no one has done what you are suggesting. People have done it for Emporia, since that is not an open system.
I am not even sure why you would want to do this. Esphome has a very steep learning curve and doing what you want in esphome with IotaWatt hardware is definitely going to be in the “challenging” category.
I have been using IotaWatt for a long time I never had significant issues with it, but did see corruption of an SD card once. After I put it on a mini UPS and got a new quality SD card (non-fake, reputable manufacturer) it has been extremely reliable. But, I don’t send the data to HA, since I much prefer Grafana.
I have thought about buying an Emporia and converting it, but not enough to actually do it yet (too many other projects that are more interesting or urgent).
I use only HA and it’s energy dashboard
I’d lost my SD second time for 5 years (last time i spend about 2 hours to restore working state with new card (no backuped config.txt)).
Because of using HA i dont need store data or anything on sd card, and i’d like to store config in esp flash
I use a lot of Esp home devices, so config is store in one place (with backup). If esp board was lost, i can replace it with new in 10-15 minutes
So i’d like to have more reliable system without SD card
IotaWatt - is dead project, esphome - alive
“Reports of my death are greatly exaggerated”, Mark Twain.
Well glad it works for you. I have yet to find the love for HA. But then I come from a long history of Tasmota and in the early days people used to make fun of HA, since you always restart it. Since I had already set up MQTT, NodeRED, InfluxDB, and Grafana, HA didn’t really offer anything for my needs.
I am pretty sure there is no existing component/conversion process for IotaWatt to esphome. It will not be a small project. If you are interested in tackling it, it might be possible. The source for IotaWatt is open and available. You will need an understanding on c++. esphome uses a combination of c++, Python, with config stored in YAML. The learning curve of both projects is steep, since they both are doing complicated things.
So, you have had SD card corruption twice in 5 years and once had to spend 2 hours recovering because you did not have a backup of the config. My suggestion, make a backup of your config and get a quality SD card. If it fails again, it should be very quick to replace.
Now, if you really want a mult-week/month/year technical challenge go for it. I am on my third iteration of a project to read data from my heat pump water heater. Turns out 9-bit serial is not as easy as it once was (it seems no one uses it anymore so all the current chips that do Wi-Fi only have 8-bit capable UARTs). I do it for the technical challenge, not because the data is that interesting or that I need it
Hi User, did you ever work this out, im interested to do the same. Thanks!
Hi, what is your “mini UPS” solution? I had corruption after a power outage a couple of weeks ago losing all my historical data and chewing up a couple of hours and a new quality uSD card so would like to mitigate the risk of this happening again.
Thanks in advance.
You could use something like this: https://www.newegg.com/sirmedal-poe-01-usb-dc-poe/p/2FT-00P4-00001?item=9SIAZ6ZJU90024
I don’t have that one. Or, if you already have a regular UPS just plug I the 5V adapter to it. Do not plug the AC adapter (for voltage reference) to the UPS.
The mini UPS is not a lot cheaper than a regular small UPS and it might provide noisier power so a small regular UPS is probably a better solution.
Thanks I’ll look into it. Necessary at the moment as we are in thunderstorm season so the power is not so great.
if you are willing to swap ESP chip you can try GitHub - pawel-sw/esphome-iotawatt: IoTaWatt ESPHome Component (ESP32-S3 Swap) it makes home assistant integration much easier with esphome MQTT, also eliminates need for flaky SD card and makes it more stable due to abundant ESP32-S3 resources
So would that mean we could have it directly interface with Home Assistant via MQTT?
yes it is standard esphome component
I have to comment here that this is a complicated solution to a simple problem. For my nickle I’d probably just fire up a NODEred workflow to query (or use the status API) to get periodic data and resend it to MQTT topics. You need an MQTT agent running anyway on an Rpi or a NAS box. Probably take a half hour to setup with NODEred or maybe a couple of hours if you need to install and learn NODEred.
You will not be able to replicate the accuracy of IoTaWatt with ESPhome and I don’t think you will be able to monitor fifteen CTs with it.
I love HA and ESPHome, I have probably 200-300 total devices and about 50 of them are ESPHome devices.
First, I still am not convinced the HA Energy Dashboard approach is as good as the older-school HA approach of stashing energy data in influxdb and using grafana. I do that, it works nice. Biggest issue is it’s harder to integrate non-iotawatt devices (like shelly), and it is hard to handle parent-child relationships (e.g. circuit A reports energy, but on circuit A is device X which separately reports energy). I think HA does those, it’s harder with influxdb and rolling your own.
OTOH INfluxdb and iotawatt’s uploaded works better for preserving data when HA is down; HA doesn’t like being fed historical data, Influxdb and iotawatt will buffer data and upload later.
All that said, I am curious about the mqtt points – esphome sensors should be able to appear in HA through the native API, without MQTT. Is there a reason for MQTT?
Linwood
I’m using OpenHab with Home Assistant binding that understands Home Assistant MQTT Discovery.
This is standard ESPHome component, so it should work fine with native protobuf Home Assistant API.
