I purchased an Iotawatt back in late 2024, but only got it installed back in April of this year. It worked great! for about 24 hours. I fiddled with it a bit, pulled the SD card, looked at the logs, but couldn’t get it to consistently connect to the router. So I left it hanging out of the wall and forgot about it for a few months.
I got back to it this weekend and messed around a bit. One of the things I tried was a better power adapter with a shorter cable on the off chance there was interference or something from the long one tangled up right next to the wifi antenna. Suddenly it was communicating with the router again (same room, 10’ away, clear line of sight) It worked great! for about 24 hours.
I did see that it was collecting data the whole time. I have a good 3 months of tracking in there (though Home Assistant won’t import retroactively by itself ). I just can’t get at it.
Throwing the router logs at Claude it diagnosed a client side DHCP issue:
DHCP client wedge (root-caused via router logs, 2026-08-03/04) — after ~2.5 hours of accelerating DHCP renewals (90min → 45min → 22min → down to every 1 minute), the device stopped sending DHCPREQUEST entirely and looped on DHCPDISCOVER broadcasts once a minute, indefinitely. Router logs confirm it kept responding with a valid DHCPOFFER every time — the device just never completed the handshake. WiFi association never dropped throughout (zero disassociations, hourly WPA rekeys all succeeded), so this is not a radio/AP-side issue — it’s a client-side DHCP state-machine hang in the device’s own firmware. Because it never disassociates from WiFi, the device’s documented self-recovery (“restart if not reconnected within an hour”) never triggers.
I tried power cycling this morning for about 15 seconds before work. It didn’t reconnect to the network. It don’t see any activity from it in the router log since this morning. I suspect if I power cycle it a few more times for more than a few seconds it might come back. I’ve kicked out the DHCP lease so that if/when I do get it talking again it might last a few days rather than one, but that’s a bandaid. I could us a Home Assistant automation to power cycle it repeatedly after it stops updating, but again, that feels like a bad solution.
Is this a firmware issue I can fix with an update? Is it a bad ESP8266 I can fix with a board swap (I have a handful of ESP8266MOD units around, but they’re half the size physically, so probably not a drop in + flash. I’d be fine getting a specific model off Amazon or Mouser)?
Hey, thanks for responding. Finally getting time to look at things again now that it’s the weekend. When it’s not connected the external green LED is on and lightly pulsing. Maybe twice a second or so? Here’s what the router sees with regards to its connection:
After a few minutes the LED switches to pulsing red. Sometimes it’ll broadcast its built in wifi access point, sometimes not (or it stops before I see it).
I wasn’t able to re-connect, but I pulled the SD card, and I’ve attached the iotamsgs.txt below.
You can see when I last worked on it (8/2) and it finally connected:
8/03/26 14:29:25 Updater: Invalid response from server. HTTPcode: -4
8/04/26 13:26:51 timeSync: No time update in last 24 hours.
I tried a reboot, which had no externally visible effect. It does eventually reconnect to the wifi, but it never gets an IP address from DHCP, and it then gives up, assigning itself the local-link address:
You can see the multiple reboots today with similar eventual behavior.
I’m at a bit of a loss of where to go next. I don’t know why it would fail to get an ip address when the router clearly still has it assigned the same one. Presumably some communication breakdown.
I appreciate any direction or troubleshooting advice. Thanks!
It looks as if there is some incompatibility or mismatch between your router and the IoTaWatt. Apparently the settings on the router have changed during the period covered by the message log. The IP address assigned lately suggests that the DHCP server is not available. There are a lot of rabbit holes that we could go down, but first I’d suggest that you try to connect the IoTaWatt to another network - a different router (take the device, power supply and reference transformer to a friend’s house) or connect to a hotspot on your phone. See if it succeeds.
When you power up the IoTaWatt you should see an IoTaWatt AP while it is blinking RGG or RRG during the three minutes after power up.
I had the same problem with IotaWatt and ASUS GT-AX6000, try setting static IP address it will rule out DHCP problems.
ESP8266 Espressif SDK 2.x has many WiFi bugs, ARP/power-save issues or ESP8266 remaining connected but missing WPA rekey exchanges. I had some success updating other (non IotaWatt) devices to run on Espressif SDK 3.0.x.
IotaWatt is running on top ESP8266 Arduino core 2.5.2 which uses Espressif NONOS SDK 2.2.1 released in 2018 so updating to at least 3.0.2 might help as it has notes "Revise the DHCP behavior according to protocol” in 3.0.1, and 3.0.2 has a DHCP-related crash fix plus additional Wi-Fi compatibility work. Not sure if it will be drop in update and I can’t test it as I upgraded my IotaWatt to ESP32S3 which was rock solid for last 6 months.
I would be interested in updating to 3.0.2. How would you go about doing that? I have Netgear Orbi Mesh routers and My Hubitat home system keeps reporting every so often an http error 408.(Device has a Static IP and IOTAWatt is only 10 feet from the router). I’m just about to the point to just replace it. Thank you.
I don’t have IotaWatt for testing if you are familiar with ESP8266 flashing via USB cable and know how to restore you can try attached binary (note it is untested). The FW does compile cleanly on new SDK you can use attached patch to tinker with it if something doesn’t work.
The point about e255’s Hubitat 408 errors is worth separating from the WiFi drop. A 408 means the HTTP request timed out, which could be the ESP8266 being slow to respond rather than fully disconnected. Static IP removes DHCP lease renewal as a variable, so that’s a reasonable first check. CurtisZM’s SDK 3.x suggestion targets known DHCP and power-save fixes, but flashing an untested binary over USB is risky if you can’t restore the original firmware. I’d confirm whether the 408s coincide with the router dropping the client before replacing anything.
Keeping the 408s separate from the WiFi drop is a good call. If the ESP8266 is still on the network but just slow to answer, that points at the device rather than the Orbi link, and a static IP already rules out DHCP as a suspect. Before touching the USB flashing route CurtisZM describes, it’s worth logging whether the 408s line up with the router losing the client. If they don’t, replacing hardware seems premature. An untested binary with no easy restore path is a real risk for a working meter.
