Hi all
I’ve got an issue with my Iotawatt that’s stopped posting to my emoncms server that I’ve had before (IottaWatt not posting to EmonCMS).
This issue coincides with upgrading the firmware and subsequent restart on my access points so the Iotawatt temporarily lost connection to the emoncms server.
The only thing I’ve done since is to reset my Iotawatt to see if that resolves but I’m keen to get to the bottom of this issue.
The emoncms server is on the local network but has a domain address.
Many Thanks
Dave
7/04/21 20:15:48z Real Time Clock is running. Unix time 1625429748
7/04/21 20:15:48z Reset reason: Exception
7/04/21 20:15:48z Trace: 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[6], 31:90, 21:110, 21:110, 31:91, 31:9, 31:1, 1:6[6], 1:3, 1:3, 1:6[1], 1:6[3], 1:5[31], 1:6[4], 31:0, 31:1, 31:2[4], 3:91, 15:0[32]
7/04/21 20:15:48z ESP8266 ChipID: 2518071
7/04/21 20:15:48z IoTaWatt 4.x, Firmware version 02_06_02
7/04/21 20:15:48z SPIFFS mounted.
7/04/21 20:15:48z Local time zone: +0:00
7/04/21 20:15:48z device name: House
7/04/21 20:15:48z HTTP server started
7/04/21 20:15:48z emoncms: Starting, interval:5, url:http://energy.m0nne.com/emoncms
7/04/21 20:15:48z timeSync: service started.
7/04/21 20:15:48z statService: started.
7/04/21 20:15:48z dataLog: service started.
7/04/21 20:15:49z dataLog: Last log entry 07/04/21 20:15:45
7/04/21 20:15:52z WiFi connected. SSID=WiFi, IP=192.168.10.133, channel=1, RSSI -58db
7/04/21 20:15:52z MDNS responder started for hostname House
7/04/21 20:15:52z LLMNR responder started for hostname House
7/04/21 20:15:52z Updater: service started. Auto-update class is MINOR
7/04/21 20:15:52z emoncms: Start posting at 07/04/21 20:15:40
7/04/21 20:15:53z historyLog: service started.
7/04/21 20:15:53z historyLog: Last log entry 07/04/21 20:15:00
7/04/21 20:15:54z Updater: Auto-update is current for class MINOR.
7/16/21 21:12:34z WiFi disconnected.
7/16/21 21:13:08z WiFi connected. SSID=WiFi, IP=192.168.10.133, channel=1, RSSI -63db
7/17/21 05:10:25z WiFi disconnected.
7/17/21 05:10:27z WiFi connected. SSID=WiFi, IP=192.168.10.133, channel=1, RSSI -62db
8/01/21 01:50:11z WiFi disconnected.
8/01/21 01:53:23z WiFi connected. SSID=WiFi, IP=192.168.10.133, channel=1, RSSI -55db
8/01/21 22:09:45z Restart command received.
8/01/21 22:09:47z Real Time Clock is running. Unix time 1627855787
8/01/21 22:09:47z Reset reason: Software/System restart
8/01/21 22:09:47z Trace: 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:3, 1:1[11], 1:2[12], 9:0[12], 9:0, 9:1, 8:4, 8:6, 8:8, 8:9, 9:3, 9:5, 9:9, 1:2, 1:3, 10:2, 10:3
8/01/21 22:09:47z ESP8266 ChipID: 2518071
8/01/21 22:09:47z IoTaWatt 4.x, Firmware version 02_06_02
8/01/21 22:09:47z SPIFFS mounted.
8/01/21 22:09:47z Local time zone: +0:00
8/01/21 22:09:47z device name: House
8/01/21 22:09:47z HTTP server started
8/01/21 22:09:47z emoncms: Starting, interval:5, url:http://energy.m0nne.com/emoncms
8/01/21 22:09:47z timeSync: service started.
8/01/21 22:09:47z statService: started.
8/01/21 22:09:47z dataLog: service started.
8/01/21 22:09:48z dataLog: Last log entry 08/01/21 22:09:45
8/01/21 22:09:52z historyLog: service started.
8/01/21 22:09:52z historyLog: Last log entry 08/01/21 22:09:00
8/01/21 22:09:52z WiFi connected. SSID=WiFi, IP=192.168.10.133, channel=1, RSSI -57db
8/01/21 22:09:52z MDNS responder started for hostname House
8/01/21 22:09:52z LLMNR responder started for hostname House
8/01/21 22:09:52z Updater: service started. Auto-update class is MINOR
8/01/21 22:09:52z emoncms: Start posting at 08/01/21 01:53:25
8/01/21 22:09:54z Updater: Auto-update is current for class MINOR.
